14/11/2009 #1
ayuda en mplab
estoy empesando y no se porqu m e sale estos errores
Clean: Deleting intermediary and output files.
Clean: Done.
Executing: "C:\Archivos de programa\Microchip\MPASM Suite\MPASMWIN.exe" /q /p16F628A "TIMER 500ms.asm" /l"TIMER 500ms.lst" /e"TIMER 500ms.err" /d__DEBUG=1
Warning[207] D:\WILLIAM\CLASES DE PIC\REVISANDO EJERCICIOS\EJERCICIO 2\TIMER 500MS.ASM 20 : Found label after column 1. (INICIO)
Message[302] D:\WILLIAM\CLASES DE PIC\REVISANDO EJERCICIOS\EJERCICIO 2\TIMER 500MS.ASM 21 : Register in operand not in bank 0. Ensure that bank bits are correct.
Warning[207] D:\WILLIAM\CLASES DE PIC\REVISANDO EJERCICIOS\EJERCICIO 2\TIMER 500MS.ASM 23 : Found label after column 1. (LAZO)
Warning[207] D:\WILLIAM\CLASES DE PIC\REVISANDO EJERCICIOS\EJERCICIO 2\TIMER 500MS.ASM 30 : Found label after column 1. (TIMER_500ms)
Warning[207] D:\WILLIAM\CLASES DE PIC\REVISANDO EJERCICIOS\EJERCICIO 2\TIMER 500MS.ASM 33 : Found label after column 1. (BUCLE)
Error[173] D:\WILLIAM\CLASES DE PIC\REVISANDO EJERCICIOS\EJERCICIO 2\TIMER 500MS.ASM 46 : Source file path exceeds 62 characters (D:\WILLIAM\CLASES DE PIC\REVISANDO EJERCICIOS\EJERCICIO 2\TIMER 500MS.ASM)
Halting build on first failure as requested.
Debug build of project `D:\William\clases de pic\revisando ejercicios\EJERCICIO 2\EJERCICIO 2.mcp' failed.
Preprocessor symbol `__DEBUG' is defined.
Sat Nov 14 14:24:05 2009
BUILD FAILED
el programa que estoy haciendo es el sgte
LIST P=16F628A ;TIPO DE PROCESADOR
INCLUDE "P16F628A.INC" ;LIBREIRA DE REGISTROS
__CONFIG ( _WDT_OFF & _MCLRE_ON & _LVP_OFF & _INTOSC_OSC_NOCLKOUT ) ;CONFIGURO EL PIC
;WACHT DOG TIMER DESHABILITADO
;BAJO VOLTAGE DE PROGRAMACION DESHABILITADO
;MVLRE HABILITADO
;OSCILADOR INTERNO TIPO RC DE 4MHZ HABILITADO
CBLOCK 0X20
CONTADOR1
CONTADOR2
ENDC
org 0X000
INICIO bsf STATUS,RP0 ;BANCO 1
bcf TRISB,0 ;RB0 SALIDA
bcf STATUS,RP0 ;BANCO 0
LAZO bcf PORTB,0 ;RBO SALE 0
call TIMER_500ms ;RETARDO DE 500ms
bsf PORTB,0 ;RB0 SALE 1
goto LAZO
TIMER_500ms movlW .250 ;MOVEMOS A W 250
movwf CONTADOR1 ;MOVEMOS AL REGISTRO CONTADOR 1 --- 250
movwf CONTADOR2 ;MOVEMOS AL REGISTRO CONTADOR 2 --- 250
BUCLE nop
nop
nop
nop
nop ;hasta aqui hay 8uS
decfsz CONTADOR1,F ;DECREMENTA EN UNO Y GUARDA EN EL REGISTRO SALTA SI ES CERO
goto BUCLE ;EGRESA A BUCLE
movwf CONTADOR1 ;CARGAMOS DE NUEVO 250 AL CONTADOR 1
decfsz CONTADOR2,F ;DECREMENTA EN UNO Y GUARDA EN EL REGISTRO SALTA SI ES CERO
goto BUCLE
return ;se genero 500 ms
END
por favor ayundeme
14/11/2009 #2
Avatar de Vick
Respuesta: ayuda en mplab
El único error que tienes es este:
y por eso no ensambla, coloca el archivo .asm más cerca de la carpeta raíz para que la "dirección" no exceda los 62 caracteres y con eso ya debe ensamblar bien.
Los warnings también hay que atenderlos...
Avatar de Meta
Este tipo de errores a se debería corregir desde hace años. Antiguamente los Windwos de antes era como máximo 255 caracter.
MPLAB tiene que evolucionar también en este aspecto, como es gratuito tampoco nos va hacer demasiado caso, usará un IDE muy antiguo.
14/11/2009 #4
muchas gracias por responder es un buen foro de electronica logre solucionar mi problema gracias
