include "P16F876.inc"
; Heap block 0, size:111 (0x00000110 - 0x0000017E)
__HEAP_BLOCK0_BANK EQU 0x00000002
__HEAP_BLOCK0_START_OFFSET EQU 0x00000010
__HEAP_BLOCK0_END_OFFSET EQU 0x0000007E
; Heap block 1, size:96 (0x00000190 - 0x000001EF)
__HEAP_BLOCK1_BANK EQU 0x00000003
__HEAP_BLOCK1_START_OFFSET EQU 0x00000010
__HEAP_BLOCK1_END_OFFSET EQU 0x0000006F
; Heap block 2, size:80 (0x000000A0 - 0x000000EF)
__HEAP_BLOCK2_BANK EQU 0x00000001
__HEAP_BLOCK2_START_OFFSET EQU 0x00000020
__HEAP_BLOCK2_END_OFFSET EQU 0x0000006F
; Heap block 3, size:44 (0x00000044 - 0x0000006F)
__HEAP_BLOCK3_BANK EQU 0x00000000
__HEAP_BLOCK3_START_OFFSET EQU 0x00000044
__HEAP_BLOCK3_END_OFFSET EQU 0x0000006F
gbl_status EQU 0x00000003 ; bytes:1
gbl_14_LSR EQU 0x00000020 ; bytes:4
gbl_float_detect_tininess EQU 0x00000039 ; bytes:1
gbl_float_rounding_mode EQU 0x0000003A ; bytes:1
gbl_float_exception_flags EQU 0x0000003B ; bytes:1
gbl_15_gbl_aSig EQU 0x00000024 ; bytes:4
gbl_15_gbl_bSig EQU 0x00000028 ; bytes:4
gbl_15_gbl_zSig EQU 0x0000002C ; bytes:4
gbl_15_gbl_aExp EQU 0x0000003C ; bytes:1
gbl_15_gbl_bExp EQU 0x0000003D ; bytes:1
gbl_15_gbl_zExp EQU 0x00000037 ; bytes:2
gbl_15_gbl_aSign EQU 0x0000003E ; bytes:1
gbl_15_gbl_bSign EQU 0x0000003F ; bytes:1
gbl_15_gbl_zSign EQU 0x00000040 ; bytes:1
gbl_15_gbl_zSigZero EQU 0x00000041 ; bytes:1
gbl_15_gbl_ret EQU 0x00000030 ; bytes:4
gbl_indf EQU 0x00000000 ; bytes:1
gbl_tmr0 EQU 0x00000001 ; bytes:1
gbl_pcl EQU 0x00000002 ; bytes:1
gbl_fsr EQU 0x00000004 ; bytes:1
gbl_porta EQU 0x00000005 ; bytes:1
gbl_portb EQU 0x00000006 ; bytes:1
gbl_portc EQU 0x00000007 ; bytes:1
gbl_pclath EQU 0x0000000A ; bytes:1
gbl_intcon EQU 0x0000000B ; bytes:1
gbl_pir1 EQU 0x0000000C ; bytes:1
gbl_pir2 EQU 0x0000000D ; bytes:1
gbl_tmr1l EQU 0x0000000E ; bytes:1
gbl_tmr1h EQU 0x0000000F ; bytes:1
gbl_t1con EQU 0x00000010 ; bytes:1
gbl_tmr2 EQU 0x00000011 ; bytes:1
gbl_t2con EQU 0x00000012 ; bytes:1
gbl_sspbuf EQU 0x00000013 ; bytes:1
gbl_sspcon EQU 0x00000014 ; bytes:1
gbl_ccpr1l EQU 0x00000015 ; bytes:1
gbl_ccpr1h EQU 0x00000016 ; bytes:1
gbl_ccp1con EQU 0x00000017 ; bytes:1
gbl_rcsta EQU 0x00000018 ; bytes:1
gbl_txreg EQU 0x00000019 ; bytes:1
gbl_rcreg EQU 0x0000001A ; bytes:1
gbl_ccpr2l EQU 0x0000001B ; bytes:1
gbl_ccpr2h EQU 0x0000001C ; bytes:1
gbl_ccp2con EQU 0x0000001D ; bytes:1
gbl_adresh EQU 0x0000001E ; bytes:1
gbl_adcon0 EQU 0x0000001F ; bytes:1
gbl_option_reg EQU 0x00000081 ; bytes:1
gbl_trisa EQU 0x00000085 ; bytes:1
gbl_trisb EQU 0x00000086 ; bytes:1
gbl_trisc EQU 0x00000087 ; bytes:1
gbl_pie1 EQU 0x0000008C ; bytes:1
gbl_pie2 EQU 0x0000008D ; bytes:1
gbl_pcon EQU 0x0000008E ; bytes:1
gbl_sspcon2 EQU 0x00000091 ; bytes:1
gbl_pr2 EQU 0x00000092 ; bytes:1
gbl_sspadd EQU 0x00000093 ; bytes:1
gbl_sspstat EQU 0x00000094 ; bytes:1
gbl_txsta EQU 0x00000098 ; bytes:1
gbl_spbrg EQU 0x00000099 ; bytes:1
gbl_adresl EQU 0x0000009E ; bytes:1
gbl_adcon1 EQU 0x0000009F ; bytes:1
gbl_eedata EQU 0x0000010C ; bytes:1
gbl_eeadr EQU 0x0000010D ; bytes:1
gbl_eedath EQU 0x0000010E ; bytes:1
gbl_eeadrh EQU 0x0000010F ; bytes:1
gbl_eecon1 EQU 0x0000018C ; bytes:1
gbl_eecon2 EQU 0x0000018D ; bytes:1
CompTempVar2188 EQU 0x00000042 ; bytes:1
CompTempVar2189 EQU 0x00000042 ; bytes:1
CompTempVar2190 EQU 0x00000042 ; bytes:1
CompTempVar2191 EQU 0x00000042 ; bytes:1
CompTempVar2192 EQU 0x00000042 ; bytes:1
CompTempVar2193 EQU 0x00000042 ; bytes:1
CompTempVar2194 EQU 0x00000042 ; bytes:1
CompTempVar2195 EQU 0x00000042 ; bytes:1
delay_ms_00000_arg_del EQU 0x00000043 ; bytes:1
delay_s_00000_arg_del EQU 0x00000042 ; bytes:1
Int1Context EQU 0x0000007F ; bytes:1
Int1BContext EQU 0x00000034 ; bytes:3
ORG 0x00000000
GOTO _startup
ORG 0x00000004
MOVWF Int1Context
SWAPF STATUS, W
BCF STATUS, RP0
BCF STATUS, RP1
MOVWF Int1BContext
SWAPF PCLATH, W
MOVWF Int1BContext+D'1'
SWAPF FSR, W
MOVWF Int1BContext+D'2'
BCF PCLATH,3
BCF PCLATH,4
GOTO interrupt
ORG 0x00000010
delay_ms_00000
; { delay_ms ; function begin
MOVF delay_ms_00000_arg_del, F
BTFSS STATUS,Z
GOTO label1
RETURN
label1
MOVLW 0xF9
label2
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
ADDLW 0xFF
BTFSS STATUS,Z
GOTO label2
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
NOP
DECFSZ delay_ms_00000_arg_del, F
GOTO label1
RETURN
; } delay_ms function end
ORG 0x0000002C
delay_s_00000
; { delay_s ; function begin
label3
MOVLW 0xFA
MOVWF delay_ms_00000_arg_del
CALL delay_ms_00000
MOVLW 0xFA
CALL delay_ms_00000
MOVLW 0xFA
CALL delay_ms_00000
MOVLW 0xFA
CALL delay_ms_00000
DECFSZ delay_s_00000_arg_del, F
GOTO label3
RETURN
; } delay_s function end
ORG 0x0000003B
main
; { main ; function begin
MOVLW 0x07
BSF STATUS, RP0
BCF STATUS, RP1
MOVWF gbl_adcon1
MOVLW 0xC0
MOVWF gbl_option_reg
label4
MOVLW 0xFE
BSF STATUS, RP0
ANDWF gbl_trisb, W
MOVWF gbl_trisb
MOVLW 0xFE
BCF STATUS, RP0
ANDWF gbl_portb, W
MOVWF CompTempVar2188
MOVLW 0x01
IORWF CompTempVar2188, W
MOVWF gbl_portb
MOVLW 0xFD
BSF STATUS, RP0
ANDWF gbl_trisb, W
MOVWF gbl_trisb
MOVLW 0xFD
BCF STATUS, RP0
ANDWF gbl_portb, W
MOVWF CompTempVar2189
MOVLW 0x02
IORWF CompTempVar2189, W
MOVWF gbl_portb
MOVLW 0xFB
BSF STATUS, RP0
ANDWF gbl_trisb, W
MOVWF gbl_trisb
MOVLW 0xFB
BCF STATUS, RP0
ANDWF gbl_portb, W
MOVWF CompTempVar2190
MOVLW 0x04
IORWF CompTempVar2190, W
MOVWF gbl_portb
MOVLW 0xF7
BSF STATUS, RP0
ANDWF gbl_trisb, W
MOVWF gbl_trisb
MOVLW 0xF7
BCF STATUS, RP0
ANDWF gbl_portb, W
MOVWF CompTempVar2191
MOVLW 0x08
IORWF CompTempVar2191, W
MOVWF gbl_portb
MOVLW 0xEF
BSF STATUS, RP0
ANDWF gbl_trisb, W
MOVWF gbl_trisb
MOVLW 0xEF
BCF STATUS, RP0
ANDWF gbl_portb, W
MOVWF CompTempVar2192
MOVLW 0x10
IORWF CompTempVar2192, W
MOVWF gbl_portb
MOVLW 0xDF
BSF STATUS, RP0
ANDWF gbl_trisb, W
MOVWF gbl_trisb
MOVLW 0xDF
BCF STATUS, RP0
ANDWF gbl_portb, W
MOVWF CompTempVar2193
MOVLW 0x20
IORWF CompTempVar2193, W
MOVWF gbl_portb
MOVLW 0xBF
BSF STATUS, RP0
ANDWF gbl_trisb, W
MOVWF gbl_trisb
MOVLW 0xBF
BCF STATUS, RP0
ANDWF gbl_portb, W
MOVWF CompTempVar2194
MOVLW 0x40
IORWF CompTempVar2194, W
MOVWF gbl_portb
MOVLW 0x7F
BSF STATUS, RP0
ANDWF gbl_trisb, W
MOVWF gbl_trisb
MOVLW 0x7F
BCF STATUS, RP0
ANDWF gbl_portb, W
MOVWF CompTempVar2195
MOVLW 0x80
IORWF CompTempVar2195, W
MOVWF gbl_portb
MOVLW 0x01
MOVWF delay_s_00000_arg_del
CALL delay_s_00000
BSF STATUS, RP0
CLRF gbl_trisb
BCF STATUS, RP0
CLRF gbl_portb
MOVLW 0x01
CALL delay_s_00000
GOTO label4
; } main function end
ORG 0x000000A4
_startup
MOVLW 0xD5
BCF STATUS, RP0
BCF STATUS, RP1
MOVWF gbl_14_LSR
MOVLW 0xC4
MOVWF gbl_14_LSR+D'1'
MOVLW 0xBB
MOVWF gbl_14_LSR+D'2'
MOVLW 0xDC
MOVWF gbl_14_LSR+D'3'
CLRF gbl_15_gbl_aSig
CLRF gbl_15_gbl_aSig+D'1'
CLRF gbl_15_gbl_aSig+D'2'
CLRF gbl_15_gbl_aSig+D'3'
CLRF gbl_15_gbl_bSig
CLRF gbl_15_gbl_bSig+D'1'
CLRF gbl_15_gbl_bSig+D'2'
CLRF gbl_15_gbl_bSig+D'3'
CLRF gbl_15_gbl_zSig
CLRF gbl_15_gbl_zSig+D'1'
CLRF gbl_15_gbl_zSig+D'2'
CLRF gbl_15_gbl_zSig+D'3'
CLRF gbl_15_gbl_aExp
CLRF gbl_15_gbl_bExp
CLRF gbl_15_gbl_zExp
CLRF gbl_15_gbl_zExp+D'1'
CLRF gbl_15_gbl_aSign
CLRF gbl_15_gbl_bSign
CLRF gbl_15_gbl_zSign
CLRF gbl_15_gbl_zSigZero
CLRF gbl_15_gbl_ret
CLRF gbl_15_gbl_ret+D'1'
CLRF gbl_15_gbl_ret+D'2'
CLRF gbl_15_gbl_ret+D'3'
CLRF gbl_float_rounding_mode
CLRF gbl_float_exception_flags
CLRF gbl_float_detect_tininess
BCF PCLATH,3
BCF PCLATH,4
GOTO main
ORG 0x000000CC
interrupt
; { interrupt ; function begin
BCF STATUS, RP0
BCF STATUS, RP1
SWAPF Int1BContext+D'2', W
MOVWF FSR
SWAPF Int1BContext+D'1', W
MOVWF PCLATH
SWAPF Int1BContext, W
MOVWF STATUS
SWAPF Int1Context, F
SWAPF Int1Context, W
RETFIE
; } interrupt function end
ORG 0x00002007
DW 0x3FFD
END
