Antiguo 28/08/2012   #1
Hola!
buscando por los addons del google chrome encontre este interesante que es un editor de esquematicos y simulador de circuitos en el navegador. Lo probe rapidamente y es muy interesante ademas de que es muy util y practico.
https://www.youtube.com/watch?v=f52GV1IpwVk
Build and test circuits right in your browser!
* Design with our easy-to-use schematic editor.
* Accurate analysis (DC, AC & more) in seconds.
* Beautiful schematic printouts (PDF) and images (PNG).
* Share a live circuit URL so others can simulate and edit your circuit.
Easy-wire mode lets you connect elements with fewer clicks and less frustration.
Cross-window copy/paste lets you easily explore and re-mix parts of public circuits from the CircuitLab community.
Mixed-mode circuit simulation lets you simulate analog and digital components side-by-side.
SPICE-like component models give you accurate results for nonlinear circuit effects.
Human-friendly formats let you enter and display values concisely, just like you would on a paper schematic.
Unit-aware expression evaluation lets you plot arbitrary signals of interest, such as differential signals or power dissipation.
In-browser simulation and plotting lets you design and analyze faster, making sure your circuit works before ever picking up a soldering iron.
Unique circuit URLs let you easily share your work or ask for help online.
Advanced simulation capabilities include frequency-domain (small signal) simulation, stepping circuit parameters through a range, arbitrary Laplace transfer function blocks, and more.
Common sense schematics let you name a node "+5V" and know that the simulator will do the right thing automatically, keeping your schematics compact and elegant.
Quick-access build box lets you draw basic circuit primitives quickly, while allowing access to a wide assortment of non-linear elements, feedback elements, digital / mixed-mode components, and custom drawing tools.
EL link:
https://chrome.google.com/webstore/d...jljoj?hl=en-US
para instalarlo ademas del google chrome necesitas una cuenta en google.
Avatar de maezca
maezca
Visitas: 3348
   Citar
12/09/2012 #2
Avatar de Narcolepsia
A ver si me leo alguna explicación o manual por que los circuitos que he hecho, al intentar medir el voltaje e intensidad, me da en todos los puntos cero... :(
12/09/2012 #3
Funciona perfectamente sin crome, no hay que instalar nada:
www.circuitlab.com
Hace tiempo que se comentó en el foro:
CircuitLab: un completa herramienta online para simular circuitos electrónicos.
Lo que no se es si la versión de crome tiene algún añadido o prestación adicional.
La "normal" funciona sin problemas desde cualquier navegador incluso los de android.
24/09/2012 #4
Avatar de jgvh75
Scooter dijo: Ver Mensaje
www.circuitlab.com
Como menciona nuestro amigo Scooter, no hay que intalar nada, solo registrense en Circuit Lab y listo (claro, para poder guardar los trabajos), pero si tiene cuenta en Google, pues con solo el Add basta y ya pueden trabajar sin limitaciones.
Avatar de maezca
jgvh75 dijo: Ver Mensaje
gracias por la aclaracion... a mi me parecio copado el addon, ya que por ejemplo vemos un circuito aca en el foro y lo queremos comprobar rapidamente o para mostrar como se conecta algo, lo hacemos muy rapidamente y sin abrir otro programa.
19/02/2013 #6
Avatar de EXELSIOR
Che y no hay una aplicacion java para moviles que realice este mismo trabajo aunque a menor escala?
20/02/2013 #7
Si, esta aplicación funciona en cualquier movil "decente".
También funciona esta otra pero es muuuuucho menos funcional: pDraft, estaba para palmOS y después hizo una aplicación javascript que funciona en cualquier plataforma, estoy buscando un enlace pero no lo encuentro.
07/05/2013 #8
existe tambien el every circuit, para dispositivos con android. la version gratis trae muy poco espacio para crear circuitos, el cual se puede extender pagado la version paga, o descargando el ElectroDroid y abrirla desde ahi (figura como plugin del mismo). Sumamente utiles ambas aplicaciones
07/05/2013 #9
Avatar de EXELSIOR
yo busco una app que sea compatible con java y simbyan s40 como los nokia c3...
Porque calculadoras de resistencias hay,pero sobre esto no he encontrado nada...
Lupa Actualidad tecnológica
