Este es una practica muy sencilla del cual consta de aparecer un MENU en un GLCD.
Código:
//CONFIGURACION///////////////////
#include<16F886.h>
#include<stdio.h>
#fuses HS,NOWDT,NOPUT,MCLR,NOPROTECT,NOCPD,NOBROWNOUT,NOIESO,FCMEN,NOLVP,NODEBUG
#use delay(clock=20000000)
#use standard_io(c)
#define GLCD_CS1 PIN_B2 // Chip Selection 1
#define GLCD_CS2 PIN_B3 // Chip Selection 2
#define GLCD_DI PIN_B4 // Data or Instruction input
#define GLCD_RW PIN_B5 // Read/Write
#define GLCD_E PIN_B6 // Enable
#define GLCD_RST PIN_B7 // Reset
#include<GLCD.C>
char buff[25];
unsigned char y;
const char txt[][25]={"> STATUS OUTPUTS","> STATUS INPUTS","> STATUS PWM SERVOS","> STATUS DISTANCE",
"> MOVE SERVOS MANUAL","> CONFIG. SPEED","> CONFIG. DISTANCE","> ABOUT"};
const char out[]={"BACK"};
unsigned char out_in[9];
//MUESTRA EL CONTENIDO DEL MENU
void MENU(void){
glcd_fillscreen(OFF);
for(y=0;y<8;y++){
sprintf(buff,"%s",txt[y]);
glcd_text57(1,y*8,&buff,1,ON);
//OBTIENE TAMANO DE TEXTO DEL ARREGLO
int CLEAR_PUT_AUX(int v){
int vv=0;
while(txt[v][vv]!=0){
vv++;
return ++vv;
//PONE TEXTO ANTERIOR PARA
//RESTABLECERLO
void PUT_TEXT(int yy,int txtlen){
glcd_rect(1,(yy*8),(txtlen*5)+13,(yy*8)+7,ON,OFF);
sprintf(buff,"%s",txt[yy]);
glcd_text57(1,(yy*8),&buff,1,ON);
//SELECTOR DE OPCIONES
int SELECTOR(){
signed int sel=0;
while(TRUE){
if(input(PIN_A0)==1 || input(PIN_A1)==1){
if(input(PIN_A0)){
PUT_TEXT(sel,CLEAR_PUT_AUX(sel));
sel++;
if(sel>=8)sel=8;
}else if(input(PIN_A1)){
sel--;
if(sel<=0)sel=0;
glcd_rect(1,(sel*8),(CLEAR_PUT_AUX(sel)*5)+13,(sel*8)+7,ON,ON);
sprintf(buff,"%s",txt[sel]);
glcd_text57(1,(sel*8),&buff,1,OFF);
delay_ms(300);
if(input(PIN_A2)==1){
break;
return sel;
//VISUALIZA "SALIR"
void back(void){
glcd_rect(48,54,75,63,ON,ON);
sprintf(buff,"%s",out);
glcd_text57(49,55,&buff,1,OFF);
//SACA LOS BINARIOS DE LAS SALIDAS & ENTRADAS
//A CARACTERES
void BIN_C(unsigned int data){
unsigned int yy=0;
for(yy=0;yy<8;yy++){
if((data&0x01)==1)
out_in[yy]='1';
else
out_in[yy]='0';
data>>=1;
//STATUS SALIDA
void STATUS_SALIDA(void){
int p=0;
sprintf(buff,"%s",txt[0]);
glcd_text57(1,1,&buff,1,ON);
back();
while(TRUE){
BIN_C(p);
p++;
sprintf(buff,"%s",out_in);
glcd_rect(15,20,120,35,ON,OFF);
glcd_text57(15,21,&buff,2,ON);
delay_ms(500);
if(input(PIN_A0)==1)break;
//STATUS ENTRADAS
void STATUS_ENTRADA(void){
//MENU PRINCIPAL
void main(void){
int target;
set_tris_a(0x07);
setup_adc(ADC_OFF); //CONVERTIDOR ANALOGO-DIGITAL APAGADO
setup_comparator(NC_NC_NC_NC); //Comparadores APAGADO
glcd_init(ON);
while(TRUE){
MENU();
target=SELECTOR();
if(target==0)STATUS_SALIDA();
