01/07/2016 #821
Avatar de hellfire4
Me encontre con este:
http://pwbelectronics.co.uk/product/...rop_Liquid.pdf
Por la minucia de 100 libras
Un fragmento a hacer hincapie:
P.W.B. Special One Drop Liquid possesses a most
extraordinary property. The human senses, in
common with the requirements of all living
material including trees and all other green plants,
have evolved the requirements for forward facing
light energy
All Compact Discs should have a drop of the Special One Drop Liquid
applied to both sides and spread across the surface using a finger tip. The
surface can be dried with a cloth or a paper tissue. Vinyl records should
have a drop of the Liquid applied to the particular area on the record which
has the run off groove on both sides of the disc. The outside faces of the
disc sleeve or disc housing should also be treated.
To ascertain the effect of the One Drop Liquid on any object, it is only
necessary to initially stand the small bottle containing the Liquid on the
face of the object. ALL transparent material within a listening room,
including glass windows, clock faces, wrist watch faces, TV screens, the
lenses of eye glasses etc. and display windows on equipment should all be
treated. It is only necessary to apply one drop of the Liquid to the corner
of a glass window for the beneficial effect to be heard
12/10/2016 #822
Avatar de hellfire4
Bueno, me tope con eso, ni más ni menos que el tatam tatam:
El toma wattgate 381
Una descripción, aunque a modo de mofa:
Ni más ni menos que el toma eléctrico que mejorara la calidad de sonido en cualquier dispositivo conectado a él. El chapado en oro de 24k y los "contactos endurecidos con tratamiento térmico" son los que hacen que la magia funcione .
14/10/2016 #823
Avatar de SKYFALL
hellfire4 dijo: Ver Mensaje
http://www.wattgate.com/images/produ...ementLarge.jpg
http://www.hiendy.com/hififorum/data...kwawuwwycy.jpg
Pero esta nueva si esta de antología, tanta fidelidad de audio potenciada desde una tomacorriente doble tipo Leviton que no alcanza a valer ni 1 Obama, lo mejor es que la tomacorriente "mejorara la calidad de sonido en cualquier dispositivo conectado a él"
Osea que si le conecto la licuadora, sonará mas diafano y con mayor realismo el motorcito aquel...
14/10/2016 #824
Avatar de djwash
La serigrafia de esa toma es de muy alta calidad vieron?
Dame 3!!
14/10/2016 #825
Si la tapa de aluminio es maciza , sin duda mejora la celestialidad del sonido , ahora , si es de chapa estampada , ya no
15/10/2016 #826
Avatar de diegomj1973
Si la tapa dice "SINE" => tiene que salir seno, nomás .
¿O saldrá otra cosa de esos enchufes?
15/10/2016 #827
Nono , no importa el momento en que enchufes , se sincronizará automáticamente a seno
15/10/2016 #828
Recordado
Avatar de elgriego
Todos los dias nos siguen sorprendiendo con estos avances de la ciencia,,, a veces les juro ,devolveria mi titulo de tecnico ,e ingeniero, para no seguir sufriendo el descreimiento, que estos conocimiento me provocan, en relacion a estos prodigios casi magicos.!!!
Pd,,,,no podriamos inventar algo asi ,digo para sacarle plata,,unos billetitos, al sector high end,que adquiere y consume todas estas novedades y maravillas de realce del sonido ,e incluso discute con fe ciega,los resultados audibles de estos adminiculos ,,,,,para pensarlo no ???
Viéndolo detenidamente, el modo de sacarle algún billetito rápido a algún desprevenido del círculo HIGH END ó HI 10 (según el gran WILLY PATRAÑA) parecería consistir solo en escribirle "AUDIO GRADE" a casi cualquier cosa que necesites usar en tu cadena de audio (digamos, hasta el paño con el que tendríamos que limpiar los equipos, para no degradar esos tonos puros, vió???) .
Esos de las tomitas SINE son SINE...SCRÚPULOS .
PD: me mató lo del número de serie!!! Baaaahhh... Y con la estrellita, quedás como un Sheriff!!!.
16/10/2016 #830
Avatar de hellfire4
Aca hay otro, más o menos adaptado el texto :
Descubrimos que durante la reproducción, una cantidad significativa de luz láser residual rebota alrededor dentro de un CD. Esta luz residual finalmente encuentra su camino de regreso al receptor, creando fluctuaciones. CD Stoplight fue desarrollado para reducir las pasivamente los efectos de la luz residual que en última instancia provocan fluctuaciones. Mediante la absorción de la luz residual en el transporte de manera pasiva, en lugar de tratar de reducir sus efectos electrónicamente, se reduce la fluctuación en la fuente, mantenimiento así la cadena de reproducción.
Se entrega con un aplicador especial, CD Stoplight es fácil de aplicar. No es tóxico, es respetuoso del medio ambiente y no causa escamas o irritación en la piel. Los discos compactos tratados con CD Stoplight suenan más neutrales, menos agitados y significativamente más francos.
Ahora, ver para creer XD.
Me suena parecido a lo de las gotas de antes (poco más arriba)
16/10/2016 #831
Avatar de Dr. Zoidberg
http://store.acousticsounds.com/imag...023654-693.jpg
http://stereo.vn/wp-content/uploads/...-Light-2-R.jpg
16/10/2016 #832
Avatar de yosimiro
Entonces propongo, "inventar", una compactera con el solo el fín de aplicar el "stop light" más parejo.
Esas rendijas que se crean por el trazo irregular, deben tener concecuencias nefastas a nivel "auditivo"
08/11/2016 #833
Avatar de Kebra
Hace un par de días me topé con algo realmente notable.
Viveza argenta.
Tiren a la calle sus equipos de audio y compren esto:
http://www.acousticintegrity.com/aco...lophonics.html
Parece que van a llevarlo a las misiones a MARTE. No es broma, lean un poco el site.
Algunos "testimonios" dicen que se puede "oler" el sonido.
Me morí muerto.
Ah, hay algo que me ofende ya, dicen que colaboró con Pink Floyd. Sí, seguro, porque Alan Parsons es un gil que de audio no sabe nada.
11/11/2016 #834
Hola Kebra, Hugo Zuccarelli fue el encargado de efectos holofónicos en el disco the Final Cut de pink Floyd, fijate en la contratapa del mismo que figura una mención de tales efectos. Estos se escuchan en forma completa unicamente usando auriculares intracanal. Un saludo, sergio.
16/11/2016 #835
Avatar de Nuyel
Cylindrical sound waves have a natural dispersion in a linear way, which translates to more sound at long distances and less sound at closer distances
Conocía de parlantes que transmitían linealmente el sonido a costa de no dispersarlo, pero no de uno que lo hiciera exponencial mientras se dispersa para tener un volumen lineal D:
17/11/2016 #836
Avatar de Kebra
sergio rossi dijo: Ver Mensaje
Curiosamente ese disco yo (en mi locura personal) no lo reconozco ni registro como obra de Pink Floyd. Los previos y los siguientes los tengo todos, pero The Final Cut es un capricho de Waters. Solista no lo banco y lo hago responsable de la separación de Floyd y si lo veo le pego seguramente.
Así que jamás podría saber quien colaboró. Pero mi rechazo es por la parte donde manda fruta con que el sonido debe salir de un solo punto en el universo y "videncias" semejantes.
Desde que se inventó el primer aparatejo de audio que están dando vueltas con 5.1, 7.1, cuadrafonía, y un desgraciado que hizo un sistema con 30 (treinta) subwoofers para un living. Tenemos 2 oídos. Lo único cierto que menciona el sujeto es el Q-Sound que podés escucharlo en el disco de Madonna Immaculate Collection, pero no es nada mas que una aprovechamiento casi perfecto del Stereo.
Se reiteran conceptos como "se siente" "es real" "limpieza" y no veo ni media ecuación ni explicación o demostración científica del asunto.
Perdón pero para mi, lo que no se puede demostrar con ciencia, es verso.
Y quienes lo alaban son vendedores de pachuli, astrólogos y tarotistas. Marilyn Ferguson, autora de un libro para "comprender la nueva era". Debe ser amiga de Romaniuk.
Uno de la NASA dice que tiene una "transparencia prístina". Mostráme los datos de respuesta en frecuencia y distorsión, pedazo de delincuente!
Transparencia prístina... Si es transparente es un vidrio, tirálo!
Hace rato que no te leía Sergio, andás perdido en otros posts que no sigo quizá.
Avatar de yosimiro
Concuerdo en que casi todo eso es verso.
Pero la cuadrafonía, es algo perceptible, así como esos 5.1 etc.(de allí a que sea util, es materia opinable).
La capacidad estereofónica del oido, no posibilita o limita la capacidad de oir o distinguir muchas fuentes, sino que se refiere a direcciones.
Podemos percibir, si algo suena delante nuestro, a nuestras espaldas, arriba, abajo, a la derecha o la izquierda.
Así como podemos percibir el desplazamiento de esas fuentes sonoras.
Y agrego, el utilizar fuentes sonoras múltiples, no comienza con la electrónica.
En el Renacimiento, se componían obras para 4 o más coros simultaneos(buscar Gabrieli.)
Y antes de eso, un tal Ockeghem, llegó a componer un Deo gratia, para 36 voces.
19/11/2016 #838
Recordado
Avatar de elgriego
Buenos dias ,Ustedes saben que mayoritariamente ,comparto con ustedes la opinion acerca de estos dislates del audio ,pero en esta ocasion,siento discrepar con ustedes,pero lo de zucarelli funciona,y no es algo nuevo,de esto se hablo en revistas especializadas de alta fidelidad,y tambien salio un articulo en popular electronics, en su reporte de equipos de finales de los 70,el invento de este muchacho ,llamado ringo,es un sensor binaural,que permite distinguir la procedencia ,altura y direccion de diferentes sonidos,claro que el efecto se aprecia con auriculares,en el trabajo de ushuaia a la quiaca de Leon Giego,Gustavo santaolalla, se puede percibir,y darse cuenta la direccion desde donde canta leon,que tiene una cascada a determinada altura ,y cosas que no son comunes en la escucha habitual en un sistema estereo convencional,es mas el efecto se distingue hasta con un solo oido.
Pd, Voy a desempolvar el disco,para volver a comprobar empiricamente mis apreciaciones.
Avatar de yosimiro
elgriego dijo: Ver Mensaje
Por eso es que dije...
yosimiro dijo: Ver Mensaje
La capacidad estereofónica del oido, no posibilita o limita la capacidad de oir o distinguir muchas fuentes, se refiere a direcciones.
22/11/2016 #840
Avatar de Nuyel
No es cuestionable esa capacidad del oído, lo cuestionable es que un altavoz pueda reproducirlo, el oído no es tan idiota como para engañarlo así, con audífonos impulsas directamente la presión acústica al oído obstruyendo el canal e interferencias, pero con las bocinas, el oído es capaz de reconocer la fuente, la ubicación y su distancia, de lo contrario no tendríamos sistemas de sonido envolvente con tantas bocinas para instalar hasta en el techo de la habitación.
Lo otro es lo de ondas cilíndricas, aun si el emisor es un cilindro estas ondas se deformaran en una esfera, o en este caso, más como un huevo, lo que causaría ondas cilíndricas es que haya medios de distinta densidades, por lo que la propagación del sonido seria cilíndrica dentro del medio mientras que se disipa en el medio de diferente densidad, esto ocurre en el mar donde las ondas se dispersan por el agua de una forma cilíndrica cuando la esfera choca con la superficie y el suelo, pero esas ya son distancias bastante grandes.
Lupa Audio: Discusión General
