Hola,
He encontrado este código pero no sei como poner los datos del gps en el lugar convercion del codigo.
Datos gps en mi codigo:
SerIn2 PortD.1,188,2000,GetData,[wait("$GPRMC,"), skip 13, str gps\12]
En codigo:
LOOKUP X,["hellohel"],B0 '8bytes textsms that will be converted in Pdu bytes
¿Cómo puedo hacerlo?
Gracias.
'* Name : pdupic.BAS < TESTED on Pic 16fF628 > *
'* Author : (c)2004 Alexandros Zachariadis *
'* Notice : Converting sms between txt and pdu format is *
'* : actually a matter of "septet" to octet convertion *
'* : i.e: 7-bit data to 8-bit data and the oposite! *
'* Date : 18/3/2004 *
'* Version : 1.0c Final *
include "modedefs.bas"
DEFINE OSC 20 '20Mhz crystal
Define LCD_DREG PORTB 'Lcd D 4-bit parallel register starts at PortB.4 to PortB.7
Define LCD_DBIT 4
Define LCD_RSREG PORTB
Define LCD_RSBIT 2
Define LCD_EREG PORTB
Define LCD_EBIT 3
Define LCD_COMMANDUS 2000 ' Command Delay (uS)
Define LCD_DATAUS 50 ' Data Delay (uS)
DEFINE LCD_LINES 2
CMCON = %00000111 'PortA digital
;OPTION_REG.7 = 1 ' Disable PORTB pull-ups
clear
char VAR BYTE [8]'text data
pdu var byte [8]'pdu data
tmp var byte [8]'temporary array
ch var byte [8]'temporary array
b0 var byte
x VAR BYTE
;---------your code from here...------------------
;fill-in the array with test data
start:
FOR X=0 TO 7
CHAR(X)=B0
NEXT X
FOR X=0 TO 7
LOOKup2 X,[232,50,155,253,70,151,217],B0 'pdu data:E8329Bfd4697D9...
pdu(X)=B0
NEXT X
;output the conversion results to LCD { 1stline>pdu2txt , 2ndline>txt2pdu }
;the Lcd I had was 2x8 ,so I can output a few bytes only.
gosub pdu2txt
lcdout $fe,$1,char(0),char(1),char(2),char(3),char(4),char(5),char(6),char(7)
gosub txt2pdu
lcdout $fe,$c0,hex pdu(0),hex pdu(1),hex pdu(2),hex pdu(3)
loop:
goto loop
;---------your code until here.----------------------
;-----CONVERSION ROUTINES-------
;---TXT2PDU--(sms_encoding)-----
TXT2PDU:
tmp(1)=char(1) << 7
tmp(2)=char(2) << 6
tmp(3)=char(3) << 5
tmp(4)=char(4) << 4
tmp(5)=char(5) << 3
tmp(6)=char(6) << 2
tmp(7)=char(7) << 1
ch(0)=chaR(0)
ch(1)=chaR(1) >> 1
ch(2)=chaR(2) >> 2
ch(3)=chaR(3) >> 3
ch(4)=chaR(4) >> 4
ch(5)=chaR(5) >> 5
ch(6)=chaR(6) >> 6
pdu(0)=tmp(1) + ch(0)
pdu(1)=tmp(2) + ch(1)
pdu(2)=tmp(3) + ch(2)
pdu(3)=tmp(4) + ch(3)
pdu(4)=tmp(5) + ch(4)
pdu(5)=tmp(6) + ch(5)
pdu(6)=tmp(7) + ch(6)
RETURN
;---PDU2TXT--(sms_decoding)---
PDU2TXT:
tmp(0)=pdu(0) >> 7
tmp(1)=pdu(1) >> 6
tmp(2)=pdu(2) >> 5
tmp(3)=pdu(3) >> 4
tmp(4)=pdu(4) >> 3
tmp(5)=pdu(5) >> 2
tmp(6)=pdu(6) >> 1
ch(0)=pdu(0) & $7f
ch(1)=pdu(1) & $3f:CH(1)=CH(1) << 1
ch(2)=pdu(2) & $1f:CH(2)=CH(2) << 2
ch(3)=pdu(3) & $0f:CH(3)=CH(3) << 3
ch(4)=pdu(4) & $07:CH(4)=CH(4) << 4
ch(5)=pdu(5) & $03:CH(5)=CH(5) << 5
ch(6)=pdu(6) & $01:CH(6)=CH(6) << 6
char(0)=ch(0)
char(1)=ch(1) + tmp(0)
char(2)=ch(2) + tmp(1)
char(3)=ch(3) + tmp(2)
char(4)=ch(4) + tmp(3)
char(5)=ch(5) + tmp(4)
char(6)=ch(6) + tmp(5)
char(7)=tmp(6)
RETURN
END
