Control Remoto Infrarrojo para Hardware de 10 canales:
¿Alguien se siente capas de hacer esto?
Si alguien se le da bien el Inglés, podría traducir esto paso a paso.
Código:
; CPU configuration
	list P=16F84
	#include "p16f84.inc"
	__config _XT_OSC & _WDT_OFF & _PWRTE_ON
; Define variables at memory locations
; RAM
W_TMP		equ	H'0C'	; temporary store for w in interrupt
STATUS_TMP	equ	H'0D'	; temporary store of status in interrupt
REMOTE_M	equ	H'0E'	; remote control input ms byte
REMOTE_L	equ	H'0F'	; remote control input LS byte
REM_FLG		equ	H'10'	; flag to indicate current remote control sequencing
REM_CNT		equ	H'11'	; interrupt count for polling remote control signal
REM_COD		equ	H'12'	; remote control bit counter mode.
TOGGLE		equ	H'13'	; remote control toggle flag
FLAG0		equ	H'14'	; test flag 0
B_STAT		equ	H'15'	; B port input status at power up
A_STAT		equ	H'16'	; A port input status at power up
VALUE_1		equ	H'17'	; delay value
VALUE_2		equ	H'18'	; delay value
FLAG_RM		equ	H'19'	; flag to indicate continuous remote
TG_BIT		equ	H'1A'	; counter of number of incorrect toggle matches
FLG_HL		equ	H'1B'	; high or low remote control sign
; define reset and interrupt vector start addresses
	org	0	  	; start at address 0000h
	goto	MAIN		; normal service routines from Reset vector
	org     4		; interrupt vector 0004h, start interrupt routine here
	goto	INTRUPT
; start interrupt by saving w and status registers before altered by interrupt routine
INTRUPT movwf	W_TMP		; w to w_tmp storage
	swapf	STATUS,w	; status to w
	movwf	STATUS_TMP	; status in status_tmp
	bcf	STATUS,RP0	; select memory bank 0
; check interrupt
	btfsc	INTCON,T0IF	; TMRO overflow interrupt flag then goto counter
	goto	COUNTER		; TMRO overflow so increase counter
	goto	RECLAIM		; end of interrupt reclaim w and status
; adjust interrupt rate with counter
COUNTER	movlw	D'207'		; freq is 4MHz/4/2/50. = 100us
	addwf	TMR0,f		; add to timer register and takes 2 cycles to start counting
	bcf	INTCON,T0IF	; clear TMRO interrupt flag
; check if RA3 has gone low for start of remote control sequence
	btfss	FLAG0,0		; if flag set then test mode
	goto	RM_SQ		; remote sequence started?
	bcf	PORTA,1		;  * tracer for remote decode
	btfsc	REM_FLG,1	; is it the end of remote control sequence
	bcf	PORTA,0		; then clear RA0 stop start indicator
RM_SQ	btfsc	REM_FLG,0	; has remote control sequence started
	goto	REM_SEQ
	btfsc	PORTA,3		; is RA3 low
	goto	RECLAIM
	bsf	REM_FLG,0	; set beginning of remote control flag
	movlw	D'22'		; initial time period to wait till next start bit
	movwf	REM_CNT
	movlw	D'13'		; shift register counter
	movwf	REM_COD
	bsf	REMOTE_L,0	; set first bit in remote control sequence
	clrf	FLG_HL		; clear bit 1 in high low flag
	bsf	REM_FLG,7	; start bit flag set
	bsf	PORTA,2		; decode out (acknowledge LED driver)
	btfss	FLAG0,0		; if set then test mode
	goto	RECLAIM
	bsf	PORTA,1		; * tracer for decode (reads level at this point)
	bsf	PORTA,0		; * start/stop trace
	goto 	RECLAIM
REM_SEQ	btfsc	REM_FLG,1	; has it finished
	goto	RECLAIM
	decfsz	REM_CNT,f	; decrease interrupt counter for timing
	goto	CKEDGE		; check if change in level
	bcf	REM_FLG,7	; clear start bit flag
	movlw	D'18'		; 18 x 100us = 1.8ms or period between valid bits
	movwf	REM_CNT
	rlf	REMOTE_L,f	; least sig byte in remote control code sequence
	rlf	REMOTE_M,f	; most sig byte
	movf	PORTA,w		; check bit 3 portA
	andlw	B'00001000'	; mask out bits except bit 3
	movwf	FLG_HL		; place in flag
	btfsc	PORTA,3		; check if high or low
	goto	HI		; high so clear
	bsf	REMOTE_L,0	; if low set this bit
	bsf	PORTA,2		; if high clear this bit
	goto	BY_HI		; bypass high
HI	bcf	REMOTE_L,0	; clear 0 bit
	bcf	PORTA,2 	; acknowledge
BY_HI
	btfsc	FLAG0,0		; if set test mode
	decfsz	REM_COD,f	; decrease shift register count
	goto	RECLAIM
	bsf	REM_FLG,1	; set end of remote control decoding flag
	goto	RECLAIM
; align change in level (edge detect) with REM_CNT counter
CKEDGE	btfsc	REM_FLG,7	; start bit flag bypass edge detect as AGC level setting
	goto	RECLAIM
	movlw	B'00001000'	; select bit 3 for PORTA,3
	andwf	PORTA,w		; bit 3
	xorwf	FLG_HL,w	; compare PORTA,3 with FLAG (previous level)
	btfsc	STATUS,z	; Z=1 if zero then no change
	goto	RECLAIM		; no change
	andwf	PORTA,w		; bit 3 select
	movwf	FLG_HL		; reload new level
	movlw	0x3		; count of 3 for REM_CNT
	subwf	REM_CNT,w	; is REM_CNT larger or equal to 3
	btfss	STATUS,c
	goto	RECLAIM		; smaller than 3
	movf	REM_CNT,w
	sublw	0x6		; check if 6 or less
	btfss	STATUS,c
	goto	RECLAIM		; larger than 6
	movlw	0x4
	movwf	REM_CNT		; set REM_CNT to 4 to align with change in level
RECLAIM	swapf	STATUS_TMP,w	; status temp storage to w
	movwf	STATUS		; w to status register
	swapf	W_TMP,f		; swap upper and lower 4-bits in w_tmp
	swapf   W_TMP,w		; swap bits and into w register
	retfie			; return from interrupt
; RESET
; Set ports A & B
MAIN	clrf	REM_CNT		; remote control polling counter
	clrf	REM_FLG		; remote control flag status
	clrf	FLAG0		; test
	clrf	FLAG_RM		; continuous remote
	bsf	STATUS,RP0	; select memory bank 1
	movlw	B'11111111'	;  inputs
	movwf	TRISB		; port B data direction register
	movlw	B'10000000'	;
	movwf	OPTION_REG	; TMRO prescaler is 2, PORTB pullups disabled
	movlw   B'00011111'	;  (1's are inputs)
	movwf   TRISA		; A port data direction register
; check pin status
	btfss	PORTA,2		; if RA2 high set the test flag
	goto	IN_CK		; input check
	bsf	FLAG0,0		; set test routine (RA0 is start stop output for remote control)
				; (RA1 is tracer) RA2 normally gives decoded output for ACK LED
IN_CK	movf	PORTB,w		; portB input level (high is toggle, low is momentary)
	movwf	B_STAT		; port B status
	movf	PORTA,w		; look at RA1 and RA0
	movwf	A_STAT		; store in A status
	btfsc	FLAG0,0
	clrf	A_STAT		; clear bits 0 and 1 if in test mode (so momentary)
	bsf	A_STAT,2	; set bit 2 for acknowledge LED
	movlw	B'00000000'	;  outputs
	movlw	B'10000000'	;
	movlw   B'00011000'	;  (1's are inputs) RA0-2 outputs
	movlw	B'00000000'	; lows
	movwf	PORTB		; portB outputs low
	movlw	B'00000000'
	movwf	PORTA		; portA low
; interrupt enable
	bsf	INTCON,T0IE	; set interrupt enable for TMR0
	bsf	INTCON,GIE	; set global interrupt enable for above
; check remote codes
; delay
RM_CK	movlw	D'100'		; set delay period of about 120ms between codes
	movwf	VALUE_1		; VALUE_1 = w
	movlw	D'255'		; set delay period value 2
LP_1	movwf	VALUE_2		; VALUE_2 = w
LP_2	decfsz	VALUE_2,f	; decrease VALUE_2, skip if zero
	goto 	LP_2
	decfsz	VALUE_1,f	; decrease VALUE_1, skip if zero
	goto	LP_1
; remote control decoding
	btfss	REM_FLG,0	; remote control sequence started
	goto	CLR_RM1
	btfss	REM_FLG,1	; is remote control entered flag set
	goto	RM_CK
; count number of codes to delete end of code sequence if button held for several seconds
	btfss	FLAG_RM,0	; is continuous mode set
	goto	XFER
	movf	REMOTE_M,w
	andlw	B'00001000'	; toggle bit
	xorwf	TOGGLE,w	; is toggle bit the same as last time
	btfsc	STATUS,z	; if z is 1 then the same
	goto	XFER
	decfsz	TG_BIT,f	; toggle counter
	goto	BY_STO		; bypass storing toggle bit
	clrf	FLAG_RM		; clear continuous mode flag
XFER	movf	REMOTE_M,w
	andlw	B'00001000'	; get toggle bit
	movwf	TOGGLE		; store toggle bit
	movlw	D'06'
	movwf	TG_BIT		; count times that toggle bit different
BY_STO	movf	REMOTE_M,w	; most significant remote code
	andlw	B'00110111'	; mask out bit 7 and 6 and toggle bit 3
	xorlw	B'00110010'	; compare with start bits and ms 3-bits of address
	btfss	STATUS,z	; if zero then matching
	goto	CLR_RMF
; compare with address code out if invalid clear REM_FLG
; if valid check command bits and ls 2 address bits then clear REM_FLG
	btfss	PORTA,4		; check porta
	goto	SAT2
SAT1	movf	REMOTE_L,w	; least sig remote code
	xorlw	B'00000000'	; bits 0-5 keycode (0), bit 7 and bit 6 are ls address bits
	btfsc	STATUS,z
	goto	ZERO
	movf	REMOTE_L,w
	xorlw	B'00000001'	; bits 0-5 keycode (1), bit 7 and bit 6 are ls address bits
	btfsc	STATUS,z
	goto	ONE
	movf	REMOTE_L,w
	xorlw	B'00000010'	; bits 0-5 keycode (2), bit 7 and bit 6 are ls address bits
	btfsc	STATUS,z
	goto	TWO
	movf	REMOTE_L,w
	xorlw	B'00000011'	; bits 0-5 keycode (3), bit 7 and bit 6 are ls address bits
	btfsc	STATUS,z
	goto	THREE
	xorlw	B'00000100'	; bits 0-5 keycode (4), bit 7 and bit 6 are ls address bits
	btfsc	STATUS,z
	goto	FOUR
	movf	REMOTE_L,w
	xorlw	B'00000101'	; bits 0-5 keycode (5), bit 7 and bit 6 are ls address bits
	btfsc	STATUS,z
	goto	FIVE
	movf	REMOTE_L,w
	xorlw	B'00000110'	; bits 0-5 keycode (6), bit 7 and bit 6 are ls address bits
	btfsc	STATUS,z
	goto	SIX
	movf	REMOTE_L,w
	xorlw	B'00000111'	; bits 0-5 keycode (7), bit 7 and bit 6 are ls address bits
	btfsc	STATUS,z
	goto	SEVEN
	xorlw	B'00001000'	; bits 0-5 keycode (8), bit 7 and bit 6 are ls address bits
	btfsc	STATUS,z
	goto	EIGHT
	movf	REMOTE_L,w
	xorlw	B'00001001'	; bits 0-5 keycode (9), bit 7 and bit 6 are ls address bits
	btfsc	STATUS,z
	goto	NINE
	goto	CLR_RMF
SAT2	movf	REMOTE_L,w	; least sig remote code
	xorlw	B'10000000'	; bits 0-5 keycode (0), bit 7 and bit 6 are ls address bits
	btfsc	STATUS,z
	goto	ZERO
	movf	REMOTE_L,w
	xorlw	B'10000001'	; bits 0-5 keycode (1), bit 7 and bit 6 are ls address bits
	btfsc	STATUS,z
	goto	ONE
	movf	REMOTE_L,w
	xorlw	B'10000010'	; bits 0-5 keycode (2), bit 7 and bit 6 are ls address bits
	btfsc	STATUS,z
	goto	TWO
	movf	REMOTE_L,w
	xorlw	B'10000011'	; bits 0-5 keycode (3), bit 7 and bit 6 are ls address bits
	btfsc	STATUS,z
	goto	THREE
	xorlw	B'10000100'	; bits 0-5 keycode (4), bit 7 and bit 6 are ls address bits
	btfsc	STATUS,z
	goto	FOUR
	movf	REMOTE_L,w
	xorlw	B'10000101'	; bits 0-5 keycode (5), bit 7 and bit 6 are ls address bits
	btfsc	STATUS,z
	goto	FIVE
	movf	REMOTE_L,w
	xorlw	B'10000110'	; bits 0-5 keycode (6), bit 7 and bit 6 are ls address bits
	btfsc	STATUS,z
	goto	SIX
	movf	REMOTE_L,w
	xorlw	B'10000111'	; bits 0-5 keycode (7), bit 7 and bit 6 are ls address bits
	btfsc	STATUS,z
	goto	SEVEN
	xorlw	B'10001000'	; bits 0-5 keycode (8), bit 7 and bit 6 are ls address bits
	btfsc	STATUS,z
	goto	EIGHT
	movf	REMOTE_L,w
	xorlw	B'10001001'	; bits 0-5 keycode (9), bit 7 and bit 6 are ls address bits
	btfsc	STATUS,z
	goto	NINE
	goto	CLR_RMF
CLR_RM1	clrf	FLAG_RM		; clear continuous mode flag
CLR_RMF	clrf	REM_FLG		; remote flag cleared
	bcf	PORTA,2		; decoder out
	btfsc	FLAG_RM,0	; if set then already passed here
	goto	RM_CK
	movf	A_STAT,w	; check portA status (high is toggle so anding will keep status)
	andwf	PORTA,f		; clear all momentary outputs keep toggles at current status
	movf	B_STAT,w
	andwf	PORTB,f
	goto	RM_CK
	bcf	PORTA,1		; * tracer out
	bcf	PORTA,0		; * start stop for decoder
	goto	RM_CK
ZERO	btfsc	FLAG0,0		; if set then test mode
	goto	CLR_RMF
	goto	CLR_RMF
	btfsc	A_STAT,1	; if set then toggle
	goto	TOG_0		; toggle (alternate mode)
	bsf	PORTA,1		; output high
	bsf	FLAG_RM,0	; set continuous mode
	goto	CLR_RMF
TOG_0	btfsc	PORTA,1		; if high clear
	goto	CLR_0
	bsf	PORTA,1		; low so set
	bsf	FLAG_RM,0	; ready for next remote control input
	goto	CLR_RMF
CLR_0	bcf	PORTA,1		; high so clear
	goto	CLR_RMF
ONE	btfsc	FLAG0,0		; if set then test mode
	goto	CLR_RMF
	goto	CLR_RMF
	btfsc	A_STAT,0	; if set then toggle
	goto	TOG_1		; toggle (alternate mode)
	bsf	PORTA,0		; output high
	goto	CLR_RMF
TOG_1	btfsc	PORTA,0		; if high clear
	goto	CLR_1
	bsf	PORTA,0		; low so set
	goto	CLR_RMF
CLR_1	bcf	PORTA,0		; high so clear
	goto	CLR_RMF
TWO	btfsc	FLAG_RM,0	; if set then already passed here
	goto	CLR_RMF
	btfsc	B_STAT,7	; if set then toggle
	goto	TOG_2		; toggle (alternate mode)
	bsf	PORTB,7		; 2 output high
	goto	CLR_RMF
TOG_2	btfsc	PORTB,7		; if high clear
	goto	CLR_2
	bsf	PORTB,7		; low so set
	goto	CLR_RMF
CLR_2	bcf	PORTB,7		; high so clear
	goto	CLR_RMF
THREE	btfsc	FLAG_RM,0	; if set then already passed here
	goto	CLR_RMF
	btfsc	B_STAT,6	; if set then toggle
	goto	TOG_3		; toggle (alternate mode)
	bsf	PORTB,6		; output high
	goto	CLR_RMF
TOG_3	btfsc	PORTB,6		; if high clear
	goto	CLR_3
	bsf	PORTB,6		; low so set
	goto	CLR_RMF
CLR_3	bcf	PORTB,6		; high so clear
	goto	CLR_RMF
FOUR	btfsc	FLAG_RM,0	; if set then already passed here
	goto	CLR_RMF
	btfsc	B_STAT,5	; if set then toggle
	goto	TOG_4		; toggle (alternate mode)
	bsf	PORTB,5		; output high
	goto	CLR_RMF
TOG_4	btfsc	PORTB,5		; if high clear
	goto	CLR_4
	bsf	PORTB,5		; low so set
	goto	CLR_RMF
CLR_4	bcf	PORTB,5		; high so clear
	goto	CLR_RMF
FIVE	btfsc	FLAG_RM,0	; if set then already passed here
	goto	CLR_RMF
	btfsc	B_STAT,4	; if set then toggle
	goto	TOG_5		; toggle (alternate mode)
	bsf	PORTB,4		; output high
	goto	CLR_RMF
TOG_5	btfsc	PORTB,4		; if high clear
	goto	CLR_5
	bsf	PORTB,4		; low so set
	goto	CLR_RMF
CLR_5	bcf	PORTB,4		; high so clear
	goto	CLR_RMF
SIX	btfsc	FLAG_RM,0	; if set then already passed here
	goto	CLR_RMF
	btfsc	B_STAT,3	; if set then toggle
	goto	TOG_6		; toggle (alternate mode)
	bsf	PORTB,3		; output high
	goto	CLR_RMF
TOG_6	btfsc	PORTB,3		; if high clear
	goto	CLR_6
	bsf	PORTB,3		; low so set
	goto	CLR_RMF
CLR_6	bcf	PORTB,3		; high so clear
	goto	CLR_RMF
SEVEN	btfsc	FLAG_RM,0	; if set then already passed here
	goto	CLR_RMF
	btfsc	B_STAT,2	; if set then toggle
	goto	TOG_7		; toggle (alternate mode)
	bsf	PORTB,2		; output high
	goto	CLR_RMF
TOG_7	btfsc	PORTB,2		; if high clear
	goto	CLR_7
	bsf	PORTB,2		; low so set
	goto	CLR_RMF
CLR_7	bcf	PORTB,2		; high so clear
	goto	CLR_RMF
EIGHT	btfsc	FLAG_RM,0	; if set then already passed here
	goto	CLR_RMF
	btfsc	B_STAT,1	; if set then toggle
	goto	TOG_8		; toggle (alternate mode)
	bsf	PORTB,1		; output high
	goto	CLR_RMF
TOG_8	btfsc	PORTB,1		; if high clear
	goto	CLR_8
	bsf	PORTB,1		; low so set
	goto	CLR_RMF
CLR_8	bcf	PORTB,1		; high so clear
	goto	CLR_RMF
NINE	btfsc	FLAG_RM,0	; if set then already passed here
	goto	CLR_RMF
	btfsc	B_STAT,0	; if set then toggle
	goto	TOG_9		; toggle (alternate mode)
	bsf	PORTB,0		; output high
	goto	CLR_RMF
TOG_9	btfsc	PORTB,0		; if high clear
	goto	CLR_9
	bsf	PORTB,0		; low so set
	goto	CLR_RMF
CLR_9	bcf	PORTB,0		; high so clear
	goto	CLR_RMF
	end
Fuente:
http://www.fullcustom.es/mod2_rehw.html
Probando en el MPLAB 8.10 me da error.
Debug build of project `C:\Documents and Settings\Hunter\Escritorio\pic_ird.disposable_mcp' started.
Preprocessor symbol `__DEBUG' is defined.
Fri Oct 17 02:37:49 2008
Clean: Deleting intermediary and output files.
Clean: Deleted file "C:\Documents and Settings\Hunter\Escritorio\pic_ird.mcs".
Clean: Done.
Executing: "C:\Archivos de programa\Microchip\MPASM Suite\MPASMWIN.exe" /q /p16F84 "pic_ird.ASM" /l"pic_ird.lst" /e"pic_ird.err" /d__DEBUG=1
Error[113] C:\DOCUMENTS AND SETTINGS\HUNTER\ESCRITORIO\PIC_IRD.ASM 125 : Symbol not previously defined (z)
Error[113] C:\DOCUMENTS AND SETTINGS\HUNTER\ESCRITORIO\PIC_IRD.ASM 132 : Symbol not previously defined (c)
Error[113] C:\DOCUMENTS AND SETTINGS\HUNTER\ESCRITORIO\PIC_IRD.ASM 136 : Symbol not previously defined (c)
Message[302] C:\DOCUMENTS AND SETTINGS\HUNTER\ESCRITORIO\PIC_IRD.ASM 160 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\DOCUMENTS AND SETTINGS\HUNTER\ESCRITORIO\PIC_IRD.ASM 162 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\DOCUMENTS AND SETTINGS\HUNTER\ESCRITORIO\PIC_IRD.ASM 164 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\DOCUMENTS AND SETTINGS\HUNTER\ESCRITORIO\PIC_IRD.ASM 182 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\DOCUMENTS AND SETTINGS\HUNTER\ESCRITORIO\PIC_IRD.ASM 184 : Register in operand not in bank 0. Ensure that bank bits are correct.
Message[302] C:\DOCUMENTS AND SETTINGS\HUNTER\ESCRITORIO\PIC_IRD.ASM 186 : Register in operand not in bank 0. Ensure that bank bits are correct.
Error[113] C:\DOCUMENTS AND SETTINGS\HUNTER\ESCRITORIO\PIC_IRD.ASM 226 : Symbol not previously defined (z)
Error[113] C:\DOCUMENTS AND SETTINGS\HUNTER\ESCRITORIO\PIC_IRD.ASM 240 : Symbol not previously defined (z)
Error[113] C:\DOCUMENTS AND SETTINGS\HUNTER\ESCRITORIO\PIC_IRD.ASM 251 : Symbol not previously defined (z)
Error[113] C:\DOCUMENTS AND SETTINGS\HUNTER\ESCRITORIO\PIC_IRD.ASM 255 : Symbol not previously defined (z)
Error[113] C:\DOCUMENTS AND SETTINGS\HUNTER\ESCRITORIO\PIC_IRD.ASM 259 : Symbol not previously defined (z)
Error[113] C:\DOCUMENTS AND SETTINGS\HUNTER\ESCRITORIO\PIC_IRD.ASM 263 : Symbol not previously defined (z)
Error[113] C:\DOCUMENTS AND SETTINGS\HUNTER\ESCRITORIO\PIC_IRD.ASM 267 : Symbol not previously defined (z)
Error[113] C:\DOCUMENTS AND SETTINGS\HUNTER\ESCRITORIO\PIC_IRD.ASM 271 : Symbol not previously defined (z)
Error[113] C:\DOCUMENTS AND SETTINGS\HUNTER\ESCRITORIO\PIC_IRD.ASM 275 : Symbol not previously defined (z)
Error[113] C:\DOCUMENTS AND SETTINGS\HUNTER\ESCRITORIO\PIC_IRD.ASM 279 : Symbol not previously defined (z)
Error[113] C:\DOCUMENTS AND SETTINGS\HUNTER\ESCRITORIO\PIC_IRD.ASM 283 : Symbol not previously defined (z)
Error[113] C:\DOCUMENTS AND SETTINGS\HUNTER\ESCRITORIO\PIC_IRD.ASM 287 : Symbol not previously defined (z)
Error[113] C:\DOCUMENTS AND SETTINGS\HUNTER\ESCRITORIO\PIC_IRD.ASM 295 : Symbol not previously defined (z)
Error[113] C:\DOCUMENTS AND SETTINGS\HUNTER\ESCRITORIO\PIC_IRD.ASM 299 : Symbol not previously defined (z)
Error[113] C:\DOCUMENTS AND SETTINGS\HUNTER\ESCRITORIO\PIC_IRD.ASM 303 : Symbol not previously defined (z)
Error[113] C:\DOCUMENTS AND SETTINGS\HUNTER\ESCRITORIO\PIC_IRD.ASM 307 : Symbol not previously defined (z)
Error[113] C:\DOCUMENTS AND SETTINGS\HUNTER\ESCRITORIO\PIC_IRD.ASM 311 : Symbol not previously defined (z)
Error[113] C:\DOCUMENTS AND SETTINGS\HUNTER\ESCRITORIO\PIC_IRD.ASM 315 : Symbol not previously defined (z)
Error[113] C:\DOCUMENTS AND SETTINGS\HUNTER\ESCRITORIO\PIC_IRD.ASM 319 : Symbol not previously defined (z)
Error[113] C:\DOCUMENTS AND SETTINGS\HUNTER\ESCRITORIO\PIC_IRD.ASM 323 : Symbol not previously defined (z)
Error[113] C:\DOCUMENTS AND SETTINGS\HUNTER\ESCRITORIO\PIC_IRD.ASM 327 : Symbol not previously defined (z)
Error[113] C:\DOCUMENTS AND SETTINGS\HUNTER\ESCRITORIO\PIC_IRD.ASM 331 : Symbol not previously defined (z)
Halting build on first failure as requested.
Debug build of project `C:\Documents and Settings\Hunter\Escritorio\pic_ird.disposable_mcp' failed.
Fri Oct 17 02:37:50 2008
BUILD FAILED
hola, me pueden decir para que /o que funcion cumplen esas r que hay a continuacion de cada salida y parecen tener un interrupotor (que no se ven en la foto) que la conmuta o con +vcc o con masa.....
las miro de arriba, de abajo y de costado y no les encuentro motivo de ser .
seran dip switchs de programacion (por eso no estan en el frente ) y ese port tiene doble funcion ?
no me parece la mejor configuracion para hacer eso.........
no se , que opinan que sea y para que ?
Buen proyecto amigo yo tengo algunos de esos PIC que me quedaron de cuando estudié en la U. Intentaré hacerlo se ve sencillo... lo complicado seria editar el programa para que trabaje con cualquier control.
