Foros de Electrónica
Osciloscopio con la tarjeta de sonido
#1  Osciloscopio con la tarjeta de sonido
guimar
citar
Se que existen programitas para simular con la tarjeta de sonido un osciloscopio.
Me podias indicar cuales son?
Y cual de ellos es el mejor?
Gracias y saludos.
#2
Li-ion
citar
Hola, yo utilizo el Oscilloscope for Windows v. 2.51
El cual tienes las siguientes caracteristicas: (Copia del archivo de ayuda)
Cita:
Oscilloscope for Windows uses the sound card as an analog-to-digital
converter, providing complete oscilloscope and spectrum analyzer
functionality in Windows95 environment.
Specifications:
- Dual trace digital storage oscilloscope with spectrum analyzer
- 20 Hz - 20 kHz bandwidth
- 50 ms buffer length
- data export to Windows clipboard or to file (text format)
Features:
- single and dual trace mode
- XY mode (Lissajous patterns)
- point-and-click waveform and spectrum meter functions
- cross-correlation coefficient measurement
- storage tube emulation
- pretrigger view and armed triggering
System requirements:
- 80486 or higher PC running Windows95
- any sound card with drivers installed
- 300 kbytes disk free space during installation, 150 kbytes for operation
Installing Oscilloscope for Windows:
No special installation procedure required.
Unpack all the files from osc251.zip, and create shortcut to winscope.exe.
Winscope.exe and winscope.hlp should be in the same directory.
Operating Oscilloscope:
To start, click On Line ("play") button and speak in the microphone.
To freeze plots, click Hold ("pause") button.
Refer to help file for more details.
Uninstalling Oscilloscope:
Delete any shortcuts to winscope.exe. Delete winscope.exe and winscope.hlp.
If winscope.ini configuration file exists in your Windows directory,
also delete it.
Changes in version 2.51:
XY Plot mode bug has been fixed. (XY Plot was unusable in v. 2.50).
Legal issues:
Oscilloscope for Windows is free for personal use and can be redistributed
provided it is not changed in any way and no fee is requested.
Terms for including Oscilloscope into any software packages are available
from the author at the address given below.
Oscilloscope is supplied on "as is" basis; use at your own risk.
Always follow safety procedures when working with electric circuits.
For more on these issues, see Help->Precautions and Help->Copyright.
Suggestions, questions and bug reports can be directed to the author,
Konstantin Zeldovich, Any your feedback is always welcome.
Y como se puede redistribuir, entonces lo adjunto al mensaje.
#3
AGIO
citar
Hola, yo he comenzado hace poco a buscar como hacerlo. El software no es mi problema, sino el hardware limitador. El circuito que aprendí en la facultad de entrada de un osciloscopio es muy parecido al de esta página
http://xoscope.sourceforge.net/hardware/hardware.html
La cuestión es que al simularlo no obtengo los resultados que busco y la verdad tampoco sé que voltajes maneja una placa de sonido. Con el esquemático de esta página obtengo justamente el recorte en los 12 V que dan los diodos, pero la verdad es que no sé si con 12 volts la placa ya se quemó. Estoy tratando de reducir la tensión reemplazando los 12 volts por 1 volt, ya que no recuerdo donde leí que la señal de entrada a la placa de sonido no puede superar el volt. La cuestión es que el diodo superior permite el paso de más de un volt y estoy tratando de averiguar como hago para que esto se corriga (es muy poco lo que supera). Es decir que el recorte no se produce en un volt exacto y no sé si eso se puede permitir. Cuando repase todo lo referente al diodo y encuentre una solución al tema la paso pero si alguién me ilumina acerca de si los valores a manejar son correctos, me harían un gran favor.
Saludos,
Omar.
#4
tasman33
citar
Hola Omar, El problema es que el cátodo de D1 está referenciado a +12v. Referencialo a +1.2 voltios.
La protección al negativo te puede producir un cierto recorte en el lado negativo de la señal ya que D2-R3 están conectado a tierra. Prueba coonectar R3 a -1 voltio.
Ojo con el interruptor X10... (S1), que multiplica por 10 la ganancia del op amp. con los valores mostrados en X1 divide entre dos y en X10 m8ltiplica por 5. Prueba cambiando R5 a 4.7k y R4 a 510 ohms.
Lo ideal sería usar un osciloscopio bien calibrado y un generadoe de señales con más de 10 voltios P-P de salida para la puesta a punto. Usa, de ser posible señal triangular, para ver el punto de clipping o recorte.
Comentame los resultados.
Joaquín
#5
chuko
citar
Otra cosa, las placas de sonido tienen un capacitor de acople en cada entrada. Hay que cortocircuitarlo para poder adquirir señales continuas.
#6
AGIO
citar
Bueno gente...después de dos años, me acordé de este post que había hecho en el foro...más vale tarde que nunca... Les comento mis resultados del proyecto.... ¡Me compré un osciloscopio!... busqué por mucho tiempo algo "seguro" para mi placa de sonido pero nunca encontré nada de esas características y además comencé a incursionar en otras cosas de un par de Mhz y me quedaba corto con la placa de sonido. Igualmente, lo primero que hice al comprarme el osciloscopio fue poner un generador de tonos en la pc y enchufar el osciloscopio...Los resultados para una SB Audigy SE... desde los 10 Hz comienza a reproducir fielmente con unos 600mV pico a pico (este nivel depende de la configuración que tengan los niveles de playback...hay que fijarse como están) y a los 18Khz comienza a decrecer gradualmente el nivel de la señal (no me fijé el "corte" o la frecuencia de -3dB...pero a los 18Khz comienza a decrecer la tensión-esto sin ecualizador ni nada en software más que el tono funcionando, sólo reproducción de sonido pura). Por lo tanto, les puedo comunicar con esto que se necesitaría que los niveles de entrada si alguien realiza esta punta de prueba posteada, no superen los 300mV de pico (igualmente creo que puede aceptar bastante más). Otro tema aparte es que utilicé algunos programas que utilizan la placa de sonido como capturadora de datos y no "sonido" y anduvo bien, aunque sería recomendable que si uno quiere datos "buenos" habría que comprar una buena placa (M-audio es una marca reconocida en el campo y ESI también, hay más). Cualquier duda o cuestión no duden en preguntar si algo necesitan como medición. Saludos.
#7  Correción datos de salida Placa de sonido.
AGIO
citar
Corrigo datos que volví a testear hoy!
SALIDA PLACA DE SONIDO SOUND BLASTER LIVE AUDIGY SE = 1.75Volts pico!
Testeada con tono de 400Hz y quizás llege a 2Volts porque yo limite la salida WAV para evitar la saturación del amplificador hace un tiempo y el testeador de tonos no sé exactamente que control para el volumen utiliza.
Es decir, 3,5~3.6 a 4 Volts pico a pico.... esto indica la cantidad máxima que emite la placa de sonido por su salida out. Yo, en lo personal, supondría que resiste lo mismo a la entrada, pero no sabría decirlo ya que esta placa, que por cierto es muy decepcionante ya que el procesamiento lo hace el procesador (por eso tan barata para ser SB), contiene la línea line in junto con mic in y se elige por soft...yo no me arriesgaría a más de 1Volt pico a pico y con miedo.... Si alguien consigue los datos "oficiales" de Sound Blaster, estaría bueno los publiquen. Otro dato de interés, para los amplificadores integrados de audio, generalmente, más de 1volt pico a pico en su entrada, provoca saturación a la salida (recorte de cresta), quizás sea costumbre no más de 1Vpp.
Espero le sirva a alguien estos datos.Saludos.
 Responder
Google
 Temas de interés
No hay mensajes nuevos Osciloscopio en el PC
No hay mensajes nuevos Osciloscopio para PC - Etapa de Atenuación
No hay mensajes nuevos Osciloscopio por labview
No hay mensajes nuevos Osciloscopio con un pic y labview
No hay mensajes nuevos Probador de Controles Remotos
Foros de Electronica
