me aparece el siguiente error cuando trato de crear el archivo de programacion para mi FPGA:
ERRORack:198 - NCD was not produced. All logic was removed from design. This
is usually due to having no input or output PAD connections in the design and
no nets or symbols marked as 'SAVE'. You can either add PADs or 'SAVE'
attributes to the design, or run 'map -u' to disable logic trimming in the
mapper.
alguien podria ayudarme?
es que ya he tratado varias cosas, y la verdad no se a que se debe el error...[/list]
mapper.
