Hola:
Estoy probando los ejemplos que tienen www.Microchip.com bajo PIC16F sobre XC8. Este es uno de los ejemplos.
Uso el MPLAB X 1.80 y XC8 con Windows 7.
Al compilarlo pulsando en l aimagen de abajo.
Como respuesta obtengo esto.
Al compilar...
...no compila o eso parece. Muestra mensaje como este:
Launching
No source code lines were found at current PC 0x0
User program stopped
En asm con el PIC16F88 y 16F886 me ocurre lo mismo.
¿Qué es lo que ocurre realmente?
Un saludo.
Código:
* Lesson 13 - "EEPROM"
* This lesson will provide code for writing and reading a single byte onto
* the on-board EEPROM. EEPROM is non-volatile memory, meaning that it does
* not lose its value when power is shut off. This is unlike RAM, which will
* lose its value when no power is applied. The EEPROM is useful for storing
* variables that must still be present during no power.
* It is also convenient to use if the entire RAM space is used up.
* Writes and reads to the EEPROM are practically instant and are much faster
* than program memory operations.
* Press the switch to save the LED state and then disconnect the power. When
* power is then applied again, the program will start with that same LED lit.
* When the lesson is first programmed, no LEDs will light up even with movement
* of the POT. When the switch is pressed, the corresponding LED will be lit and
* then the PIC will go to sleep until the switch is pressed again. Each press of
* the switch saves the ADC value into EEPROM. The PIC uses interrupts to wake up
* from sleep, take an ADC reading, save to EEPROM, and then goes back to sleep.
* PIC: 16F1829
* Compiler: XC8 v1.00
* IDE: MPLABX v1.10
* Board: PICkit 3 Low Pin Count Demo Board
* Date: 6.1.2012
* See Low Pin Count Demo Board User's Guide for Lesson Information*
#include <xc.h> //PIC hardware mapping
#define _XTAL_FREQ 500000 //Used by the XC8 delay_ms(x) macro
#define DOWN 0
#define UP 1
#define SWITCH PORTAbits.RA2
//config bits that are part-specific for the PIC16F1829
#pragma config FOSC=INTOSC, WDTE=OFF, PWRTE=OFF, MCLRE=OFF, CP=OFF, CPD=OFF, BOREN=ON, CLKOUTEN=OFF, IESO=OFF, FCMEN=OFF
#pragma config WRT=OFF, PLLEN=OFF, STVREN=OFF, LVP=OFF
/* -------------------LATC-----------------
* Bit#: -7---6---5---4---3---2---1---0---
* LED: ---------------|DS4|DS3|DS2|DS1|-
unsigned char adc(void); //prototype
void main(void) {
OSCCON = 0b00111000; //500KHz clock speed
TRISC = 0; //all LED pins are outputs
LATC = 0; //init all LEDs OFF
//setup switch (SW1)
TRISAbits.TRISA2 = 1; //switch as input
ANSELAbits.ANSA2 = 0; //digital switch
//setup ADC
TRISAbits.TRISA4 = 1; //Potentiamtor is connected to RA4...set as input
ANSELAbits.ANSA4 = 1; //analog
ADCON0 = 0b00001101; //select RA4 as source of ADC and enable the module (AN3)
ADCON1 = 0b00010000; //left justified - FOSC/8 speed - Vref is Vdd
//setup interrupt on change for the switch
INTCONbits.IOCIE = 1; //enable interrupt on change global
IOCANbits.IOCAN2 = 1; //when SW1 is pressed/released, enter the ISR
INTCONbits.GIE = 1; //enable global interupts
while (1) {
LATC = eeprom_read(0x00); //load whatever is in EEPROM to the LATCH
SLEEP(); //sleep until button is pressed
unsigned char adc(void) {
__delay_us(5); //wait for ADC charging cap to settle
GO = 1;
while (GO) continue; //wait for conversion to be finished
return ADRESH; //grab the top 8 MSbs
void interrupt ISR(void) {
unsigned char adc_value = 0;
if (IOCAF) { //SW1 was just pressed
IOCAF = 0; //must clear the flag in software
__delay_ms(5); //debounce by waiting and seeing if still held down
if (SWITCH == DOWN) {
adc_value = adc(); //get the ADC value from the POT
adc_value >>= 4; //save only the top 4 MSbs
LATC = adc_value;
//EEPROM is non-volatile, meaning that it can retain its value when no power is applied
eeprom_write(0x00, adc_value); //save the value to EEPROM and go back to sleep
Código:
make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
make[1]: Entering directory `C:/Users/Meta/Desktop/13_EEPROM/eeprom.X'
make -f nbproject/Makefile-default.mk dist/default/production/eeprom.X.production.hex
make[2]: Entering directory `C:/Users/Meta/Desktop/13_EEPROM/eeprom.X'
"C:\Program Files (x86)\Microchip\xc8\v1.12\bin\xc8.exe" --pass1 --chip=16F1829 -Q -G --asmlist --double=24 --float=24 --opt=default,+asm,-asmfile,+speed,-space,-debug --addrqual=ignore --mode=free -P -N255 --warn=0 --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,+osccal,-resetbits,-download,-stackcall,+clib "--errformat=%%f:%%l: error: %%s" "--warnformat=%%f:%%l: warning: %%s" "--msgformat=%%f:%%l: advisory: %%s" -obuild/default/production/_ext/1472/eeprom.p1 ../eeprom.c
"C:\Program Files (x86)\Microchip\xc8\v1.12\bin\xc8.exe" --chip=16F1829 -G --asmlist -mdist/default/production/eeprom.X.production.map --double=24 --float=24 --opt=default,+asm,-asmfile,+speed,-space,-debug --addrqual=ignore --mode=free -P -N255 --warn=0 --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,+osccal,-resetbits,-download,-stackcall,+clib "--errformat=%%f:%%l: error: %%s" "--warnformat=%%f:%%l: warning: %%s" "--msgformat=%%f:%%l: advisory: %%s" -odist/default/production/eeprom.X.production.cof build/default/production/_ext/1472/eeprom.p1
Microchip MPLAB XC8 C Compiler V1.12
Copyright (C) 2012 Microchip Technology Inc.
License type: Node Configuration
Memory Summary:
Program space used B4h ( 180) of 2000h words ( 2.2%)
Data space used Dh ( 13) of 400h bytes ( 1.3%)
EEPROM space used 0h ( 0) of 100h bytes ( 0.0%)
Configuration bits used 2h ( 2) of 2h words (100.0%)
ID Location space used 0h ( 0) of 4h bytes ( 0.0%)
Running this compiler in PRO mode, with Omniscient Code Generation enabled,
produces code which is typically 40% smaller than in Free mode.
See http://microchip.com for more information.
make[2]: Leaving directory `C:/Users/Meta/Desktop/13_EEPROM/eeprom.X'
make[1]: Leaving directory `C:/Users/Meta/Desktop/13_EEPROM/eeprom.X'
BUILD SUCCESSFUL (total time: 11s)
Loading code from C:/Users/Meta/Desktop/13_EEPROM/eeprom.X/dist/default/production/eeprom.X.production.hex...
Loading symbols from C:/Users/Meta/Desktop/13_EEPROM/eeprom.X/dist/default/production/eeprom.X.production.cof...
Loading completed
Al compilar...
Launching
Un saludo.
