20/12/2015 #1
SCADA Con ARDUINO Software Gratis iQuimiCAD
Saluos amigos,
Aqui les traigo la version gratiuta del iQuimiCAD2015
Esta version fue liberada el 20-12-2015
Ahora puede hacer control de procesos con ARDUINO
de manera rapida y facil, sin saber mucho sobre programacion.
Gracias por la atencion
20/12/2015 #2
montaje en circuito simple
codigo del arduino utilizado ene l ejemplo, si lo cargan en cualquier ARDUINO UNO  veran que funciona perfectamente
// These constants won't change.  They're used to give names
// to the pins used:
const int analogInPin = A0;  // Analog input pin that the potentiometer is attached to
const int analogOutPin = 9; // Analog output pin that the LED is attached to
int sensorValue = 0;        // value read from the pot
int outputValue = 0;        // value output to the PWM (analog out)
int incomingByte = 0;   // for incoming serial data
void setup() {pinMode(12, OUTPUT);pinMode(11, OUTPUT);pinMode(13, OUTPUT);
  // initialize serial communications at 9600 bps:
  Serial.begin(9600,SERIAL_7N1);//Serial.begin(speed, config) config: sets data, parity, and stop bits. Valid values are :
void loop() {
  // read the analog in value:
  sensorValue = analogRead(analogInPin);
  // map it to the range of the analog out:
  //outputValue = map(sensorValue, 0, 1023, 0, 255);
  // change the analog out value:
  //analogWrite(analogOutPin, outputValue);
  // print the results to the serial monitor:
  //Serial.print("sensor = " );
  Serial.println(sensorValue);
  //Serial.print("\t output = ");
  //Serial.println(outputValue);
  // wait 2 milliseconds before the next loop
  // for the analog-to-digital converter to settle
  // after the last reading:
     if (Serial.available() > 0) {
                // read the incoming byte:
                incomingByte = Serial.read();
switch(incomingByte)
   case 105: digitalWrite(13, HIGH); break;//i
   case 106: digitalWrite(12, HIGH); break;//j
   case 107: digitalWrite(11, HIGH); break;//k
   case 108: digitalWrite(13, LOW); break;//l
   case 109: digitalWrite(12, LOW); break;//m
   case 110: digitalWrite(11, LOW); break;//n
   case 111: digitalWrite(11, LOW);digitalWrite(12, LOW);digitalWrite(13, LOW); break;//todas apagadas "o"
   case 112: digitalWrite(13, HIGH);digitalWrite(12, HIGH);digitalWrite(11, HIGH); break;//todas prendidas "p"
                // say what you got:
               // Serial.print("I received: ");
              //  Serial.print(incomingByte, DEC);
  delay(100);
Les envio una foto de lo siemple que puede ser el montaje solo conectarlo al modlo de Reles y al iQuimiCAD mediante puerto USB, y tendremos funcionando el ARDUINO UNO con un SCADA listo para controlar cualuquier proceso.
