Hola gente de foro de electronica , recurro a uds para que me ayuden a correguir el siguiente codigo en matlab para la simulacion de un afinador. gracias.
Código:
clear all, clc;
x = 1;
while x == 1,
x = isempty (input ('Press enter to start program or press zero to quit. "));
ghighE = 1318.1505;
gB = 987.7669;
gG = 783.9911;
gD = 587.3297;
gA = 440;
glow = 329.6277;
guitar = [ghighE, gB, gG, gD, gA, glow];
if x == 1,
p = input ('Which are you Adjusting string? 1 = e 2 = B 3 = G 4 = D 5 = A 6 = E');
guitar w = (p)
y = isempty (input ('Press enter to record input signal or 0 to start over. "));
while y == 1,
% Input signal record
Fs = 44100;
T = 0:1: Fs/2-1;
I = wavrecord (Fs);
% To compare frequencies of a save file stored
Let's hear the % input signal
display ('This is how the input signal sounds.');
sound (I, Fs);
% Fft of input signal
J = fft (I) / size (I, 1);
K = 0:1: Fs/2-1;
if p == 6
for i = 400: size (J, 1)
J (i, 1) = 0;
end
else
for i = 1500: size (J, 1)
J (i, 1) = 0;
end
end
% Plotting
subplot (2,1,1), plot (I);
subplot (2,1,2), plot (K, 2 * real (J (1: Fs / 2)));
if p == 6
axis ([200 500 -0.01 0.01])
J (i, 1) = 0;
end
elseif p == 5
axis ([400 550 -0.01 0.01])
for i = 550: size (J, 1)
J (i, 1) = 0;
end
elseif p == 4
axis ([450 700 -0.01 0.01])
for i = 700: size (J, 1)
J (i, 1) = 0;
end
elseif p == 3
axis ([650 850 -0.01 0.01])
for i = 900: size (J, 1)
J (i, 1) = 0;
end
elseif p == 2
axis ([800 1100 -0.01 0.01])
for i = 1200: size (J, 1)
J (i, 1) = 0;
end
elseif p == 1
axis ([1200 1400 -0.01 0.01])
J (i, 1) = 0;
end
end
% Xlabel ('Frequency (Hz)') ylabel ('Amplitude (V)');
% Title ('input signal');
K = 0:1: (Fs/2-1);
(1.0015 * w)
K (find (J == max (J)))
(0.9985 * w)
z = ((K (find (J == max (J)))-w) / w) * 100;
if (1.0015 * w)> K (find (J == max (J )))&& (0.9985 * w) <K (find (J == max (J))),
display ('Perfect Intonation !!!');
disp (['The frequency of the input signal is,', num2str (K (find (J == max (J)))) 'Hz']);
fprintf ('Percent Error% d%% \ n', z)
elseif w> K (find (J == max (J))),
display ('Input Should Be INCREASED frequency');
elseif w <K (find (J == max (J))),
display ('Input Should Be Decreased frequency');
end
y = isempty (input ('Make needed adjustments and press enter to record a new input signal or 0 to start over. "));
if y == 1,
continue;
else x = 1;
end
end
end
end
