11/04/2013 #1
Avatar de JBE
Opiniones sobre estos circuitos de amplificadores
Hola! Quería saber que les parecían estos circuitos;
El primero es un amplificador de 25W en 8Ω:
http://wiringcircuitdiagram.wiringdi...ifi-amplifier/
Componentes:
Código PHP:
R1,R4 47K       1/4W Resistors
R2
4K7    1/4W Resistors
R3
1K5    1/4W Resistors
R5
390R    1/4W Resistors
R6
470R    1/4W Resistors
R7
33K    1/4W Resistors
R8
150K    1/4W Resistors
R9
15K    1/4W Resistors
R10
27R    1/4W Resistors
R11
500R    1/2W Trimmer Cermet
R12
,R13,R16 10R    1/4W Resistors
R14
,R15 220R    1/4W Resistors
R17
8R2    2W Resistor
R18
R22    4W Resistor (wirewound)
C1 470nF    63V Polyester Capacitor
C2
330pF    63V Polystyrene Capacitor
C3
,C5 470µF    63V Electrolytic Capacitors
 C4
,C6,C8,C11 100nF    63V Polyester Capacitors
C7
100µF    25V Electrolytic Capacitor
C9
10pF    63V Polystyrene Capacitor
C10
1µF    63V Polyester Capacitor
Q1
-Q5 BC560C    45V100mA Low noise High gain PNP Transistors
Q6
BD140    80V 1.5A PNP Transistor
Q7
BD139     80V 1.5A NPN Transistor
Q8
IRF532    100V 12A N-Channel Hexfet Transistor
Q9
IRF9532    100V 10A P-Channel Hexfet Transistor
El segundo es un amplificador de 40W en 8Ω:
http://electronicsproject.org/7040-w...-fi-amplifier/
Componentes:
Código PHP:
R1R7 100 KOhms
R2
R3R9 1.2 KOhms
R4
R5R6 2.7 KOhms/2W
R8
4.7 KOhms
R10
R13R16R18R19 100 Ohms
R11
3.3 KOhms
R12
R17 680 Ohms
R14
R15R22R23R24R25 1 Ohm /2W
R20
10 Ohms /2W
R21
1o Ohms /1W
VR1
100 Ohms
[B]Capacitors[/B]
C1 1 µF/polyester
C2
C3 25 µF/25V electrolytic
C4
C8C9 o.1 µF polyester
C5
10 µF/60V electrolytic
C6
4.7 µF/10V electrolytic
C7
56 pF ceramic disc
[B]Semiconductors[/B]
T1T2T3 BC546B
T4
BC558B
T5
T11 2N4033
T6
T10 2N3019
T7
BC548B
T8
T9 BC147B
T12
BD140
T13
BD139
T14
2N3055
T15
MJ2955
ZD1
3.3V 400mW zener diode
ZD2
3.9V400mW zener diode
[B]Miscellaneous[/B]
L1 Coil having 20 turns of 20 SWG over thin pencil
F1
3.5 Ampere fuse
[B]SPECIFICATIONS[/B]
Output power (1 KHzo.7THD): 73W into 4-ohms and 44W into 8-ohms
Offset Voltage
Less than ±40mV
Input impedance
100 K
Harmonic distortion
0.015%
Intermodulation distortion (70W): 0.02%
Frequency range10 Hz – 30 KHz, ±2dB
Signal-to-noise ratio (out 100mW): Over 72dB
¿Alguno es mejor que el otro? ¿Alguien los armó?
Edit: Los circuitos también están publicados en el foro, para que no se pierdan.
Muchas gracias!
Lupa Audio: Gran señal
