03/11/2012 #1
VHDL: Divisor Binario. Problema: "Can't resolve multiple constant drivers"
Hola!
Tengo una duda con mi código.
Es un divisor binario de 4 bits, el procedimiento que hace es comprar y restar.
No me compila el programa porque dice que no puedo tener múltiples drivers. Según esto me muestra que tengo las mismos drivers en el proceso 1 y el proceso 2, pero yo no le veo algún problema. ¿Me podrían ayudar por favor?
Me muestra los siguientes errores:
Error (10028): Can't resolve multiple constant drivers for net "EDO.IDLE" at DIV.vhd(50)
Error (10029): Constant driver at DIV.vhd(40)
Error (10028): Can't resolve multiple constant drivers for net "EDO.RES_1" at DIV.vhd(50)
Error (10028): Can't resolve multiple constant drivers for net "EDO.RES_2" at DIV.vhd(50)
Error (10028): Can't resolve multiple constant drivers for net "EDO.RES_3" at DIV.vhd(50)
Error (10028): Can't resolve multiple constant drivers for net "EDO.RES_4" at DIV.vhd(50)
Error: Can't elaborate top-level user hierarchy
Error: Quartus II Analysis & Synthesis was unsuccessful. 7 errors, 20 warnings
Error: Peak virtual memory: 226 megabytes
Error: Processing ended: Sat Nov 03 19:18:09 2012
Error: Elapsed time: 00:00:00
Error: Total CPU time (on all processors): 00:00:01
El código
entity Div is
port (Dividen: unsigned(3 downto 0);
Divisor: unsigned(3 downto 0);
RST, CLK: in std_logic;
Cociente, Residuo: out std_logic_vector(3 downto 0));
end entity Div;
architecture NICE of DIV is
component SumadorRestador is
port( A,B: in std_logic_vector(7 downto 0);
Se: std_logic;
S: out std_logic_vector(7 downto 0));
end component SumadorRestador;
type EDOS is (IDLE, RES_1, RES_2, RES_3, RES_4);
signal EDO, EDOF: EDOS;
signal A,B,C,D: unsigned(3 downto 0);
signal A_1,B_1,C_1,D_1: unsigned(7 downto 0);
signal Coci: std_logic_vector(3 downto 0);
signal Ini: std_logic;
signal Dividendo: unsigned(7 downto 0);
begin
Dividendo <= "0000" & Dividen;
Ini <= RST;
p1: process(CLK,RST)
begin
if RST = '0' then
EDO <= IDLE;
elsif CLK'event and CLK='1' then
EDO <= EDOF;
end if;
end process;
p2: process (EDO, A, B, C, D, Ini, Dividendo, Divisor)
begin
case EDO is
when IDLE => if Ini = '0' then
EDO <= RES_1;
else
EDO <= IDLE;
end if;
when RES_1 => if (A > Divisor) or A = Divisor then
A_1 <= "0000" & A - Dividendo;
Coci(3) <= '1';
EDO <= RES_2;
else
A_1 <= "0000" & A;
Coci(3) <= '0';
EDO <= RES_2;
end if;
when RES_2 => if B > Divisor or B = Divisor then
B_1 <= "0000" & B - Dividendo ;
Coci(2) <= '1';
EDO <= RES_3;
else
B_1 <= "0000" & B;
Coci(2) <= '0';
EDO <= RES_3;
end if;
when RES_3 =>
if C > Divisor or C = Divisor then
C_1 <="0000" & C - Dividendo;
Coci(1) <= '1';
EDO <= RES_3;
else
C_1 <= "0000" & C;
Coci(1) <= '0';
EDO <= RES_3;
end if;
when RES_4 =>
if D > Divisor or D = Divisor then
D_1 <= "0000" & D - Dividendo;
Coci(0) <= '1';
EDO <= IDLE;
else
D_1 <= "0000" & D;
Coci(0) <= '0';
EDO <= IDLE;
end if;
when others => null;
end case;
end process;
p3: process (EDO)
begin
case EDO is
when IDLE => Cociente <= Coci;
when RES_1 => A <= Dividendo (6 downto 3);
when RES_2 => B <= A_1(2 downto 0) & Dividendo(2);
when RES_3 => C <= B_1(2 downto 0) & Dividendo(1);
when RES_4 => D <= C_1(2 downto 0) & Dividendo(0);
end case;
end process;
end architecture NICE;
04/11/2012 #2
En VHDL sintetizable una señal no debe ser asignada en dos procesos distintos.
Ten en cuenta que es concurrente, ¿qué valor va a coger una señal si en un instante el proceso 1 le da el valor '0' y el proceso 2 le da el valor '1'?
Eléctricamente es un cortocircuito.
Por ejemplo, en tu diseño, la señal EDO es asignada (recibe valor) en los procesos p1 y p2.
Revisa también que la señal EDOF no recibe valor, no es asignada en ningún sitio. Quiza tu intención era hacer que EDOF sea la señal registrada de EDO, por lo que en el p1, EDOF tendría que ser la señal que recibe valor, mientras que en p2, EDO sería la señal asignada.
Haz estas comprobaciones en el resto de señales que estás teniendo conflicto.
