24/04/2012 #1861
Avatar de reyvilla
Fijate este codigo:
@ device PIC16F72 , xt_osc, wdt_off, pwrt_on, protect_oN
Include "MODEDEFS.BAS"          ' Include Shiftin/out modes
DEFINE DEBUG_REG PORTC
DEFINE DEBUGIN_REG PORTC
DEFINE DEBUGIN_BIT 7
DEFINE DEBUG_BIT 6
DEFINE DEBUG_MODE 0 		' 1 = Inverted (w/o max) , 0 = true (with max)
DEFINE DEBUGIN_MODE 0
DEFINE DEBUG_BAUD 9600
' HARDWARE DEFINES
' Define LCD pins
Define Lcd_dreg Porta
Define Lcd_dbit 0
Define Lcd_rsreg Porta
Define Lcd_rsbit 4
Define Lcd_ereg Porta
Define Lcd_ebit 5
Define Osc 4                   ' We're using a 4 MHz oscillator
    Adcon1 = 7                     ' Set PORTA DIGITAL
    OPTION_REG.7 = 0               ' DISABLE INTERNAL PULLUPS
    Trisa = %00000000              ' SETS ALL PORTA PINS TO OUTPUT
    Trisb = %00000000              ' ALL OUTPUT
    Trisc = %00001011              ' 6 Pins - LCD and 2 Pins RF Module
RELAY1      VAR PORTB.0     ' RELAY 1
RELAY2      VAR PORTB.1     ' RELAY 2
RELAY3      VAR PORTB.2     ' RELAY 3
RELAY4      VAR PORTB.3     ' RELAY 4
RELAY5      VAR PORTB.4     ' RELAY 5
RELAY6      VAR PORTB.5     ' RELAY 6
RELAY7      VAR PORTB.6     ' RELAY 7
RELAY8      VAR PORTB.7     ' RELAY 8
LED         VAR PORTC.4     ' LED (SINK)
RELAY       VAR BYTE        ' RELAY NUMBER
MYDATA      VAR BYTE        ' GENERAL PURPOSE DATA VARIABLE
INDEX       VAR BYTE        ' SMS INDEX NUMBER
I           VAR BYTE        ' GENERAL VARIABLE
Pause 500                   ' Wait .5 second
B2400   Con 16780           ' Inverted 2400 baud for SERIN2
    HIGH LED
    PORTB = 0		    ' TURN OFF ALL RELAYS
    Lcdout $fe, 1,   "SMS CONTROL"  ' Send to LCD
    Lcdout $fe, $C0, "SMS TEST C5"  ' Second Line
    PAUSE 2000
    ' GOSUB OLD
LOOP:
    Lcdout $fe, 1,   "WAITING 4 SMS"  ' Send to LCD
    DEBUGIN [WAIT("+CMTI:"), SKIP 7 , DEC INDEX]
    Lcdout $fe, $C0, "SMS RX: " , DEC INDEX ' Second Line
    PAUSE 5000
    Lcdout $fe, 1,   "READ MSG "  ' Send to LCD
    DEBUG "AT+CMGR=", DEC INDEX, 13
    'DEBUGIN [WAIT("+CMGR:"), SKIP 51 , DEC MYDATA]
    DEBUGIN [WAIT("+CMGR:"), SKIP 53 , DEC MYDATA]
    Lcdout $fe, 1,   "MYDATA: " , DEC MYDATA   ' Send to LCD
    PAUSE 3000
    SELECT CASE MYDATA
    CASE 20
        Lcdout $fe, 1,   "RELAY 2"
        Lcdout $fe, $C0, "ON"
    CASE 21
        Lcdout $fe, $C0, "OFF"
    CASE 10
        Lcdout $fe, 1,   "RELAY 1"
    CASE 11
    CASE 30
        Lcdout $fe, 1,   "RELAY 3"
    CASE 31
    CASE 40
        Lcdout $fe, 1,   "RELAY 4"
    CASE 41
    END SELECT
    PAUSE 3000
    Lcdout $fe, 1,   "DELETE SMS MSG"
    Lcdout $fe, $C0, "#:" , DEC INDEX
    DEBUG "AT+CMGD=", DEC INDEX, 13
    PAUSE 3000
GOTO LOOP
END
Lo saque de este Link: http://www.picbasic.co.uk/forum/showthread.php?t=3765
Según tengo entendido es para el control de relays a traves de un SMS, por eso mi duda al respecto con esos comandos DEBUG y DEBUGIN
Quería ver si los ponía a prueba pero aun no se como ya que no tengo un sistema para la recepción de SMS, que modulo uso o que materiales aparte del pic necesito?
24/04/2012 #1862
creo que ya voy entendiendo...
no solo es con los mensajes SMS es una comunicacion serial asincrona normalita y corriente...
la ventaja es que supuestamente utiliza menos codigo... pero suponiendo que utiliza menos codigo algo debe estar sacrificando no?, como algun cequeo de recepcion o envio.... intentare hacer una prueba.. o si gustas tu tambien hazla como si fuera el Serin y serout....
con respecto a como mandar mensajes por SMS, solo necesitas un telefono y tener los codigos AT del telefono, modem o modulo... y conectas como si conectaras pic a pic por usart...
lo dificil es encontrar un telefono que se conecte con el puerto serial porque ya la mayoria son por bluetooth y USB, yo lo hice con un Nokia 3100 y la PC el problema fue que nunca encontre los codigos del Nokia, me aburrio y lo deje.... ahora lo interesante es que venden modulos Bluetooth en 20usd aprox y puedes comunicar cualquier pic con cualquier telefono que tenga bluetooth..
24/04/2012 #1863
Amigo ludbeck, estoy por utilizar un modulo gsm marca ZTE ME 3000, que ya viene con el puerto serial, esta por llegarme en los proximos dias de esta semana.
Con respecto a la simulacion en proteus, no la tengo pues yo soy mas de implementarlo directamente en el protoboard
reyvilla dijo: Ver Mensaje
Fijate este codigo:
DEFINE DEBUG_BIT 6
' HARDWARE DEFINES
' Define LCD pins
Define Lcd_dbit 0
Define Lcd_rsbit 4
Define Lcd_ebit 5
    HIGH LED
    PAUSE 2000
    ' GOSUB OLD
LOOP:
    PAUSE 5000
    PAUSE 3000
    SELECT CASE MYDATA
    CASE 20
    CASE 21
    CASE 10
    CASE 11
    CASE 30
    CASE 31
    CASE 40
    CASE 41
    END SELECT
    PAUSE 3000
    PAUSE 3000
GOTO LOOP
END
Amigo reyvilla tu sabes para que pone skip 53, osea yo se que skip es saltar un numero determinado de caracteres, pero porque? especificamente salta 53 en este ejemplo?
24/04/2012 #1864
Avatar de reyvilla
Oye la verdad no se es primera vez al igual que lubeck que le presto atencion a estos comandos la verdad nunca los he usado, pero debe referirse a una cadena de caracteres que esta antes del mensaje, en ese caso para ese país y empresa de telefonica en aprticular la verdad que no estoy seguro
24/04/2012 #1865
Porque el pic va a esperar a que lleguen los caracteres +CMGR: y despues discrimina 53 caracteres, y despues recibe un byte y lo guarda en mydata que es lo que necesita el que lo programo...
Ejemplo:
el modem manda al pic.:
"+CMGR:Hola estoy mandando un dato para que prenda el Relay 1"
esto es el dato que espera para proceder..."+CMGR:"
estos son 53 caracteres que no sirven..."Hola estoy mandando un dato para que prenda el Relay "
esto es el relay que guarda en mydata..."1"
Rey... ya echaste a andar ese ejemplo???? yo no puedo
YAAAAAAAAAAAAAA PUUUUDEEEEE
esta bien fregon ese metodo para comunicacion serial... muy bueno... muy bueno...
24/04/2012 #1866
Avatar de reyvilla
No aun no me he puesto de verdad, y lo hiciste con el código que te coloque con el mismo pic ?
De que se trata, yo no pude deducir las conexión ya que tiene unas definiciones que no entendí muy bien tienes un esquema para armarlo aquí y ver de que se trata?
como funciona ?
24/04/2012 #1867
mira lasimulacion, la puse con el 877A pero puede ser cualquiera porque es por software... y use el virtualterminal...
en el virtual pones "+CMTI:12345678" sin las comillas y enter despues pasa al siguiente paso...
si te fijas discrimina el 1234567 y pone el 8....
Tipo de Archivo: rar Debug.rar (70,9 KB (Kilobytes), 102 visitas)
24/04/2012 #1868
Avatar de reyvilla
Si ya vi esta bien bueno, eso facilita la cosa ya que no hay que inventar mucho ya con estoy tendrías lo que quieres, cambiando un poco el código claro esta, ahora voy hacer mas pruebas a ver que se me ocurre y a ver si aprendo mas de este comando. Por cierto lubeck si te fijaste en los DEFINE, a que se refiere cada uno o tienes alguna idea de que pueda ser?
Edit: Ya, que torpe, es igual a las definiciones de un ldc, la diferencia es que aqui defines cual es TX y RX, por otro lado, puedes tener dos modos uno de entrada y otro para salida, muy interesante esto ya que no tiene esas limitaciones como el serin y el serout
24/04/2012 #1869
Estos?
si te refieres a esos es algo parecido a como se usa el LCD...
DEFINE DEBUG_REG PORTC 'Este y....
DEFINE DEBUG_BIT 6         ' este es para decir que la salida del Debug (Salida Serial) seria por el puerto RC6
DEFINE DEBUGIN_REG PORTC  'Este y....
DEFINE DEBUGIN_BIT 7     ' este es para decir que la entrada del DebugIn (entrada serial) seria por el puerto RC7
DEFINE DEBUGIN_MODE 0  'estos son el modo invertido si no se usa el max232 y no invertido si  se usa
DEFINE DEBUG_BAUD 9600  'la velocidad en baudios
24/04/2012 #1870
Avatar de reyvilla
Exacto, ahora DEBUG es salida y DEBUGIN es la entrada, osea puedes tener dos modos diferentes con los mismo baud de velocidad, digamos entrada normal o verdadera, y salida invertida o falsa.
24/04/2012 #1871
sip... es muy parecido al SEROUT (debug) y SERIN (DEBUGIN) la diferencia es que con el serin serout cada que los utilizas especificas el pin y la velocidad, y aca lo defines desde el principio del programa....
otra ventaja es eso del Wait, SKip,WaitSTR etc, que no se si recuerdas que mi amigo maxtorcampos solicitaba algo asi.... esto le hubiera servido de lujo...
bueno... ni hablar... hasta ahora lo descubrimos...
24/04/2012 #1872
Amigos, partiendo de la muy buena explicacion de ludbeck referente al comando SKIP, pongo a consideracion el siguiente codigo, el cual gracias espera (WAIT) a la palabra "Activar", salta (SKIP) 2 caracteres y despues de establecer la condicionante con el IF-THEN que si la variable tipo byte (B0) sea "1", active el rele, bueno pues el problema esque no activa el rele, pero lo curioso esque si pasa a la siguiente linea, que para el caso es el inicio de la subrutina ENVIAR:, que es simplemente la confirmacion de la activacion del rele mediante comandos AT. Esto lo probe con el terminal del microcode y evidencie lo antes explicado.
Entonces reitero el problema el cual es que el rele no se esta activando, por favor revisenle el codigo y digame cual es el error que estoy cometiendo y la posible solucion.
Muchas gracias
include "modedefs.bas"
define OSC 4
CMCON=7
REL1 VAR PORTA.0
RX VAR PORTB.0
TX VAR PORTB.1
B0 VAR BYTE
INICIO:
    SerIn2 TX,16468,[WAIT("Activar"),SKIP 2,DEC B0]
    IF B0="1" THEN
    HIGH REL1
    ENDIF
ENVIAR:
    PAUSE 10000
    serout2 Rx,16468,["AT+CMGF=1",13]
    PAUSE 50
    serout2 Rx,16468,["AT+CMGS=",34,"092661649",34,13]
    PAUSE 50
    SEROUT2 Rx,16468,["R1 activado",26]
    pause 50
GOTO INICIO
24/04/2012 #1873
el serin2 y el serout2 es la combinacion del uso del Serin serout y del debug debugin...
ya aprendi algo nuevo hoy....
amigo pull1988, te recomiendo muy ampliamente que utilices el proteus.... o que pongas el esquema... honestamente a mi me da flojera siquiera tratar de entender que rayos quieres que haga.. con la simulacion ya te estuviera intentando ayudar...
24/04/2012 #1874
jajajajaja ok amigo ludbeck voy a poner un esquema enseguida lo hago y si el serin2 y el serout2 son muy completos y me han ayudado a resolver muchos problemas de comunicacion serial, sobretodo el WAIT
24/04/2012 #1875
Avatar de reyvilla
Ya somos dos lubeck, concuerdo contigo hoy aprendimos algo nuevo, y conrespecto al esquema amigo Pull1988 te iba a decir algo similar, ya que no contamos con el circuito que tu tienes para hacer las pruebas y no hay mejor manera que un esquema en proteus para probarlo.
24/04/2012 #1876
Bueno amigos ahi lo tienen el esquema en proteus, disculpen cualqueir error, puesto q yo no utilizo mucho el simulador, prefiero hacerlo en el protoboard directamente. Les explico brevemente los pines del PIC:
el puerto A.0 es la salida al rele mediante el transistor 2N2222.
los purtos B.0 y B.1 son RX y TX respectivamente, del cable serial.
los puertos A.6 y A.7 son para el Oscilador de 4MHz, no lo puse puesto q no lo encontré, pido disculpas por mi ignorancia para con el simulador.
Esos son los puertos q utilizo hasta el momento prentendo utilizar los puertos desde el A.0 hasta el A.5 para las salidas a los reles.
Cualquier inquietud estaré atento para esclarecerselas.
Muchas gracias
Tipo de Archivo: rar Esquema.rar (11,6 KB (Kilobytes), 90 visitas)
24/04/2012 #1877
Avatar de reyvilla
Amigo Pull1988, unas recomendaciones si quieres tomarlas, si bien esta demostrado, hablo por mi propia experiencia, las simulaciones en proteus son yo diria un mas de un 70% confiables, eso quiere decir que si corre en el proteus tienes un 70% si no mas de probabilidades de que funcione en la practica real, aparte del ahorro de tiempo y coste, si conectas algo mal o configuras o programas mal en el proteus, fácil lo corriges de manera rápida y ya, en cambio en la practica real puede costarte mucho tiempo aparte de dinero, por otro lado, en la programación para garantizar un mejor funcionamiento, las configuraciones de los fuses y entradas y salidas del microcontrolador, ya que de no hacerlo puede causarte mas que un dolor de cabeza, lo digo por que me paso mucho. Ya terminando con esto, revise y verifique tu código, lo simule y corregí. Solo falta declaración de fuses y entradas y salidas, y en la parte de serin2, tu estas transformando en dato en decimal por lo tanto debes tratarlo como decimal y no como dato ascii o AT. Otra cosa desde hace un tiempo yo para estar seguro y diferencias que es variable y que es un pin, utilizo el comando symbol para renombrar los pines, esto es opcional.
El codigo si funciona solo falta lo que te dije revisa y me avisas.
24/04/2012 #1878
amigo reyvilla muchas gracias x tu respuesta, sabes q en lo personal no utilizo fuses, bueno de hecho asi me enseñaron en la universidad y me he acostumbrado a eso, pero tal ves tu me puedes decir q fuses me hacen falta para ponerlos; con respecto a la parte del seri2 en cual tu mencionas que lo utlizo como decimal, pues efectivamente tienes razon, pero en ese caso que podria poner?.
Muchas gracias por tus sugerencias y consejos, los tendré muy presentes, sino es mucha molestia me gustaria que pongas el codigo para ver cuales fueron mis errores y que me falta.
24/04/2012 #1879
A mi no me funciona
a que velocidad se supone que esta o lo quieres configurar?
24/04/2012 #1880
la velocidad es 9600 baudios con logica invertida.
16468=9600
