26/01/2008 #1
Dalvi decoder
Does anyone how to create a dalvi decoder? Pls if you have any datasheet any circuit diagram, blocks.
26/01/2008 #2
Avatar de Eduardo
Dolby decoder ?
26/01/2008 #3
Dalvi decoder for analog cable coded chanels
My provider uses
DV100 www.dalvi.co.uk/pdfs/DV100.pdf
dsr400 http://www.technetix.plc.uk/products.../c2/dhr200.pdf
for PAL
Technical Specification: Active Line Cut & Rotate.
Cut position is dynamic and random in one of 256 positions
Optional Audio Descrambling:
Scrambling system: Spectrum inversion
Frequency Response: 100Hz to 11kHz ±3dB
26/01/2008 #4
Scrambling system: Spectrum inversion... old ...
moretv-> wilma program for PC
Your search canal plus
http://www.ayudadigital.com/video/ma..._canalplus.htm
http://es.geocities.com/ketoc2k3/Files/Elect/adecod.pdf
26/01/2008 #5
Spectrum inversion is just for audio scrambling.
for video they cut each line in 2 parts. the cuting point can be done in 256 positions on a line. After the cut the lines are rotated (the first part becomes the second part). the system is pseudo digital because they convert the chanels (HBO, DISCOVERY TRAVEL....) from analog to digital make the coding and convert back to analog. It is something like Videocypt systems. if you have something for videocrypt decoding it might help me.
Tipo de Archivo: gif linecutandrot3_774.gif (9,9 KB (Kilobytes), 805 visitas)
