12/11/2007 #1
Avatar de Andres Cuenca
Guías de diseño amplificadores serie TDA (Philips)
Esta guía de diseño menciona las características de funcionamiento de una gran parte de los amplificador integrados serie TDA de Philips y el circuito sugerido por el fabricante para sacar el máximo provecho de estas.
Lista de ICs:
For portable radio/audio equipment
TDA1011
TDA1015, TDA1015T
TDA1016
TDA1308T
TDA7050(T)
TDA7052, TDA7052A(AT), TDA7052B(BT)
TDA7053, TDA7053A(AT)
TDA7056, TDA7056B, TDA7056A
TDA7057Q
TDA7057AQ
TDA8541(T)
TDA8542(T)
TDA8543(T)
TDA8547(T)
TDA8551(T)
TDA8558(T)
TDA8559(T)
For car radios/power boosters
TDA1010A
TDA1020
TDA1510AQ
TDA1515BQ
TDA1516BQ, TDA1516CQ
TDA1518BQ
TDA1517(P)
TDA1519, TDA1519A, TDA1519B
TDA1552Q
TDA1553Q, TDA1553CQ, TDA1553Q
TDA1557Q
TDA1555Q
TDA1554Q
TDA1558Q
TDA1556Q
TDA1560Q
TDA1561Q
TDA8560Q
TDA8563AQ, TDA8563Q
TDA8564Q
TDA8561Q
TDA8562Q
TDA8565Q
TDA8566Q
TDA8567Q
TDA8568Q
TDA8569Q
TDA8574(T)
TDA8576T
TDA8577
TDA8578(T)
TDA8579(T)
For mains-powered systems including hi-fi and TV sound
TDA1013B
TDA1514A
TDA1521A
TDA2615
TDA1521A
TDA1521(Q
TDA2616(Q)
TDA1521(Q)
TDA2611A
TDA2613
TDA2614
Very low power (less than 1 W)
TDA8574(T)
TDA8576T
TDA8577
TDA8578(T)
TDA8579(T)
TDA8559(T)
TDA1308T
TDA7050(T)
TDA1015T
Low power (1 W to 5 W)
TDA8558(T)
TDA7052A(AT)
TDA7052B(BT), TDA7052A(AT)
TDA7052
TDA7053
TDA8541(T)
TDA8551(T)
TDA8542(T)
TDA7053A(AT)
TDA8543(T)
TDA8547(T)
TDA1016
TDA7056
TDA7057Q
TDA1015
TDA7057AQ
TDA7056A
TDA7056B
Medium power (6 W to 12 W)
TDA1010A
TDA1020
TDA1013B
TDA2611A
TDA2613
TDA2614
TDA2613
TDA1011
TDA1517(P)
TDA1519
TDA1517
TDA1521A, TDA1521(Q)
TDA2615
TDA2616(Q)
High power (more than 12 W)
TDA1519A, TDA1519B
TDA1554Q
TDA1555Q
TDA1554Q
TDA1558Q
TDA1510AQ
TDA1515BQ
TDA1518BQ
TDA8562Q
TDA8565Q
TDA8561Q
TDA8564Q
TDA1552Q
TDA1553Q, TDA1553CQ
TDA1557Q
TDA1556Q
TDA1561Q
TDA8566Q
TDA8567Q
TDA8568Q
TDA8569Q
TDA1560Q
TDA8560Q
TDA8563Q, TDA8563AQ
TDA1514A
15/03/2008 #2
Avatar de Tomasito
Esto ya lo había posteado yo antes
Amplificadores Integrados Phillips (Lista y Caracteristicas)
Salu2!
13/06/2008 #3
Avatar de djmyky
hize pruebas con algunos tda el tda 1510 no me agrado por que tiene una salida media latosa igual que los sony bueno lo iguala el tda 2005 en puente estoy por probar los tda que usan loas auto radios pioner los comentare luego como me fue
16/07/2008 #4
Avatar de detrakx
djmyky en cuanto a lo que decis si tenes drama o no te gustan algunos integrados
te recomiendo que utilices los de fuente partida. por que ?¿ Por que la mayoría no utiliza capacitores de boostrap estos capacitores de gran capacidad generalmente son electroliticos. que son una bosta para una etapa de salida que te destruyen la señal. En todo caso utiliza electroliticos no polarizados o bipolares.
Para que la etapa de salida no sea degradada tienes que utlizar capacitores de poliester o los de la familia MKT , MKP etc. el problema es que para valores superiores a 10uf no se consiguen. Otra cosa tenes divisor de frecuencia,. ?¿ un parlante mal filtrado suena latoso.
saludos.
18/07/2008 #5
Avatar de djmyky
hummm debe de ser al igual que el conocido la4440 me suena asi debe de ser fidelidad pero ahora en el mercado se corre el riesgo con los stk que he probado algunos son truchos y te queman los parlantes con un mal manejo de de ese integrado es por la fuente partida
18/07/2008 #6
Avatar de detrakx
buenas. djmyky escuche algunas potencias con STk , aca hay una empresa que se llama NB electronics y usa los STK. estan buenos esos integrados pero tienen algunos problemas
primero usan grandes ganancias por el tipo de realimentacion es decir te tiran altas tensiones en bornes, suponete que te armas una potencia para bajos y pones un parlante con poca excursion del cono ,.. a 1/4 de potencia te lo puede desconar, es decir este integrado usa mucha tension en bornes y poca corriente lo que no es lo mas recomendable. y Segundo cuando tenes tan alta ganancia el ruido electrico se multiplica por esa ganancia "por eso esas potencias conectadas a las bocinas con drivers soplan mucho :( "
por ahora estoy usando el TDA7265 de fuente partida (25+25W o 50W en puente) sin capacitor de salida , tambien tiene la opcion de stby/mute opcional para usarlo como antipop ahora justamente estoy trabajando en ello.
Te recomiendo ese integrado es barato de facil configuracion y tiene muy buen sonido.
Avatar de djmyky
exactamente estoy biendo ese tipo de integrado y ver la posibilidad de que si funciona 2 tda uno master y otor en esclavo para ganar corriente
Tipo de Archivo: jpg esclavo_304.jpg (66,7 KB (Kilobytes), 829 visitas)
21/07/2008 #8
Avatar de detrakx
que buen circuito. me viene a pleno voy a probarlo. Si te llega a funcionar avisa que tal.
La verdad que andaba buscando algo similar como poner unos transistores a la salida. de los integrados y hacer una pequeña etapa A/B de salida y a la par minimizar la ganancia de los integrados de esa manera llegar a un equilibrio entre la ganancia para minimiar soplido. y una corriente tal que el parlante tenga buena amortiguacion.
ya que lo menciono si alguien tiene algun circuito, con algunos mosfet en la salida del integrado sería muy buen aporte.
gracias djmiky.
saludos.
15/01/2009 #9
Avatar de franko1819
pero se olvidan del tda2822
que tiene bastante potencia yo lo he probado y lo bueno es que va con 4 pilas
Tipo de Archivo: gif circuito_amp_6v_195.gif (31,7 KB (Kilobytes), 1618 visitas)
15/06/2009 #10
hola djmyky, me interesa ese cicuito amplificador peo estoy en duda de que integrado usas para cada uno? perdona si es ignorante mi pregunta pero no especifica cual es el integrado. yo tengo un tda7265 y lo arme en puente y solo me tira 20w igual al tda2005 que tambien tira 20w en puenteo. nose si yo lo arme defectuoso o es ese la potencia real del tda7265. te agradeceria si pudiereas responderme
15/06/2009 #11
creo falta el tda 1562q el amplificador de 75w rms mono
19/07/2009 #12
tambien se olvidan del 7377.. del 2004 2003.. 2002...1998 (cuack) hay muchos
28/07/2009 #13
Avatar de Alexis Córdoba
Falta el TDA1562Q amplificador de 70W mono,
12/10/2009 #14
Avatar de Tacatomon
Respuesta: Guías de diseño amplificadores serie TDA (Philips)
neutron dijo: Ver Mensaje
Esos IC´s son de fabricacion exclusiva de ST Microelectronics.
Saludos!!!
25/10/2009 #15
Avatar de Luis1342
Hola foro,bueno pues he de comentarles que hace poco arme un ampli con el TDA1517 de Phillips para sustituir el modulo amplificador que dejo de funcionar en las bocinas de la PC,arme fuente y amplificador hecho en base a ese integrado y a los calculos del post de Fogonazo para el diseño de fuentes de alimentación y muy bien .
debo decirles que la economia en mi hogar pues no es muy buena actualmente para haber comprado unas bocinas nuevas,sabiendo que era falla del ampli y usando componentes que tenia guardados,todo salio muy bien....
muchas gracias por este completo aporte
creo que el hemos de todos es el TDA1560Q que saca 30w en 8ohm con 0.1 de distorsión. Lo probare con una fuente de pc por que dice que trabaja con 12v y una corriente de 4A. Deséenme buena suerte hay les cuento como me fue.
27/11/2009 #17
Saven lo que falto fue el TDA1524A Ese integrado es indispensable en las fiestas juveniles
27/11/2009 #18
si esa cosa la quieres para crear un sub woofer eso no sirve, mejor te recomiendo el PT2350 es muchísimo mejor.
03/08/2010 #19
hola gente, una consulta: ¿ ningun integrado TDA se banca +/-51V ?
Porque tengo un tranformador de 36+36 y quisiera usarlo para un tda haber que tal se escucha, la macana que vi un monton de datasheet de los tda y solamente vi dos o tres integrados que soportan +/-50V Maximo de ésta marca, nose si por +/-1V se me puede llegar a quemar el integrado, igualmente esos +/-51V que restifica mi fuente son aproximados pero puede llegar al voltaje mensionado.
¿ Si saben de algun integrado tda que soporte mas voltaje me podrian decir para ayudarme ? o si el tda7294 con una buena disipacion pueda llegar andar. Desde ya muchas gracias
17/10/2010 #20
Avatar de electrodin
hola, juan_inf, alguna vez tuve ese mismo problema, y si algunos integrados no soportann mas alla de su voltaje max, lo que yo hacía para reducir +-1v era colocar uno o dos diodos en serie en la etapa rectificadora con dos diodos se consigue 1.4v aprox. y es mejor que usar una resistencia serie.
espero te sirva.
Lupa Audio: Gran señal
