Mi saludo cordial amigos.
Tengo un problema al intentar generar el archivo HEX de este programa. Estoy usando PIC C Compiler y Proteus, el problema es que cuando intento hacer cambios en el programa y después de compilar me da lo siguiente:
*** Error 128 "Sensor.c" Line2(1,1): A #DEVICE requored before this line
1 Errors, 0 Warnings.
La verdad es que estoy ingresando a este mundo de programación de PICs. Agradeceré mucho vuestros consejos. El PIC es el 16F877A y el Display LCD es el LM016L.
Código:
// LCD module connections
sbit LCD_RS at RB2_bit;
sbit LCD_EN at RB3_bit;
sbit LCD_D4 at RB4_bit;
sbit LCD_D5 at RB5_bit;
sbit LCD_D6 at RB6_bit;
sbit LCD_D7 at RB7_bit;
sbit LCD_RS_Direction at TRISB2_bit;
sbit LCD_EN_Direction at TRISB3_bit;
sbit LCD_D4_Direction at TRISB4_bit;
sbit LCD_D5_Direction at TRISB5_bit;
sbit LCD_D6_Direction at TRISB6_bit;
sbit LCD_D7_Direction at TRISB7_bit;
// End LCD module connections
char txt1[] = "SENSOR SAT";
char txt2[] = "Desarrollado por....";
char txt3[] = "Cesar Moradel";
char txt4[] = "---------------";
char mtr1[] = "Alarma ";
char mtr2[] = "ON";
char mtr3[] = "OFF";
char wtr1[] = "Nivel: ";
char wtr2[] = "0.30";
char wtr3[] = "0.60";
char wtr4[] = "0.90";
char wtr5[] = "1.20";
char wtr6[] = "1.50";
void main()
int i = 0;
int c = 16;
int b = 0;
CMCON = 0x07;
ADCON1 = 0x06;
TRISA = 0x0F; // set direction to be input
PORTA = 0x00;
PORTD = 0x00;
PORTC = 0x00;
TRISB = 0x00; // set direction to be output
TRISC = 0x00; // set direction to be output
TRISD = 0x80; // set direction to be output
PORTD.F2 = 1;
PORTD.F7 = 1;
Lcd_Init(); // Initialize LCD
Lcd_Cmd(_LCD_CLEAR); // Clear display
Lcd_Cmd(_LCD_CURSOR_OFF); // Cursor off
Lcd_Out(1,1,txt1); // Write text in first row
Lcd_Out(2,1,txt2); // Write text in second row
Delay_ms(500);
Lcd_Out(1,1,txt3); // Write text in first row
Lcd_Out(2,1,txt4); // Write text in second row
Delay_ms(500);
// Moving text
for(i=0; i<15; i++)
{ // Move text to the right 16 times
Lcd_Cmd(_LCD_SHIFT_RIGHT);
Delay_ms(125);
i=0;
do
Lcd_Out(1,1,wtr1);
Lcd_Out(2,1,mtr1);
if(c>0)
PORTD.F2 = 1;
c--;
else
PORTD.F2 = 0;
if(b>0)
PORTD.F0 = 1;
Delay_ms(125);
PORTD.F0 = 0;
b--;
if(PORTD.F7 == 0)
c = 16;
if(PORTA == 0x0F)
PORTD.F1 = 1;
Lcd_Out(1,8,wtr2);
Lcd_Out(2,7,mtr3);
PORTC = 1;
if(i == 0)
c = 16;
b=3;
i=1;
else if(PORTA == 0x0E)
Lcd_Out(1,8,wtr3);
if(i == 1)
Lcd_Out(2,7,mtr3);
else
Lcd_Out(2,7,mtr2);
PORTC = 3;
else if(PORTA == 0x0C)
Lcd_Out(1,8,wtr4);
if(i == 1)
Lcd_Out(2,7,mtr3);
else
Lcd_Out(2,7,mtr2);
PORTC = 7;
else if(PORTA == 0x08)
Lcd_Out(1,8,wtr5);
if(i == 1)
Lcd_Out(2,7,mtr3);
else
Lcd_Out(2,7,mtr2);
PORTC = 15;
else if(PORTA == 0x00)
Lcd_Out(1,8,wtr6);
Lcd_Out(2,7,mtr2);
PORTD.F1 = 0;
if(i == 1)
c = 16;
b = 3;
i=0;
PORTC = 31;
else
PORTA = 0x0F;
Delay_ms(125);
}while(1); // Endless loop
