28/03/2007 #1
Modelo para el LM35 sensor temperatura en Proteus
Hola
Como no existe un modelo para el LM35 para Proteus, me puse a buscarlo por Internet. Finalmente dí con un archivo ZIP que aparentemente es el modelo. Dentro de este hay tres archivos: un .ASC, un .CCT y un .CIR. Segun ví, son modelos SPICE de acuerdo a uno de los archivos (el .CIR) que contiene lo siguiente:
*SPICE Simulation of National Semiconductor LM35 Precision Centigrade Temperature Sensor
X1 1 LM35
.subckt LM35 Out
* Simulation of National Semiconductor LM35 Precision Centigrade Temperature Sensor
* By Colin Seymour http://www.cjseymour.plus.com/
* Spec for LM35 connected as Full-Range Centigrade Temperature Sensor:
* Vout = +1500 mV at +150°C
* = +250 mV at +25°C
* = -550 mV at -55°C
* Current source I1 and resistor R0 create a voltage source
* with a linear temperature coefficient tc1
* controlled by the SPICE temperature
* R = R0 * (1. + dt * tc1)
* where R0 is the resistance at the nominal temperature
* dt is the difference between the resistor's temperature
* and the nominal temperature TNOM
* LM35 tempco = 0.01 V per degree C
I1 0 N001 1
R0 N001 0 1 tc1=0.01
* Current source I2 and resistor R1 create a similar voltage source
* with the same linear temperature coefficient, but the temperature
* is fixed at zero C, which is the reference temperature
* for the LM35
I2 0 N002 1
R1 N002 0 1 tc1=0.01 TEMP=0
* G1 and R2 subtract the reference voltage from the
* temperature dependent voltage to obtain a temperature
* dependent output with zero at the reference temperature
* for the LM35.
* The output impedance is set to 0.1 ohms to match the
* dynamic impedance of the LM35 for a 1mA load
G1 0 Out N001 N002 10
R2 Out 0 0.1
.ends
* Simulation commands to plot the operating point
* over a temperature range
.step temp -55 150 5
.OP
.print V(1)
.end
Mi problema es que no se como hacer que este modelo funcione en PROteus. Como lo añado a la plantilla del LM35?. Como utilizo estos archivos?? Es compatible esta información con el Proteus?.
Ayuda por favor
LEs adjunto el modelo que me baje en la NAtional SEmiconductor
12/12/2007 #2
Avatar de gcgiron
En la version de Proteus 7.2 SP0 ya viene el modelo para simular
16/06/2010 #3
Respuesta: Modelo para el LM35 sensor temperatura en Proteus
justo yo tb estoy haciendo un proyecto de sensor de temperatuta , estoy utilizando el proteus 7 y si existe el Lm35.Descargalo ya que no demora mucho.
