22/10/2009 #1
codigo para lcd en vhdl
hola amigos estoy tratando de controlar un lcd de 16x2 en vhdl pero no logro mostar nada. el codigo siguiente lo que hace es mostrar numero de acuerdo a las veces en que pulse pero me da los siguientes errores
-- Company:
-- Engineer:
-- Create Date: 14:25:42 10/22/2009
-- Design Name:
-- Module Name: LCD - Behavioral
-- Project Name:
-- Target Devices:
-- Tool versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity LCD is
port(reset:in std_logic;
teclado:in std_logic_vector (1 downto 0);
clk: in std_logic;
rs: out std_logic;
rwut std_logic;
enut std_logic;
al_disput std_logic_vector (1 downto 0);
lcdut std_logic_vector (7 downto 0));
end LCD;
architecture Behavioral of LCD is
signal clkout: std_logic:='0';
signal nop: std_logic:='0';
signal count, count1: integer:=0;
signal letra_e:std_logic:='0';
signal letra:std_logic_vector (7 downto 0):=X"FE";
signal al_reg:std_logic_vector (1 downto 0);
signal del_reg:std_logic_vector (1 downto 0);
begin
-- codificador del teclado
process (teclado)
begin
case teclado is
when "10" => al_reg <= "01"; ---el cero
letra <= X"31";
letra_e <= '1';
when "01" => al_reg <= "10"; ---el uno
letra <= X"32";
letra_e <= '1';
when others => al_reg <= "11";
letra_e <= '0';
end case;
end process;
-- registro temporal 1
PROCESS(al_reg)
BEGIN
IF clk = '1' THEN
del_reg <= al_reg;
END IF;
END PROCESS;
--Rutina de retardo de clock para el LCD
process (clk)
begin
if clk'event and clk ='1' then
count1<= count1 + 1;
if count1 = 100000 then
clkout <= not clkout;
count1 <= 0;
end if;
end if;
end process;
----maquina de estado del LCD
process (reset,clkout)
variable count:integer range 0 to 131072; --17bits
begin
if (reset ='0') then
count:=0;
elsif(clkout'event and clkout ='1') then
if (count = 34) then
if letra_e ='1' then
count:=34;
else
count<=32;
end if;
end if;
if count = 32 then
if letra_e='1' then
count<=33;
end if;
count<=count;
else
if count =34 then
count<= 34;
else
count<= count+1;
end if;
end if;
case count is
when 0 => en<='0';
when 1 => en<='1';
rw<='0';
rs<='0';
lcd<=X"38";
when 2 => en<='0';
when 3 => en<='1';
rw<='0';
rs<='0';
lcd<=X"38";
when 4 => en<='0';
when 5 => en<='1';
rw<='0';
rs<='0';
lcd<=X"38";
when 6 => en<='0';
when 7 => en<='1';
rw<='0';
rs<='0';
lcd<=X"06";
when 8 => en<='0';
when 9 => en<='1';
rw<='0';
rs<='0';
lcd<=X"0C";
when 10 => en<='0';
when 11 => en<='1';
rw<='0';
rs<='0';
lcd<=X"01";
when 12 => en<='0';
when 13=> en<='1';
rw<='0';
rs<='0';
lcd<=X"80";
when 14 => en<='0';
when 15 => en<='1';
rw<='0';
rs<='1';
lcd<=X"45"; --E
when 16 => en<='0';
when 17 => en<='1';
rw<='0';
rs<='1';
lcd<=X"54"; --T
when 18 => en<='0';
when 19 => en<='1';
rw<='0';
rs<='1';
lcd<=X"4E"; --N
when 20 => en<='0';
when 21 => en<='1';
rw<='0';
rs<='1';
lcd<=X"FE"; -- " "
when 22 => en<='0';
when 23 => en<='1';
rw<='0';
rs<='1';
lcd<=X"31"; --1
when 24 => en<='0';
when 25 => en<='1';
rw<='0';
rs<='1';
lcd<=X"30"; --0
when 26 => en<='0';
when 27 => en<='1';
rw<='0';
rs<='1';
lcd<=X"34"; --4
when 28 => en<='0';
when 29 => en<='1';
rw<='0';
rs<='1';
lcd<=X"30"; --0
when 30 => en<='0';
when 31 => en<='1';
rw<='0';
rs<='0';
lcd<=X"0C"; --Nueva linea
when 32 => en<='0';
when 33 => en<='1';
rw<='0';
rs<='1';
lcd<=letra; -- del teclado
when 34 => nop<='0';
end case;
end if;
end process;
end Behavioral;
HDLParsers:410 - "C:/LCD_TEC/LCD.vhd" Line 105. Variable 'count' count is at left hand side of signal assignment statement.
HDLParsers:410 - "C:/LCD_TEC/LCD.vhd" Line 111. Variable 'count' count is at left hand side of signal assignment statement.
HDLParsers:410 - "C:/LCD_TEC/LCD.vhd" Line 113. Variable 'count' count is at left hand side of signal assignment statement.
HDLParsers:410 - "C:/LCD_TEC/LCD.vhd" Line 116. Variable 'count' count is at left hand side of signal assignment statement.
HDLParsers:410 - "C:/LCD_TEC/LCD.vhd" Line 118. Variable 'count' count is at left hand side of signal assignment statement.
HDLParsers:814 - "C:/LCD_TEC/LCD.vhd" Line 123. Integer value 131072 is missing in case.
07/03/2010 #2
Respuesta: codigo para lcd en vhdl
hola una pregunta , pudistes arreglar el problema que tenia tu programa , si llegastes a solucionar me podrias decir donde estaba el error gracias de ante mano
07/03/2010 #3
Avatar de Ferny
Hola
Los 5 primeros errores vienen porque hay una señal definida con el nombre count:
Así como una variable con el mismo nombre:
Entonces es por eso que sale error. La solución es renombrar una de ellas. El problema está en saber en el código cuándo es variable y cuándo es señal. En las asignaciones, si es de tipo := entonces es variable, mientras que si es de tipo <= entonces es señal. El problema está cuando encontramos algo como if count = XX, en ese caso no se sabe si es variable o señal, y hay que averiguarlo por contexto.
En cuando al último error, eso viene porque el número 131072 no se puede representar en 17 bits, sino en 18. La solución está en definir el rango de la variable correctamente, o sea una unidad menos:
variable count:integer range 0 to 131071; --17bits (ahora sí)
De todas formas, veo muchas cosas raras en el código, no sé si corrigiendo esos fallos pueda funcionar, pero es posible que dé algún quebradero de cabeza más.
Un saludo
PD: por favor, no llamar "programas" a los VHDL, lo que se diseña es HARDWARE, no software, luego decir programa no tiene sentido. Es que lo veo decir mucho y francamente es incorrecto...
08/12/2011 #4
Aplicacion del vhdl para lcd del monitor de pantalla
Hola amigos soy nuevo en programar codigo vhdl con el programa xilinx ise y mi pregunta es si uds saben o me pueden ayudar con el codigo vhdl de un programa para mostrar palabras en el lcd de la pantalla del monitor, es decir, no el lcd del spartan sino el lcd de la compu de escritorio, de ante mano muchas gracias por su respuesta
