Hola,
estoy intentando programar un modulo mrf24j40mb con un atmega8l para obtener el valor RSSI de la señal enviada, pero no lo consigo. A continuación dejo el código, creo que el problema esta en la asignación de canal libre o en el coordinador PAN. Muchas gracias por vuestro tiempo.
#include <mega8.h>
#include <stdlib.h>
#include "WifiHeader.h"
int measurement_number=0;
char message_number=0;//count messages in one measurement
//unsigned int mask;
unsigned char byte;
Message *pointer,*current;//pointer to struct "Message" (equal to one measurement)
bit process_started=0;
bit wait=0;//for module B waiting
bit sleep_enabled=0;
bit start_comm=0;
bit no_response=0;
bit mem_full=0;
bit message_send=0;
bit retransmit=0;
bit end=0;
bit process_initiated=0;
unsigned char clock_timeout=0; //for time measurement
unsigned char clock_counter=CLOCK_FREQUENCY;
unsigned char frame_lenght;
unsigned int rx_adress;
// External Interrupt 0 service routine
interrupt [EXT_INT0] void ext_int0_isr(void)
MCUCR=0x00;//disable sleep
GICR&=0x3F; //disable INT1 and INT2
wake_wifi();
GIFR=0xC0;
MEM_FULL_LED=1; //start pressed indication
FINISH_LED=1; //start pressed indication
NO_RESPONSE_LED=1; //start pressed indication, now 3 diodes, not all 4
process_initiated=1; //start pressed indication
start_comm=1;
sleep_enabled=0;
GIFR|=0x40;
// External Interrupt 1 service routine
interrupt [EXT_INT1] void ext_int1_isr(void)
writeByte(0x39,0x04);//BBREG1,RXDECINV set to prevent recieving while reading
byte=readByte(0x31);//INTSTAT, clear interrupt
byte=readLongByte(0x300);
frame_lenght=byte-HEADER_LENGHT-2;
if(frame_lenght==1)
rx_adress=0x300+byte;
byte=readLongByte(0x308);
if(byte==0x66)
wait=0;//communication succesfull
retransmit=0;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
if(process_initiated)
MEM_FULL_LED=0;
FINISH_LED=0;
NO_RESPONSE_LED=0;
PROCESS_STARTED_LED=1;
process_started=1;
}else if(!wait) //if there was measurement start byte
pointer->lqi_B[message_number]=readLongByte(0x308);
pointer->rssi_B[message_number]=readLongByte(0x309);
message_send=0;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
GIFR=0x80;
GICR|=0x80; //enable only INT1
writeByte(0x39,0x00);//BBREG1,RXDECINV not set to allow recieving
//Delay_ms(3);
// Timer 1 output compare A interrupt service routine
interrupt [TIM1_COMPA] void timer1_compa_isr(void)
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
clock_counter--;
if(!clock_counter)
MEM_FULL_LED=0;
FINISH_LED=0;
NO_RESPONSE_LED=0;
if(clock_timeout)
clock_timeout--;
if(!clock_timeout)
if(process_started)
PROCESS_STARTED_LED=0;
process_started=0;
if(no_response)
no_response=0;
NO_RESPONSE_LED=0;
wait=0;//clock_timeout is already 0
sleep_enabled=1;
if(mem_full)
MEM_FULL_LED=0;
mem_full=0;
sleep_enabled=1;
if(end)
FINISH_LED=0;
end=0;
sleep_enabled=1;
if(wait)
NO_RESPONSE_LED=1;
no_response=1;
clock_timeout=6;//3sec
TCCR1B=0x05;
if(message_send)
message_send=0;
NO_RESPONSE_LED=1;
no_response=1;
TCCR1B=0x05;
else
TCCR1B=0x05;//nothing to report
if(retransmit)
retransmit=0;
TCCR1B=0x05;
}else TCCR1B=0x05;
void destruct(Message *deleted)
if(measurement_number>1)
while(deleted->previous)
current=deleted->previous;
deleted=current;
free(current->next);
free(deleted);
}else if(measurement_number==1)
free(deleted);
void main(void)
// Declare your local variables here
// Input/Output Ports initialization
// Port B initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=Out
// State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=0
PORTB=0x00;
DDRB=0x01;
// Port C initialization
// Func6=In Func5=In Func4=In Func3=In Func2=Out Func1=In Func0=In
// State6=T State5=T State4=T State3=T State2=0 State1=T State0=T
PORTC=0x10;
DDRC=0x0E;
// Port D initialization
// Func7=In Func6=In Func5=Out Func4=Out Func3=Out Func2=In Func1=Out Func0=In
// State7=T State6=P State5=0 State4=0 State3=0 State2=P State1=0 State0=T
PORTD=0x4C;
DDRD=0x72;
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: Timer 0 Stopped
TCCR0=0x00;
TCNT0=0x00;
// Timer/Counter 1 initialization
// Clock value: 0.977 kHz
// Mode: Normal top=FFFFh
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer 1 Overflow Interrupt: Off
// Input Capture Interrupt: Off
// Compare A Match Interrupt: On
// Compare B Match Interrupt: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x01;
OCR1AL=0xE8;//pola s
OCR1BH=0x00;
OCR1BL=0x00;
// External Interrupt(s) initialization
// INT0: On
// INT0 Mode: Low level
// INT1: Low level
//GIMSK|=0x40;
GICR&=0x3F; //disable interrupt
MCUCR=0x00;
GIFR=0xC0;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x10;
// Global enable interrupts
#asm("sei")
CSN=1;
delaySPI();
SCLK=0; //iddle when low
MEM_FULL_LED=0;
FINISH_LED=0;
NO_RESPONSE_LED=0;
wake_wifi();
initialize();
byte=readByte(0x31);//intstat read, clear interrupts
//sleep_wifi();
sleep_MCU();
while(1)
int i;
if(start_comm)
//start timer1
TCCR1B=0x05;
clock_timeout=20;
while(clock_timeout && (!no_response) && (!process_started))
writeByte(0x39,0x04);//BBREG1,RXDECINV set to prevent recieving while transmitting
SREG&=0x7F;//disable interrupts
writeByte(0x0D,0x25);//RXFLUSH //WAKE low polarity ,only data packet recieved
SREG|=0x80;//enable interrupts
GICR|=0x80;//enable interrupt 1, message recieved
retransmit=1;
wait=1;
transmit(1,pointer);
while(retransmit);
start_comm=0;
if(sleep_enabled)
sleep_enabled=0;
//sleep_wifi();
sleep_MCU();
if(process_started)
TCCR1B=0x05;
while(process_started);//3 sec delay
pointer=(Message*)malloc(sizeof(Message));
if(pointer)
measurement_number++;
pointer->previous=0;
else
pointer->previous=current;
current->next=pointer;
message_number=0;
for(i=0;i<10;i++)
pointer->n_message=measurement_number;
pointer->lqi_A[message_number]=readLongByte(0x310);
pointer->rssi_A[message_number]=readLongByte(0x311);
transmit(2,pointer);
message_send=1;
clock_timeout=6;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
TCCR1B=0x05;
message_number++;
while(message_send);
TCCR1B=0x00;
pointer->next=0;
current=pointer;
clock_timeout=6;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
TCCR1B=0x05;
FINISH_LED=1;
else
MEM_FULL_LED=1;
mem_full=1;
clock_counter=6;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
TCCR1B=0x05;
while(mem_full)
if(!DESTRUCT)
mem_full=0;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
destruct(pointer); //clear memory
MEM_FULL_LED=0;
sleep_enabled=1;
#include <mega8.h>
#include <stdlib.h>
unsigned char byte;
bit start_comm=0;
bit no_response=0;
bit mem_full=0;
bit message_send=0;
bit retransmit=0;
bit end=0;
wake_wifi();
GIFR=0xC0;
start_comm=1;
sleep_enabled=0;
GIFR|=0x40;
if(frame_lenght==1)
if(byte==0x66)
retransmit=0;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
MEM_FULL_LED=0;
FINISH_LED=0;
NO_RESPONSE_LED=0;
process_started=1;
message_send=0;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
GIFR=0x80;
//Delay_ms(3);
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
clock_counter--;
if(!clock_counter)
MEM_FULL_LED=0;
FINISH_LED=0;
NO_RESPONSE_LED=0;
if(clock_timeout)
clock_timeout--;
if(!clock_timeout)
if(process_started)
process_started=0;
if(no_response)
no_response=0;
NO_RESPONSE_LED=0;
sleep_enabled=1;
if(mem_full)
MEM_FULL_LED=0;
mem_full=0;
sleep_enabled=1;
if(end)
FINISH_LED=0;
end=0;
sleep_enabled=1;
if(wait)
NO_RESPONSE_LED=1;
no_response=1;
TCCR1B=0x05;
if(message_send)
message_send=0;
NO_RESPONSE_LED=1;
no_response=1;
TCCR1B=0x05;
else
if(retransmit)
retransmit=0;
TCCR1B=0x05;
}else TCCR1B=0x05;
deleted=current;
free(deleted);
free(deleted);
void main(void)
PORTB=0x00;
DDRB=0x01;
PORTC=0x10;
DDRC=0x0E;
PORTD=0x4C;
DDRD=0x72;
TCCR0=0x00;
TCNT0=0x00;
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x01;
OCR1BH=0x00;
OCR1BL=0x00;
// INT0: On
// INT1: Low level
//GIMSK|=0x40;
MCUCR=0x00;
GIFR=0xC0;
TIMSK=0x10;
#asm("sei")
CSN=1;
delaySPI();
MEM_FULL_LED=0;
FINISH_LED=0;
NO_RESPONSE_LED=0;
wake_wifi();
initialize();
//sleep_wifi();
sleep_MCU();
while(1)
int i;
if(start_comm)
//start timer1
TCCR1B=0x05;
clock_timeout=20;
retransmit=1;
wait=1;
while(retransmit);
start_comm=0;
if(sleep_enabled)
sleep_enabled=0;
//sleep_wifi();
sleep_MCU();
if(process_started)
TCCR1B=0x05;
if(pointer)
else
message_number=0;
for(i=0;i<10;i++)
message_send=1;
clock_timeout=6;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
TCCR1B=0x05;
message_number++;
TCCR1B=0x00;
pointer->next=0;
current=pointer;
clock_timeout=6;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
TCCR1B=0x05;
FINISH_LED=1;
else
MEM_FULL_LED=1;
mem_full=1;
clock_counter=6;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
TCCR1B=0x05;
while(mem_full)
if(!DESTRUCT)
mem_full=0;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
MEM_FULL_LED=0;
sleep_enabled=1;
