07/09/2013 #321
Avatar de el-rey-julien
Fernando Arias dijo: Ver Mensaje
que se lo lleven a una clinica de reposo.
07/09/2013 #322
Avatar de Dr. Zoidberg
Tacatomon dijo: Ver Mensaje
"This experiment demonstrates that within the freezer compartment, there exists a high degree of symmetry and that this symmetrical condition is imposed on the temporal asymmetric condition of the two chronologically spaced photographs and is, in turn, imposed on the senses of the human subject of the photographs. It is unfortunate that the vast majority of people, including many who work in science and technology, do not appreciate that a photograph functions within the quantum mechanical world."
07/09/2013 #323
Avatar de maton00
Solo le falto decir que si daba 3.141592... vueltas alrededor de su refrigerador sosteniendo el marcador cuantico el sonido iba a mejorar.
07/09/2013 #324
Avatar de Ratmayor
http://i.imgur.com/wqLOjTt.gif
07/09/2013 #325
Fit the First. Choose two photographs of yourself, a current one and another taken when you were much younger, place them in separate sealed plain polythene bags and store them inside the freezer compartment of your domestic fridge. Listen to your audio system playing (the source of the music doesn’t matter) and decide if the sound has improved. If unsure whether this is the case, remove the photographs and their containers from the fridge and you will hear the sound deteriorate markedly. And so will anyone else present at the time.
Fit the Second. Remove the photos and their bags from the fridge. Take a standard red fine-point permanent Staedtler Lumocolour pen (No 313) and write 'x 26 'x (the dashes are important) on both sides of each of the bags containing your photographs.
Fit the Third. Take a domestic flashlight, remove its batteries and with the same red pen write 'x 26 'x on each of them. Replace the batteries in the flashlight.
Fit the Fourth. Using the red pen, write 'x 26 'x on a CD’s printed side and also on the outside of its plastic storage case. Take your domestic flashlight and shine the beam for a few seconds on the written 'x 26 'x markings on the bags containing your photographs and then to the markings on the CD and its case. Replace the photographs in the freezer and play the CD. The sound will again have improved considerably, even if the whole idea seems as mad as apple crumble to you.
07/09/2013 #326
Avatar de SKYFALL
La leyenda del "audio improvement CD across frezzed photographs", si son fotos en blanco y negro y el marcador es morado del # 22 el experimento no sirve
10/09/2013 #327
Digno de ser leído: http://www.hifilit.com/hifilit/Mad/Mad.htm
y es de los 50's.....
10/09/2013 #328
Avatar de Tacatomon
250 Horsepower Turntable...
12/09/2013 #329
Avatar de cosmefulanito04
Miren esta cosa rara que se fabricó hace 10 años (motherboard con sonido valvular ):
AOpen AX4 B 533 Tube:
¿Opiniones?
Yo ya tengo una idea formada, pero quiero saber que piensan uds
12/09/2013 #330
Avatar de juanfilas
jeje justo lo postié en un foro vecino, que queres que te diga, a mi me gusta el enjendro, une los circuitos mas avanzados que tenemos actualmente (microprocesadores) con casi lo mas obsoleto de la electrónica... ¿interesante no?
12/09/2013 #331
Avatar de Nuyel
Seria lindo tenerla en un gabinete con ventana y ver la valvulita encendida
12/09/2013 #332
cosmefulanito04 dijo: Ver Mensaje
¿Opiniones?
Y... andar? Puede andar... de ahí a que lo haga bien... es otra historia.
Habría que ver cual DAC tiene el mobo y en que configuración están las válvulas.. al menos como para hacer una evaluación "medianamente decente".
He leído de gente que conecta un DAC con salidas en modo-corriente a una resistencia de 100Ω (del tipo "audio boutique") para hacer el conversor I-V (ni te digo la distorsión que eso mete) y luego ponen un par de válvulas para amplificar lo que sale. Y el filtro pasa-bajos??? ... ooooppsss!! no sabía que iba uno... "pero mis oídos dicen que así suena bien", así que seguramente los ingenieros son unos salames... o cosas parecidas...
En fin... probablemente valga más como un adorno tipo retro-tech que como algo verderamente útil...
12/09/2013 #333
Avatar de hazard_1998
te digo mas, tengo el leve presentimiento de que está como buffer (seguidor catódico) así que el "sonido valvular" bien gracias...
13/09/2013 #334
Les dejo este review:
http://www.neoseeker.com/Articles/Ha...aopenax4btube/
Lo más destacado:
In AOPen’s own words: “We love what we hear regardless of harmonic distortion as well as the limited frequency response compared to a solid state device.”
13/09/2013 #335
Creo que le voy a pegar un par de válvulas a la placa de pIV que tengo para tirar, así algún gil*******as igual me paga 200€ o más.
13/09/2013 #336
Recordado
Avatar de elgriego
Hola colegas eso se denomina :Tecnologia Vintage!!!
Lo más destacado:
Naaaa..... lo más destacado es esto:
AOpen’s “meticulous journey” to bring this fusion to fruition involved carefully choosing components. They use a 24K plated ceramic 9 pin socket for the tube, Cardas Audi cable, Vishay resistors, and a Maxim 668 DC-DC power supply for the tube.
Todo eso es garantía de calidad audiófila....
Baaaahhhh.... ya sabíamos el "segmento del mercado" al que estaba dirigido...
13/09/2013 #338
Avatar de juanfilas
adorno tipo retro-tech... mortal
01/12/2013 #339
Avatar de Mostdistortion
maomastering dijo: Ver Mensaje
Oro???
Manley 16x2 Line Mixer: $8,100.00
ProAc Response D80: $17,995.00
Millennia LPE-2: $8,549.99
PMC Loudspeakers BB5-A: $79,000.00
SPL MMC 1 Mastering Console:$78,849.00
Todos éstos equipos (y muchos mas!!!) se encuentran dentro de la gama de productos mas utilizados por los profesionales del audio. Ninguno posee conexiones bañadas en oro ni cosas por el estilo.
Seguramente tienen conexiones bañadas en oro en los conectores phantom, de línea y de señal débil, eso se hace para que exista un buen contacto. El oro no es tan buen conductor como el cobre (pueden buscarlo en tablas) pero no se oxida y proporciona un buen contacto, pero contactos externos, no pavadas internas que se pueden soldar (contacto asegurado)
Y tampoco tiene precios astronómicos, como dijo Fogo por ahí, las fichas ethernet (son re baratas) tienen sus contactos bañados en oro, las fichas phantom de calidad y casi todos los microfonos tienen contactos bañados en oro, los microprocesadores tienen las patas bañadas en oro, etc.
El problema es cuando te quieren cobrar una pavada de guita argumentando que porque tiene contactos de oro o cablecitos mágicos, es el non plus ultra del audio. Esas cosas que menciona Zoidberg son algo así como el "indispensable" en un equipo destinado al audiófilo que gusta de consumir humarketing en dosis letales.
Lupa Audio: Discusión General
