Error expected primary-expression before ',' token
Este es el error:
Código:
sketch_may26a:111:24: error: expected primary-expression before ',' token
  111 |   if (http.begin(Client, full_url));
Código:
C++:
#include <ESP8266HTTPClient.h>
#include <deprecated.h>
#include <MFRC522.h>
#include <MFRC522Extended.h>
#include <require_cpp11.h>
#include <Arduino.h>
#include <ESP8266WiFi.h>
#include <SPI.h>
#include <WiFiClient.h>
In the ESP8266, D3 pin is RST_PIN and
D4 pin is SS_PIN
#define RST_PIN D3
#define SS_PIN D4
MFRC522 reader(SS_PIN, RST_PIN);
MFRC522::MIFARE_Key key;
// Credentials to connect to the wifi network
const char *ssid = "Hola";
const char *password = "291203";
The ip or server address. If you are on localhost, put your computer's IP (for example http://192.168.1.65)
If the server is online, put the server's domain for example Sitio oficial de Luis Cabrera Benito (parzibyte)
const String SERVER_ADDRESS = "http://190.94.18.219/asistencia-php-rfid";
void setup()
  // Connect to wifi
  WiFi.begin(ssid, password);
  while (WiFi.status() != WL_CONNECTED)
    delay(1000);
  SPI.begin();
  reader.PCD_Init();
  // Just wait some seconds...
  delay(4);
  // Prepare the security key for the read and write functions.
  // Normally it is 0xFFFFFFFFFFFF
  // Note: 6 comes from MF_KEY_SIZE in MFRC522.h
  for (byte i = 0; i < 6; i++)
    key.keyByte = 0xFF; //keyByte is defined in the "MIFARE_Key" 'struct' definition in the .h file of the library
void loop()
  // If not connected, we don't need to read anything, that would be unnecessary
  if (WiFi.status() != WL_CONNECTED)
    return;
  // But, if there is a connection we check if there's a new card to read
  // Reset the loop if no new card present on the sensor/reader. This saves the entire process when idle.
  if (!reader.PICC_IsNewCardPresent())
    return;
  // Select one of the cards. This returns false if read is not successful; and if that happens, we stop the code
  if (!reader.PICC_ReadCardSerial())
    return;
    At this point we are sure that: there is a card that can be read, and there's a
    stable connection. So we read the id and send it to the server
  String serial = "";
  for (int x = 0; x < reader.uid.size; x++)
    // If it is less than 10, we add zero
    if (reader.uid.uidByte[x] < 0x10)
      serial += "0";
    // Transform the byte to hex
    serial += String(reader.uid.uidByte[x], HEX);
    // Add a hypen
    if (x + 1 != reader.uid.size)
      serial += "-";
  // Transformw to uppercase
  serial.toUpperCase();
  // Halt PICC
  reader.PICC_HaltA();
  // Stop encryption on PCD
  reader.PCD_StopCrypto1();
  HTTPClient http;
  // Send the tag id in a GET param
  const String full_url = "http://190.94.18.219/asistencia-php-rfid/rfid_register.php?serial=" + serial;
  if http.begin(Client, full_url);
  // Make request
  int httpCode = http.GET();
  if (httpCode > 0)
    if (httpCode == HTTP_CODE_OK)
      // const String &payload = http.getString().c_str(); //Get the request response payload
    else
  else
  http.end(); //Close connection
Que por cierto ese "IF" de la función que apunta el error no hace absolutamente nada de nada, bórrelo o, al menos, incluya la parte que falta que supongo que es la que verifica que la función funciono correctamente.
