Hace 4 Semanas #1
Avatar de Heisenbergg
Error al subir LIFA BASE en arduino
Hola, estoy empezando a usar labview con arduino, y al cargar el lifa base en el arduino me da error al subir, tengo la version 1.8.4 de arduino este es el error que me muestra:
Arduino:1.8.4 (Windows 7), Tarjeta:"Arduino/Genuino Uno"
C:\\Program Files\\National Instruments\\LabVIEW 2014\\vi.lib\\LabVIEW Interface for Arduino\\Firmware\\LIFA_Base\\LabVIEWInterface.ino : In function \'void processCommand(unsigned char*)\':
C:\\Program Files\\National Instruments\\LabVIEW 2014\\vi.lib\\LabVIEW Interface for Arduino\\Firmware\\LIFA_Base\\LabVIEWInterface.ino :150:60: warning: left shift count >= width of type
duration=(command[8]+ (command[7]<<8)+ (command[6]<<16)+(command[5]<<24));
C:\\Program Files\\National Instruments\\LabVIEW 2014\\vi.lib\\LabVIEW Interface for Arduino\\Firmware\\LIFA_Base\\LabVIEWInterface.ino :150:77: warning: left shift count >= width of type
C:\\Program Files\\National Instruments\\LabVIEW 2014\\vi.lib\\LabVIEW Interface for Arduino\\Firmware\\LIFA_Base\\LabVIEWInterface.ino : In function \'sevenSegment_Config(unsigned char*)\':
C:\\Program Files\\National Instruments\\LabVIEW 2014\\vi.lib\\LabVIEW Interface for Arduino\\Firmware\\LIFA_Base\\LabVIEWInterface.ino :632:41: warning: iteration 7 invokes undefined behavior [-Waggressive-loop-optimizations]
sevenSegmentPins[(i-1)] = command[i];
C:\\Program Files\\National Instruments\\LabVIEW 2014\\vi.lib\\LabVIEW Interface for Arduino\\Firmware\\LIFA_Base\\LabVIEWInterface.ino :629:3: note: containing loop
for(int i=2; i<10; i++)
C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\ard uino\\main.cpp: In function \'main\':
El Sketch usa 18112 bytes (56%) del espacio de almacenamiento de programa. El máximo es 32256 bytes.
Las variables Globales usan 1120 bytes (54%) de la memoria dinámica, dejando 928 bytes para las variables locales. El máximo es 2048 bytes.
avrdude: ser_open(): can\'t open device "\\\\.\\COM4": Acceso denegado. //CREO QUE ESTE SERIA EL ERRON >:(
Problema subiendo a la placa. Visita http://www.arduino.cc/en/Guide/Troubleshooting#upload para sugerencias.
Este reporte podría tener más información con
"Mostrar salida detallada durante la compilación"
opción habilitada en Archivo -> Preferencias. ...
Hace 4 Semanas #2
Avatar de D@rkbytes
Con esa forma de redactar el problema, (Copiar y pegar) hay que hacerle al adivino para tratar de comprenderlo.
Para que no aparezcan caracteres extraños, como &quot, &gt, &lt y etc. (De HTML) Debes usar las etiquetas del editor de texto, para envolver tu redacción con un formato adecuado.
Sin embargo, analizando y tratando de resolver el enigma, todo parece indicar que el dispositivo en el puerto serial COM4, no está disponible.
Podría ser porque no está conectado.
Porque no están instalados los controladores.
Porque está en uso. (Puerto abierto)
O porque los controladores instalados no son los correctos para el sistema.
Verifica lo anterior, entrando al Administrador de dispositivos.
Sección: Puertos (COM y LPT)
Si al conectar el dispositivo asignado al COM4, aparece un signo ! en amarillo, es porque existe un problema y entrando a sus propiedades podrás determinar la causa.
Esto es en el caso de usar Windows.
Lupa Arduino y Raspberry Pi
