16/07/2011 #61
Hello, thanks for your fast replay.
I've read them all these links and I cannot find any mistake of mine.
I make the sensor using 2 aluminium strip plates (one side is sticky) as sandwich in the middle a plastic strip. I tried 4mm, 5mm, 7mm, 0.5mm distances for dielectric size between 2 aluminium plates. Is there any problem?
I tried with 5cm height strips and 2.5cm height strips too... I tried 1.2 meters length and ~2.4 meters length...
Do I understand wrong? You said that I can't get good results using CapMeters? And I should use the oscillator method for best result? In other words, the capacitance changings cannot be detected by the capmeter, is this correct for you?
Also now I tested the strips' conductivity using my multimeter's short circuit test (beep) option, it beeps normally, that means the capacitor "sensor" is totally connected to the measurement circuit and the cables are OK. There are no any simple mistake. The problem is I can't get changings on more than 2 cm distance...
What to do?
EDIT:
I get this result when I'm not near to the sensor.
H: high byte of timer
L: low byte of timer
T: result of average filter
B: The timer total value for the moment (H*255+L)
H:577 L:151 T:396760 B:402286
H:565 L:221 T:396839 B:399296
H:565 L: 31 T:396910 B:399106
H:566 L:105 T:396989 B:399435
H:562 L:166 T:397036 B:398476
H:557 L: 31 T:397037 B:397066
H:548 L:128 T:396969 B:394868
H:536 L:233 T:396811 B:391913
H:582 L: 31 T:397018 B:403441
H:560 L: 91 T:397045 B:397891
H:546 L: 31 T:396958 B:394261
H:552 L: 91 T:396924 B:395851
H:553 L:122 T:396899 B:396137
H:528 L: 21 T:396673 B:389661
H:581 L:246 T:396883 B:403401
H:552 L: 31 T:396849 B:395791
H:547 L:211 T:396782 B:394696
H:551 L: 91 T:396745 B:395596
H:538 L: 14 T:396603 B:392204
H:566 L:162 T:396693 B:399492
H:550 L:149 T:396653 B:395399
H:555 L:190 T:396654 B:396715
H:553 L: 18 T:396635 B:396033
H:538 L:159 T:396501 B:392349
H:574 L: 91 T:396656 B:401461
H:572 L:192 T:396794 B:401052
H:563 L: 91 T:396852 B:398656
H:559 L:114 T:396877 B:397659
H:565 L:242 T:396953 B:399317
H:559 L:131 T:396976 B:397676
H:556 L:222 T:396977 B:397002
H:557 L:134 T:396983 B:397169
H:534 L: 31 T:396802 B:391201
H:563 L:226 T:396864 B:398791
H:542 L: 31 T:396751 B:393241
H:549 L: 17 T:396696 B:395012
H:529 L:136 T:396488 B:390031
H:590 L:190 T:396774 B:405640
H:580 L: 31 T:396967 B:402931
H:556 L:132 T:396965 B:396912
H:561 L: 91 T:397002 B:398146
H:562 L: 31 T:397044 B:398341
H:564 L: 8 T:397099 B:398828
H:560 L:155 T:397126 B:397955
H:555 L:128 T:397111 B:396653
H:546 L:254 T:397029 B:394484
H:540 L:147 T:396899 B:392847
H:573 L: 91 T:397033 B:401206
H:548 L: 31 T:396962 B:394771
H:556 L:218 T:396964 B:396998
H:558 L:184 T:396980 B:397474
H:556 L: 91 T:396976 B:396871
H:538 L:240 T:396834 B:392430
H:565 L:169 T:396909 B:399244
H:551 L:172 T:396871 B:395677
H:551 L:237 T:396836 B:395742
H:551 L:255 T:396802 B:395760
H:533 L: 91 T:396621 B:391006
H:569 L:214 T:396736 B:400309
H:550 L:216 T:396696 B:395466
H:553 L: 91 T:396678 B:396106
H:553 L: 91 T:396660 B:396106
H:535 L: 31 T:396497 B:391456
H:568 L:202 T:396608 B:400042
H:546 L:175 T:396539 B:394405
H:559 L: 24 T:396572 B:397569
H:560 L: 31 T:396611 B:397831
H:558 L: 31 T:396633 B:397321
H:547 L:160 T:396571 B:394645
H:542 L:140 T:396470 B:393350
H:523 L: 91 T:396220 B:388456
H:577 L: 31 T:396406 B:402166
H:552 L:152 T:396390 B:395912
H:551 L:203 T:396369 B:395708
H:552 L:185 T:396356 B:395945
H:534 L:189 T:396200 B:391359
H:565 L:174 T:396295 B:399249
H:544 L:201 T:396221 B:393921
H:549 L: 1 T:396182 B:394996
H:536 L: 7 T:396042 B:391687
H:568 L:203 T:396167 B:400043
H:546 L:176 T:396112 B:394406
H:560 L: 8 T:396165 B:397808
H:559 L: 31 T:396209 B:397576
H:560 L:146 T:396263 B:397946
H:554 L:209 T:396270 B:396479
H:531 L: 31 T:396088 B:390436
H:575 L: 5 T:396261 B:401630
H:549 L: 91 T:396224 B:395086
H:557 L:192 T:396256 B:397227
H:558 L:240 T:396295 B:397530
H:559 L:234 T:396342 B:397779
H:552 L:251 T:396331 B:396011
H:532 L:204 T:396161 B:390864
H:575 L: 31 T:396332 B:401656
H:549 L: 91 T:396293 B:395086
H:558 L: 91 T:396327 B:397381
H:561 L: 91 T:396384 B:398146
H:561 L: 31 T:396437 B:398086
H:556 L:255 T:396456 B:397035
H:542 L:123 T:396358 B:393333
H:543 L: 31 T:396269 B:393496
H:525 L:167 T:396043 B:389042
H:587 L:159 T:396318 B:404844
H:571 L:142 T:396457 B:400747
H:567 L:222 T:396561 B:399807
H:560 L: 31 T:396601 B:397831
H:560 L:128 T:396642 B:397928
H:556 L: 91 T:396650 B:396871
H:553 L: 91 T:396633 B:396106
H:529 L: 91 T:396425 B:389986
H:582 L: 31 T:396644 B:403441
H:559 L:205 T:396679 B:397750
H:544 L:231 T:396593 B:393951
H:559 L: 91 T:396626 B:397636
H:553 L:190 T:396613 B:396205
H:538 L: 31 T:396476 B:392221
H:572 L: 27 T:396613 B:400887
H:568 L: 31 T:396715 B:399871
H:561 L:173 T:396763 B:398228
H:558 L:105 T:396782 B:397395
H:557 L:175 T:396796 B:397210
H:534 L: 24 T:396621 B:391194
H:569 L:220 T:396736 B:400315
H:552 L:113 T:396709 B:395873
H:551 L:213 T:396678 B:395718
H:552 L: 30 T:396650 B:395790
H:538 L:125 T:396515 B:392315
H:568 L:218 T:396626 B:400058
H:554 L: 91 T:396617 B:396361
H:540 L: 15 T:396495 B:392715
H:571 L: 91 T:396627 B:400696
H:552 L:126 T:396604 B:395886
H:552 L: 91 T:396580 B:395851
H:554 L: 29 T:396571 B:396299
H:536 L: 31 T:396419 B:391711
H:567 L:177 T:396524 B:399762
H:555 L:215 T:396531 B:396740
H:535 L: 31 T:396372 B:391456
H:577 L:169 T:396557 B:402304
H:555 L: 91 T:396559 B:396616
H:548 L:182 T:396508 B:394922
H:558 L: 8 T:396533 B:397298
H:555 L:171 T:396538 B:396696
H:537 L: 27 T:396395 B:391962
H:566 L:208 T:396493 B:399538
H:547 L:243 T:396438 B:394728
H:556 L:194 T:396455 B:396974
H:559 L:119 T:396492 B:397664
H:556 L: 31 T:396502 B:396811
H:534 L:168 T:396341 B:391338
H:571 L:123 T:396478 B:400728
H:551 L:234 T:396455 B:395739
H:548 L: 91 T:396404 B:394831
H:553 L: 91 T:396395 B:396106
H:535 L: 91 T:396242 B:391516
H:566 L:204 T:396345 B:399534
H:548 L:239 T:396303 B:394979
H:556 L:203 T:396324 B:396983
H:558 L:159 T:396359 B:397449
H:556 L: 91 T:396375 B:396871
H:537 L:168 T:396242 B:392103
H:569 L:108 T:396365 B:400203
H:554 L: 13 T:396363 B:396283
H:537 L: 31 T:396225 B:391966
H:580 L:132 T:396438 B:403032
H:568 L: 9 T:396545 B:399849
H:569 L:223 T:396663 B:400318
H:568 L:137 T:396766 B:399977
H:556 L:215 T:396773 B:396995
H:559 L:129 T:396801 B:397674
H:556 L: 23 T:396802 B:396803
H:541 L: 31 T:396682 B:392986
H:583 L:174 T:396906 B:403839
H:560 L: 91 T:396937 B:397891
H:563 L:232 T:396995 B:398797
H:555 L: 91 T:396983 B:396616
H:555 L: 31 T:396970 B:396556
H:536 L:143 T:396809 B:391823
H:569 L:198 T:396918 B:400293
H:560 L: 13 T:396946 B:397813
H:542 L: 91 T:396832 B:393301
H:554 L:188 T:396820 B:396458
H:554 L:184 T:396809 B:396454
H:538 L: 31 T:396665 B:392221
H:564 L:144 T:396737 B:398964
H:545 L: 17 T:396651 B:393992
H:553 L:183 T:396637 B:396198
H:540 L: 91 T:396517 B:392791
H:581 L:111 T:396728 B:403266
H:573 L:206 T:396871 B:401321
H:545 L:144 T:396785 B:394119
H:555 L:208 T:396784 B:396733
H:538 L: 91 T:396643 B:392281
H:575 L: 31 T:396800 B:401656
H:573 L:234 T:396942 B:401349
H:558 L: 31 T:396954 B:397321
H:562 L:229 T:397003 B:398539
H:563 L: 31 T:397053 B:398596
H:561 L: 31 T:397085 B:398086
H:564 L:121 T:397143 B:398941
H:563 L: 31 T:397189 B:398596
H:561 L:209 T:397222 B:398264
H:558 L: 13 T:397225 B:397303
H:553 L:169 T:397192 B:396184
H:533 L: 31 T:396997 B:390946
H:572 L:161 T:397123 B:401021
H:555 L: 1 T:397104 B:396526
H:544 L:192 T:397004 B:393912
I get this with 22pF real capacitor:
H: 11 L: 25 T:2833 B:2830
H: 11 L: 26 T:2833 B:2831
H: 11 L: 24 T:2833 B:2829
H: 11 L: 31 T:2833 B:2836
H: 11 L: 27 T:2833 B:2832
H: 11 L: 29 T:2833 B:2834
And this is result of 10nF real capacitor
H:724 L:233 T:439752 B:439853
H:724 L:182 T:439754 B:439802
H:724 L: 13 T:439750 B:439633
H:724 L:151 T:439751 B:439771
H:724 L:125 T:439751 B:439745
H:724 L:207 T:439753 B:439827
H:724 L:166 T:439754 B:439786
H:724 L:113 T:439753 B:439733
H:724 L:163 T:439754 B:439783
H:724 L: 4 T:439750 B:439624
H:724 L:112 T:439750 B:439732
H:724 L:147 T:439750 B:439767
My circuit counts 2131 when there is no any capacitor connected.
I use this formula for calculating the capacitor value:
Cap = (T-2131)/ClockFreq/Resistor_value
9.94nF = (439750-2131)/(20Mhz/4)/8.8Mohm <----- 10nF
15.9pF = (2833-2131)/(20Mhz/4)/8.8Mohm <----- 22pF
8.9nF = (396627-2131)/(20Mhz/4)/8.8Mohm <----- the sensor
################# SPANISH VERSION ####################
Hola, gracias por su repetición rápida.
Los he leído todos estos enlaces y no puedo encontrar ningún error mío.
Yo hago el sensor con dos placas de tiras de aluminio (un lado es persistente) como sándwich en el medio una tira de plástico. Traté de 4mm, 5mm, 7mm distancias, de 0,5 mm para el tamaño de dieléctrico entre dos placas de aluminio. ¿Hay algún problema?
He probado con las tiras de 5 cm de altura y 2,5 cm de altura tiras demasiado ... Traté de 1,2 metros de longitud y 2,4 metros de longitud ~ ...
¿Entiendo mal? Usted ha dicho que no puede obtener buenos resultados utilizando CapMeters? Y debe utilizar el método del oscilador para un mejor resultado? En otras palabras, la capacidad changings no puede ser detectado por el capmeter, ¿es esto correcto para usted?
Ahora también he probado la conductividad de las tiras "mediante la prueba de mi multímetro de cortocircuito (pitido) opción, se oye un pitido normalmente, eso significa que el condensador de" sensor "es totalmente conectado a la red de medición y los cables están bien. No hay ningún error simple. El problema es que no puede conseguir en changings cm de distancia de más de 2 ...
¿Qué hacer?
EDIT:
Me sale este resultado cuando no estoy cerca del sensor.
H: byte alto del temporizador
L: byte bajo del contador
T: resultado de la media del filtro
B: El valor total de temporizador, por el momento (H * 255 + L)
[Quote] H: 577 L: 151 T: 396760 B: 402286
H: 565 L: 221 T: 396839 B: 399296
H: 565 L: 31 T: 396910 B: 399106
H: 566 L: 105 T: 396989 B: 399435
H: 562 L: 166 T: 397036 B: 398476
H: 557 L: 31 T: 397037 B: 397066
H: 548 L: 128 T: 396969 B: 394868
H: 536 L: 233 T: 396811 B: 391913
H: 582 L: 31 T: 397018 B: 403441
H: 560 L: 91 T: 397045 B: 397891
H: 546 L: 31 T: 396958 B: 394261
H: 552 L: 91 T: 396924 B: 395851
H: 553 L: 122 T: 396899 B: 396137
H: 528 L: 21 T: 396673 B: 389661
H: 581 L: 246 T: 396883 B: 403401
H: 552 L: 31 T: 396849 B: 395791
H: 547 L: 211 T: 396782 B: 394696
H: 551 L: 91 T: 396745 B: 395596
H: 538 L: 14 T: 396603 B: 392204
H: 566 L: 162 T: 396693 B: 399492
H: 550 L: 149 T: 396653 B: 395399
H: 555 L: 190 T: 396654 B: 396715
H: 553 L: 18 T: 396635 B: 396033
H: 538 L: 159 T: 396501 B: 392349
H: 574 L: 91 T: 396656 B: 401461
H: 572 L: 192 T: 396794 B: 401052
H: 563 L: 91 T: 396852 B: 398656
H: 559 L: 114 T: 396877 B: 397659
H: 565 L: 242 T: 396953 B: 399317
H: 559 L: 131 T: 396976 B: 397676
H: 556 L: 222 T: 396977 B: 397002
H: 557 L: 134 T: 396983 B: 397169
H: L 534: 31 T: 396802 B: 391201
H: 563 L: 226 T: 396864 B: 398791
H: 542 L: 31 T: 396751 B: 393241
H: 549 L: 17 T: 396696 B: 395012
H: 529 L: 136 T: 396488 B: 390031
H: 590 L: 190 T: 396774 B: 405640
H: 580 L: 31 T: 396967 B: 402931
H: 556 L: 132 T: 396965 B: 396912
H: 561 L: 91 T: 397002 B: 398146
H: 562 L: 31 T: 397044 B: 398341
H: 564 L: 8 T: 397099 B: 398828
H: 560 L: 155 T: 397126 B: 397955
H: 555 L: 128 T: 397111 B: 396653
H: 546 L: 254 T: 397029 B: 394484
H: 540 L: 147 T: 396899 B: 392847
H: 573 L: 91 T: 397033 B: 401206
H: 548 L: 31 T: 396962 B: 394771
H: 556 L: 218 T: 396964 B: 396998
H: 558 L: 184 T: 396980 B: 397474
H: 556 L: 91 T: 396976 B: 396871
H: 538 L: 240 T: 396834 B: 392430
H: 565 L: 169 T: 396909 B: 399244
H: 551 L: 172 T: 396871 B: 395677
H: 551 L: 237 T: 396836 B: 395742
H: 551 L: 255 T: 396802 B: 395760
H: 533 L: 91 T: 396621 B: 391006
H: 569 L: 214 T: 396736 B: 400309
H: 550 L: 216 T: 396696 B: 395466
H: 553 L: 91 T: 396678 B: 396106
H: 553 L: 91 T: 396660 B: 396106
H: 535 L: 31 T: 396497 B: 391456
H: 568 L: 202 T: 396608 B: 400042
H: 546 L: 175 T: 396539 B: 394405
H: 559 L: 24 T: 396572 B: 397569
H: 560 L: 31 T: 396611 B: 397831
H: 558 L: 31 T: 396633 B: 397321
H: 547 L: 160 T: 396571 B: 394645
H: 542 L: 140 T: 396470 B: 393350
H: 523 L: 91 T: 396220 B: 388456
H: 577 L: 31 T: 396406 B: 402166
H: 552 L: 152 T: 396390 B: 395912
H: 551 L: 203 T: 396369 B: 395708
H: 552 L: 185 T: 396356 B: 395945
H: L 534: 189 T: 396200 B: 391359
H: 565 L: 174 T: 396295 B: 399249
H: 544 L: 201 T: 396221 B: 393921
H: 549 L: 1 T: 396182 B: 394996
H: 536 L: 7 T: 396042 B: 391687
H: 568 L: 203 T: 396167 B: 400043
H: 546 L: 176 T: 396112 B: 394406
H: 560 L: 8 T: 396165 B: 397808
H: 559 L: 31 T: 396209 B: 397576
H: 560 L: 146 T: 396263 B: 397946
H: 554 L: 209 T: 396270 B: 396479
H: 531 L: 31 T: 396088 B: 390436
H: 575 L: 5 T: 396261 B: 401630
H: 549 L: 91 T: 396224 B: 395086
H: 557 L: 192 T: 396256 B: 397227
H: 558 L: 240 T: 396295 B: 397530
H: 559 L: 234 T: 396342 B: 397779
H: 552 L: 251 T: 396331 B: 396011
H: 532 L: 204 T: 396161 B: 390864
H: 575 L: 31 T: 396332 B: 401656
H: 549 L: 91 T: 396293 B: 395086
H: 558 L: 91 T: 396327 B: 397381
H: 561 L: 91 T: 396384 B: 398146
H: 561 L: 31 T: 396437 B: 398086
H: 556 L: 255 T: 396456 B: 397035
H: 542 L: 123 T: 396358 B: 393333
H: 543 L: 31 T: 396269 B: 393496
H: 525 L: 167 T: 396043 B: 389042
H: 587 L: 159 T: 396318 B: 404844
H: 571 L: 142 T: 396457 B: 400747
H: 567 L: 222 T: 396561 B: 399807
H: 560 L: 31 T: 396601 B: 397831
H: 560 L: 128 T: 396642 B: 397928
H: 556 L: 91 T: 396650 B: 396871
H: 553 L: 91 T: 396633 B: 396106
H: 529 L: 91 T: 396425 B: 389986
H: 582 L: 31 T: 396644 B: 403441
H: 559 L: 205 T: 396679 B: 397750
H: 544 L: 231 T: 396593 B: 393951
H: 559 L: 91 T: 396626 B: 397636
H: 553 L: 190 T: 396613 B: 396205
H: 538 L: 31 T: 396476 B: 392221
H: 572 L: 27 T: 396613 B: 400887
H: 568 L: 31 T: 396715 B: 399871
H: 561 L: 173 T: 396763 B: 398228
H: 558 L: 105 T: 396782 B: 397395
H: 557 L: 175 T: 396796 B: 397210
H: L 534: 24 T: 396621 B: 391194
H: 569 L: 220 T: 396736 B: 400315
H: 552 L: 113 T: 396709 B: 395873
H: 551 L: 213 T: 396678 B: 395718
H: 552 L: 30 T: 396650 B: 395790
H: 538 L: 125 T: 396515 B: 392315
H: 568 L: 218 T: 396626 B: 400058
H: 554 L: 91 T: 396617 B: 396361
H: 540 L: 15 T: 396495 B: 392715
H: 571 L: 91 T: 396627 B: 400696
H: 552 L: 126 T: 396604 B: 395886
H: 552 L: 91 T: 396580 B: 395851
H: 554 L: 29 T: 396571 B: 396299
H: 536 L: 31 T: 396419 B: 391711
H: 567 L: 177 T: 396524 B: 399762
H: 555 L: 215 T: 396531 B: 396740
H: 535 L: 31 T: 396372 B: 391456
H: 577 L: 169 T: 396557 B: 402304
H: 555 L: 91 T: 396559 B: 396616
H: 548 L: 182 T: 396508 B: 394922
H: 558 L: 8 T: 396533 B: 397298
H: 555 L: 171 T: 396538 B: 396696
H: 537 L: 27 T: 396395 B: 391962
H: 566 L: 208 T: 396493 B: 399538
H: 547 L: 243 T: 396438 B: 394728
H: 556 L: 194 T: 396455 B: 396974
H: 559 L: 119 T: 396492 B: 397664
H: 556 L: 31 T: 396502 B: 396811
H: L 534: 168 T: 396341 B: 391338
H: 571 L: 123 T: 396478 B: 400728
H: 551 L: 234 T: 396455 B: 395739
H: 548 L: 91 T: 396404 B: 394831
H: 553 L: 91 T: 396395 B: 396106
H: 535 L: 91 T: 396242 B: 391516
H: 566 L: 204 T: 396345 B: 399534
H: 548 L: 239 T: 396303 B: 394979
H: 556 L: 203 T: 396324 B: 396983
H: 558 L: 159 T: 396359 B: 397449
H: 556 L: 91 T: 396375 B: 396871
H: 537 L: 168 T: 396242 B: 392103
H: 569 L: 108 T: 396365 B: 400203
H: 554 L: 13 T: 396363 B: 396283
H: 537 L: 31 T: 396225 B: 391966
H: 580 L: 132 T: 396438 B: 403032
H: 568 L: 9 T: 396545 B: 399849
H: 569 L: 223 T: 396663 B: 400318
H: 568 L: 137 T: 396766 B: 399977
H: 556 L: 215 T: 396773 B: 396995
H: 559 L: 129 T: 396801 B: 397674
H: 556 L: 23 T: 396802 B: 396803
H: 541 L: 31 T: 396682 B: 392986
H: 583 L: 174 T: 396906 B: 403839
H: 560 L: 91 T: 396937 B: 397891
H: 563 L: 232 T: 396995 B: 398797
H: 555 L: 91 T: 396983 B: 396616
H: 555 L: 31 T: 396970 B: 396556
H: 536 L: 143 T: 396809 B: 391823
H: 569 L: 198 T: 396918 B: 400293
H: 560 L: 13 T: 396946 B: 397813
H: 542 L: 91 T: 396832 B: 393301
H: 554 L: 188 T: 396820 B: 396458
H: 554 L: 184 T: 396809 B: 396454
H: 538 L: 31 T: 396665 B: 392221
H: 564 L: 144 T: 396737 B: 398964
H: 545 L: 17 T: 396651 B: 393992
H: 553 L: 183 T: 396637 B: 396198
H: 540 L: 91 T: 396517 B: 392791
H: 581 L: 111 T: 396728 B: 403266
H: 573 L: 206 T: 396871 B: 401321
H: 545 L: 144 T: 396785 B: 394119
H: 555 L: 208 T: 396784 B: 396733
H: 538 L: 91 T: 396643 B: 392281
H: 575 L: 31 T: 396800 B: 401656
H: 573 L: 234 T: 396942 B: 401349
H: 558 L: 31 T: 396954 B: 397321
H: 562 L: 229 T: 397003 B: 398539
H: 563 L: 31 T: 397053 B: 398596
H: 561 L: 31 T: 397085 B: 398086
H: 564 L: 121 T: 397143 B: 398941
H: 563 L: 31 T: 397189 B: 398596
H: 561 L: 209 T: 397222 B: 398264
H: 558 L: 13 T: 397225 B: 397303
H: 553 L: 169 T: 397192 B: 396184
H: 533 L: 31 T: 396997 B: 390946
H: 572 L: 161 T: 397123 B: 401021
H: 555 L: 1 T: 397104 B: 396526
H: 544 L: 192 T: 397004 B: 393912
[/ Quote]
Me sale este con un condensador de 22pF reales:
[Quote] H: 11 L: 25 T: 2833 B: 2830
H: 11 L: 26 T: 2833 B: 2831
H: 11 L: 24 T: 2833 B: 2829
H: 11 L: 31 T: 2833 B: 2836
H: 11 L: 27 T: 2833 B: 2832
H: 11 L: 29 T: 2833 B: 2834
[/ Quote]
Y esto es resultado de condensador real 10nF
[Quote] H: 724 L: 233 T: 439752 B: 439853
H: 724 L: 182 T: 439754 B: 439802
H: 724 L: 13 T: 439750 B: 439633
H: 724 L: 151 T: 439751 B: 439771
H: 724 L: 125 T: 439751 B: 439745
H: 724 L: 207 T: 439753 B: 439827
H: 724 L: 166 T: 439754 B: 439786
H: 724 L: 113 T: 439753 B: 439733
H: 724 L: 163 T: 439754 B: 439783
H: 724 L: 4 T: 439750 B: 439624
H: 724 L: 112 T: 439750 B: 439732
H: 724 L: 147 T: 439750 B: 439767 [/ quote]
Mi circuito cuenta con 2131 cuando no hay ningún condensador conectado.
Puedo usar esta fórmula para calcular el valor del condensador:
Cap = (T-2131) / ClockFreq / Resistor_value
9.94nF = (439,750-2131) / (20 Mhz / 4) / 8.8Mohm <----- 10nF
15.9pF = (2.833-2131) / (20 Mhz / 4) / 8.8Mohm <----- 22pF
8.9nF = (396.627-2131) / (20 Mhz / 4) / 8.8Mohm <----- el sensor
16/07/2011 #62
Avatar de seaarg
FFT dijo: Ver Mensaje
Your test sensors sounds good. As i said before, mine was about 1.2 meters length x 4cm height x 5 mm dielectric tickness.
As i understood, you used plastic as dielectric. Have you tried with something less solid, such as styrofoam? (or even air, but that's not much feasible). My sensor's dielectric is styrofoam, not tested with other dielectrics (except air: 1 single aluminium strip and car GND as the other capacitor terminal, however not got good results this way)
You did understood wrong: I try to say that perhaps your capmeter isnt sensible enough. It should measure values between 1pF and 47pF. Most commercial capmeters i know measures from 100pF.
It happened to me. I dont recall exactly but i think that happened with a sensor. Then i built another one and worked.
I dont know those formulas, but if your math is ok, then the problem is that your sensor have too much capacitance (9nF). Let's think this for a moment: If you want to make a 4mhz oscillator with a crystal, the crystal-to-ground capacitors should be about 47pF. If you put a 9nF capacitor you're too far away. (that's why i suggest make a less solid dielectric, i think capacitance will decrease)
You should get a timer counter value of about 1500, according to this (your math): 15.9pF = (2833-2131)/(20Mhz/4)/8.8Mohm <----- 22pF
This value will say that your sensor is about 12pF (wich is the correct one for a 20mhz crystal).
I suggest you try with a 4mhz crystal, a 47pF cap in one side and an about 47pF sensor on the output of the inverter.
Sadly there's no much i can help you about it, but i hope you manage to get this crap working
PS: Maybe i was just very lucky. I had bad results such as the ones you're having but finally after several approaches it basically worked. I dont know THAT much to be able to explain how it works in formulas, etc. That's why i directed you to capaciflector patents and papers.
----------------------- ESPAÑOL ---------------------------------------------------
Hice el sensor con 2 tiras de aluminio y como sandwich en el medio una tira de plastico. Intente con 4mm, 5mm, 7mm, 0.5mm distancias de dielectrico entre las 2 tiras de aluminio. Hay algun problema con esto?
Intente tambien con tiras de 5cm y 2.5 cm de alto. 1.2 metros y 2.4 metros de largo
Tus sensores de prueba suenan bien. Como dije anteriormente, el mio es de aprox 1.2 metros de largo x 4cm de alto x 5 mm de grosor de dielectrico.
Segun entendi, usaste plastico como dielectrico. ¿Probaste con algo menos solido, como telgopor? (incluso aire aunque no es muy practicable)
Entendi mal? decis que no puedo obtener buenos resultados usando medidores de capacitancia?
Entendiste mal: Lo que trate de decir es que quizas tu capmeter no es lo suficientemente sensible. Deberia poder medir valores entre 1pF y 47pF. La mayoria de los comerciales que vi miden desde 100pF.
Y aqui me canse de traducir. Si a alguien le interesa lo que se esta diciendo por favor pidanlo y lo termino de traducir.
16/07/2011 #63
seaarg dijo: Ver Mensaje
Yes, my second sensor had 5mm styrofoam dielectric and it was 1.2 m long, 5cm wide. I'll make another one similar, now.
I made my own CapMeter using measuring the charging time of capacitor. Not a commercial meter, I want to use this as the brain of parking sensor. Doesn't matter do I measure frequency or I get directly the capacitor's value. If the capacitor changes its capacitance, I'll see this using RC time measurements too.
This doesn't matter if I know how many nanofarads is my sensor at the begining. I can understand when someone is near to it from changings of the capacitance. Got it?
You understood wrong this time. These are real capacitors which proof my capmeter works good. The 9nF one is my sensor only. The other values are some real capacitors, they aren't sensors.
I'm good with formulas but I couldn't get it working
But the fact is when the plates are very near (dielectric thickness) to each other, the capacitance value becomes bigger (like 9nF). You have 4mm thickness because of this you can measure ~47pF value.
I'm gonna keep trying.. Suggestions are welcome.
? ¿Has probado con algo menos sólido, tales como espuma de poliestireno
Sí, mi segundo sensor dieléctrico de espuma de poliestireno había 5 mm y de 1,2 m de largo, 5 cm de ancho. Voy a hacer otra similar, ahora.
Hiciste mal entendido: yo trato de decir que tal vez su capmeter no es lo suficientemente sensible. Se deben medir los valores entre 1pF y 47pF. Capmeters más comercial que sé las medidas de 100pF.
Hice mi propia CapMeter con la medición del tiempo de carga del condensador. No es un medidor comercial, quiero utilizar esto como el cerebro de los sensores de aparcamiento. No importa qué medir la frecuencia o que reciba directamente el valor del condensador. Si el condensador cambia su capacidad, voy a ver esto con las mediciones de tiempo RC también.
Yo no sé esas fórmulas, pero si las matemáticas está bien, entonces el problema es que el sensor tiene demasiada capacitancia (9NF). Pensemos por un momento: Si usted desea hacer un oscilador de 4 MHz con un cristal, el cristal de condensadores a tierra debe ser de 47pF. Si se pone un condensador 9NF está demasiado lejos. (Es por eso que le sugiero hacer un dieléctrico menos sólido, creo que la capacitancia disminuye)
Esto no importa si saben pocos nanofaradios muchos es mi sensor desde el principio. Puedo entender cuando alguien está cerca de él a partir de changings de la capacidad. ¿Lo tienes?
Usted debe obtener un valor de temporizador contador de alrededor de 1500, de acuerdo con esto (la matemática): 15.9pF = (2833 a 2131) / (20 Mhz / 4) / 8.8Mohm <----- 22pF
Has entendido mal esta vez. Estos son los condensadores reales que prueba mi capmeter buenas obras. El 9NF es mi único sensor. Los otros valores son algunos condensadores reales, no son los sensores.
Soy bueno con las fórmulas, pero no pude hacerlo funcionar: cry:
Pero el hecho es que las placas están muy cerca (espesor dieléctrico) el uno al otro, el valor de capacidad se hace más grande (como 9NF). Usted tiene 4 mm de espesor a causa de esto se puede medir el valor ~ 47pF.
Voy a seguir intentando .. Sugerencias son bienvenidas.
18/07/2011 #64
Hi again,
I've tried to make the same sensor like yours but doesn't work again.
I decided that your aluminium strip is different. Mine is just one side is aluminium and the other side is sticky paper. Separate it by pulling it to stick somewhere, its used for temperature isolation of mattresses of wooden floors (on ground).
Could you give me a link, a photo of the strip you are using?
Sincerely.
Hola de nuevo,
He tratado de hacer el mismo sensor como la suya, pero no funciona de nuevo.
Decidí que la tira de aluminio es diferente. La mía es sólo una parte es de aluminio y el otro es el papel pegajoso. Separarla tirando de ella para pegar en algún lugar, su temperatura utilizado para el aislamiento de los colchones de los suelos de madera (en el suelo).
¿Podría darme un enlace, una foto de la banda que está utilizando?
Atentamente.
18/07/2011 #65
Avatar de seaarg
Here you have 2 zip files with photos.
Aporte: Estacionamiento asistido (parking aid) NO ultrasonido
As you described your strip, it's similar to mine. It's used for isolation of pvc plumbing.
I ask again... have you tried using a 40106 as inverter gate for the oscillator? Mine worked with it.
Aqui estan las fotos
Pregunto de nuevo: Intentaste usar un 40106 para el oscilador? el mio funciono con ese.
19/07/2011 #66
I've found the problem!!!
This is the translation of your words in the link you wrote:
SENSOR: consists of 3 self-adhesive aluminum strip used to cover PVC pipe, separated by tergopol, which is used in the trays of cold cuts. This acts dielectric and have a espresor approx. 5 mm.
a) - The strip is wider GND
b) - In the middle is a strip slightly narrower (8mm lower), SHIELD
c) - At the other end, a strip slightly narrower (8mm lower), SENSOR
I don't have any shield part here !!! I have only 2 plates, not the 3th one and you haven't said me about this.
I'll try with 5 cm wide 1.5 meters long strip as GROUND (C-),
4 cm wide 1.5 meters long strip as SHIELD,
3 cm wide 1.5 meters long strip as SENSOR (C+)
It will consist of 3 layers strips. Here is the problem.
19/07/2011 #67
Have you read this?? http://www-cdr.stanford.edu/touch/pr...ciflector.html
It explains clearly that there is 3 plates.
And you are missing the the lengths of the layers. The GND strip has to be the largest, the shield has to be 8mm less than the GND strip, and the Sensor strip 8mm less than the Shield. Good luck!!
Seaarg, te hago una consulta. Dijiste que el sensor lo armaste con cintas de aluminio separadas por tergopol. Pero como uniste todo esto?? Lo pegaste, o solo estan apoyadas unas con otras y atadas con cinta??
Aprovecho para felicitarte por tu proyecto y agradecerte por compartirlo. Estuve buscando muchisimo en internet y casi no existe informacion en español sobre este tema. Asiq mil gracias por facilitarnos esta informacion q para mi vale oro! Saludos!
19/07/2011 #68
Avatar de seaarg
Stop right there. Do not build it yet
I pointed to that post since the images you asked about is there. But the 3 stripes sensor is for another circuit. (the one with two operationals: ie, capaciflector).
This circuit is not very stable. Although it works.
Crystal Oscillator circuit is more stable and uses 2 strips.
Para ahi, no lo construyas aun
Te apunte a ese post porque las imagenes que pediste estan ahi. Pero el sensor de 3 tiras es para otro circuito (el que tiene 2 operacionales, o sea, capaciflector)
Este circuito no es muy estable, aunque funciona.
El de oscilador a cristal es mas estable y usa 2 tiras.
zspikes dijo: Ver Mensaje
3 plates is the capaciflector project: On previous posts i posted the circuit. Dont mix up with the crystal oscillator project, in wich the F gets affected by sensor's capacitance. Those are 2 different projects pointing to the same objetive. Please check out the other diagrams to see the difference.
Me alegro que la info te sirva! este proyecto es un dolor de cabeza pero me ha dado muchas satisfacciones y aprendizaje. El sensor son tiras de aluminio, correcto. Estas tiras de aluminio (cobertores para protejer caño de pvc de la intemperie) tienen un lado adhesivo. Se pegaron al tergopol y se ato con cinta de papel, que usan los pintores.
El proyecto con "shield" funciona muy bien, pero pierde estabilidad ante cambios de presion / temperatura y/o humedad. (logico, el "capacitor" cambia su capacitancia).
Con un oscilador a cristal consegui mas estabilidad pero estoy pensando si me salio de suerte o que, porque el amigo de finlandia no puede reproducirlo.
19/07/2011 #69
Hi again,
I've tried with 3 strips and it worked. Not so stable but makes sense.
I don't know about temp, humidity or pressure problems, but I couldn't make a working model with 2 strips really. I use 2 the same size, parallel alu strips with tergopol dielectric. I've tried it using crystal too. But I don't have a 40106, I'm gonna buy it tomorrow, we will see the difference.
Sensor with 3 strips is not recommended, right?
Also I want to ask you, what do you do with the varicap circuit there in the 2nd version?
Best regards
Hola de nuevo,
He probado con 3 tiras y funcionó. No es tan estable, pero tiene sentido.
Yo no sé acerca de los problemas temporales, humedad o presión, pero yo no podría hacer un modelo de trabajo con dos tiras de verdad. Yo uso dos del mismo tamaño, en paralelo tiras de aluminio con dieléctrico de tergopol. He intentado que el uso de cristal también. Pero no tengo un 40106, lo voy a comprar mañana, vamos a ver la diferencia.
Sensor de 3 bandas, no se recomienda, ¿verdad?
También me gustaría preguntarle, ¿qué hacer con el circuito varicap hay en la versión de segunda?
Saludos cordiales
19/07/2011 #70
Avatar de seaarg
Hi again,
Best regards
Im glad it worked but... where did you connected the middle strip (shield)? If not connected, perhaps what you're doing is lowering the capacitance as i said before. Confirm this (it's my own doubt)
The pressure & humidity problems happened to me on non-crystal versions.
Sensor with 3 strips it's recommended by the NASA inventor of capaciflector. I just couldnt make it stable.
About your question: the varicap version was an attempt to make something that self calibrates on startup (to avoid capacitance changes from one day to another due humidity, etc) It's a complicated circuit and worked, but finally the crystal oscillator one was more stable and easy. (or maybe i was just lucky)
Me alegra que te funciono pero... donde conectaste la tira del medio (shield)? Si no la conectaste, tal vez lo que estas haciendo es bajar la capacitancia como dije antes. Confirma esto (es mi duda propia)
Los problemas de presion y humedad me ocurrieron en las versiones no-cristal.
El sensor con 3 tiras es recomendado por el inventor del capaciflector en la nasa. Simplemente yo no puede hacerlo estable.
Acerca de tu pregunta: la version con varicap fue un intento de hacer algo que se auto calibrase al inicio. Es un circuito mas complicado y funciona pero finalmente el oscilador con cristal fue mas estable y facil. (o tal vez solo tuve suerte).
19/07/2011 #71
I connected it to output of a follower op-amp. I made this schema for test.
Your crystal osc version uses 2 strips only, OK but I couldn't get it working Tomorrow I'll try it using a 40106, but I think the sensor doesn't work for me. The oscillator is OK I think.
Could you give me more details about the system, schematic or the sensor, if you haven't said to me. You know, I made several sensors but no chance...
Best regards.
me alegro que funcionó, pero ... ¿de dónde ha conectado la franja del centro (de protección)? Si no está conectado, tal vez lo que estamos haciendo es reducir la capacidad como he dicho antes. Confirmar esto (que es mi propia duda)
Lo conecta a la salida de un seguidor del amplificador operacional. Hice este esquema para la prueba.
[IMG] http://bdml.stanford.edu/DML/previou...or/rel_osc.gif [/ IMG]
Su versión osc cristal utiliza dos bandas solamente, bien, pero no pude hacerlo funcionar Mañana voy a tratar utilizando un 40.106, pero creo que el sensor no funciona para mí. El oscilador está bien, creo.
¿Me podría dar más detalles sobre el sistema, esquema o el sensor, si no me han dicho. Ya sabes, he hecho varios sensores pero el azar no ...
Saludos cordiales.
19/07/2011 #72
Avatar de seaarg
That's ok. That's a real capaciflector scheme. I found it unstable to wheather variations, but give it a try.
What op-amp did you use for this test?
I already give all details i can about the sensor. Do you have some specific question in mind? (already give you schematics of the crystal oscillator i used too)
Eso esta bien, es un esquematico de un capaciflector. Lo encontre inestable bajo variaciones del clima pero intentalo.
Que operacional usaste para este test?
Ya te di los detalles que pude sobre el sensor. Tenes alguna pregunta especifica en mente? (Tambien te di el esquematico del oscilador a cristal)
21/07/2011 #73
I had LMC6484 and used it for test. I'm still trying here the sensor but no changings with temperature. Everyday it says:
74kHz - near,
65kHz - mid,
59kHz - away.
Actually I don't have a question, already I know that you answered to my all questions very good.
Didn't understand what is the difference between yours and mines...
Maybe your sensor's plate's/strip's widths are not equal? For example the GND strip is 5cm, capacitor+ strip is 4cm?
Also I've tried using 40106 the crystal schematic with my previous hand-made sensors, but didn't work.
Best regards and thanks so much for your answers again.
¿Qué amplificador operacional se utiliza para esta prueba?
Tuve LMC6484 y lo utilizó para la prueba. Todavía estoy tratando aquí el sensor, pero no changings con la temperatura. Todos los días se dice:
74kHz - cerca,
65kHz - medio,
59kHz - de distancia.
¿Tiene alguna pregunta específica en mente?
En realidad no tengo una pregunta, ya sé que usted contestó a mis preguntas muy buenas.
No entiendo cuál es la diferencia entre el suyo y las minas ...
Tal vez el sensor de la placa de / ancho de banda no son iguales? Por ejemplo, la tira de GND es de 5 cm, el condensador + tira es de 4 cm?
También he intentado usar el esquema 40106 cristal con mis anteriores hechos a mano, los sensores, pero no funcionó.
Un saludo y muchas gracias por sus respuestas de nuevo
21/07/2011 #74
Avatar de seaarg
Congratulations! im glad it worked. Keep testing and let us know the results.
In my two strips sensor both strips are equal.
Now you can program a microcontroller as frequencymeter and make beeps according to distance.
I would like if, when finished, you can publish your schematics here so everybody can build your version too.
Felicitaciones, me alegra que te funciono. Segui haciendo pruebas y comentanos los resultados.
En mi sensor, ambas tiras son iguales.
Ahora podes programar un microcontrolador como un frecuencimetro y hacer beeps de acuerdo a la distancia.
Me gustaria si, cuando lo terminas, podrias publicar tus esquematicos aqui para que todos puedan hacer tu version tambien.
21/07/2011 #75
Thanks, but I'll make your second version project, if I decide to use 3 stripped sensor.
You said that the sensor is affected by temp humidity etc.. It mixed my mind really, because I couldn't tested it in humidity. Do you use it still and what are the problems exactly?
Today I'll try another 3 stripped sensor with bigger capacitance (10nF).
And I don't know how to make it like professionals to use on my car. Now my sensor is so basic and easily can be damaged. I don't want to change sensors periodically.
BR.
Gracias, pero voy a hacer el proyecto de la segunda versión, si decido usar 3 sensores despojado.
Usted ha dicho que el sensor se ve afectado por la humedad, etc temp. Se mezclan mi mente realmente, porque yo no lo podía probar en la humedad. ¿Utiliza usted todavía y cuáles son los problemas exactamente?
Hoy voy a probar con otro sensor 3 despojado con mayor capacidad (10nF).
Y no sé cómo hacer que, como profesionales, para usarlo en mi coche. Ahora mi sensor es tan básica y sencilla puede ser dañado. Yo no quiero cambiar los sensores de forma periódica.
BR.
21/07/2011 #76
Avatar de seaarg
When i installed it on the car, from one morning to another weather conditions changed. The prototipe i built worked first day, then next morning alerted about "min-distance" even when no object is near. The was due capacitance change on different weather conditions.
Perhaps this can be corrected by software, making some sort of turn-on calibration.
I found the crystal based one more stable, but you should try what fit best for you.
How do i installed? look at the pictures. Attached to the read of the bumper and covered with duct tape.
Cuando lo instale en el auto, de una mañana a otra las condiciones de tiempo cambiaron. El prototipo que construi funciono el primer dia, entonces en la mañana siguiente alerto sobre distancia minima incluso cuando no habia objeto cerca. Esto fue debido a un cambio de la capacitancia en diferentes condiciones de tiempo.
Tal vez esto pueda ser corregido por software, haciendo una especie de calibracion al encendido.
Encontre que el basado en cristal es mas estable, pero deberias probar que te va mejor.
Como lo instale? mira las imagenes. Lo pegue a la parte trasera del paragolpes y lo cubri con cinta adhesiva.
21/07/2011 #77
Why perhaps? Are not you using it still?
21/07/2011 #78
Avatar de seaarg
As i said before. I leave this project on hold due lack of time.
The 3 strip version was abandoned since i couldnt make it stable. I was working on the crystal oscillator one and had to leave it on hold due lack of time, even when i was having some sort of good results.
Porque tal vez? No lo estas usando aun?
Como dije antes, deje este proyecto en pausa debido a falta de tiempo.
La version de 3 tiras fue abandonada porque no la pude hacer estable. Estaba trabajando en la version con oscilador a cristal y tuve que dejarla en pausa debido a falta de tiempo, incluso mientras obtenia buenos resultados.
21/07/2011 #79
Hola de nuevo!!
Me lei casi todo el hilo y no me di cuenta que habian dos sensores o metodos en cuestion jeje. Yo estoy probando con el capaciflector. Por el momento no me molesta que hayan variaciones debidas al clima. Solo quiero sensar la presencia de algo a una distancia razonable.
Me acabo de armar un mini capaciflector con bandejas de telgopor y papel aluminio, todo pegado con cola. El oscilador de relajación lo hice con un TLC084CN (pero tambien hice pruebas con un LM324N) como muestra esta figura
Pero no obtuve muy buenos resultados. Para empezar la distancia de sensado es muy pequeña, de unos 5cm. Ademas la onda generada por el oscilador no se ve muy "linda", y no alcanza un maximo de 5V que es con lo que estoy alimentando el integrado. Por ultimo, el buffer tiene un offset que hace que la tension del shield no sea exactamente la misma que la del sensor.
Que consejos podrias darme para mejorar mi capaciflector? Por lo pronto pienso armar uno un poco mas grande (para aumentar la capacidad), y tal vez con forma de antena parabolica, ya que lei por ahi que esto ayuda a concentrar las lineas de campo.
Dejo un video de la primera prueba que hice.
Saludos y gracias!!
21/07/2011 #80
When you have time, you should work on it
Don't you know how does it work the device of www.parkingdynamics.co.uk ? I remember that you said, you helped them, right?
Cuando tiene tiempo, debe trabajar en ello
¿No sabes cómo funciona el dispositivo de www.parkingdynamics.co.uk? Recuerdo que usted dijo, que les ayudó, ¿no?
