Bus I2C y lenguaje "C", no se resolver el codigo
Hola a todos.
tengo problemas para comunicar dos pic 16f887 con el bus I2C, lo que quiero hacer es de lo mas sencillo, ingresar un dato por un puerto, y leerlo en el otro pic desde algun otro puerto.
el problema es que creo entender como trabaj el protocolo, pero no consigo llevarlo a la line de codigo...
si alguien puede darme una ayuda les estaria muy agradecido. los codigos que utilizo son:
MASTER:
Código:
#include main.h
void main()
int result;
   SET_TRIS_A (0xff);
   SET_TRIS_b (0x00);
   SET_TRIS_d (0xff);
   setup_adc_ports(NO_ANALOGS|VSS_VDD);
   setup_adc(ADC_OFF);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DISABLED,0,1);
   setup_comparator(NC_NC_NC_NC);// This device COMP currently not supported by the PICWizard
//Setup_Oscillator parameter not selected from Intr Oscillator Config tab
   // TODO: USER CODE!
pto_b= 0;
while(TRUE)
      if(input(PIN_D0))    //read inputs when PIN d0 is depressed
         delay_ms(10);
         i2c_start ();           //begin communication
         i2c_write (0xa0);       //send slave address
         i2c_write (0x05);       //request slave internal memory address for data
         i2c_stop();             //stop write cycle to shift to read cycle
         i2c_start ();           //send repeated start command to begin read cycle
         i2c_write (0xa1);       //add 1 to the address to send a write bit
         result = i2c_read(0);   //read analogue informaciónrmation from the slave
         i2c_stop ();            //terminate communication
         pto_b=result;           //display analogue informaciónrmation from the slave
      while(!input(PIN_D0))      //read inputs when PIN d0 is depressed
         delay_ms(10);
         i2c_write(0x06);        //posicion del buffer
         i2c_write (0xaa);       //request slave internal memory address for data
SLAVE:
Código:
#include main.h
//BYTE address, buffer[0x10];
int *address,
SET_TRIS_A (0xff)
SET_TRIS_B (0x00)
#INT_SSP
  void ssp_interupt ()
     state = i2c_isr_state();
     if(state < 0xa1)                 //master is sending data
       if(state == 0)
        if(state == 1)                   //first received byte is address
           address = i2c_read();
        if(state == 2)                   //second received byte is data
           *address = i2c_read();
     if(state == 0xa1)                //master is requesting data
        i2c_write (*address);  //send requested data
void main()
   setup_adc(ADC_OFF);
   // TODO: USER CODE!
   enable_interrupts(GLOBAL);
   enable_interrupts(INT_SSP);
   while (TRUE) {
   delay_ms(10);
   pto_b= 0x00;
   delay_ms(10);
   pto_b=0xff;
estos condigos fueron creados en ccs, y montados simulados sobre proteus. pero no andan!
los archivos que envio, pertenecen a los codigos aqui expuestos, y al fichero de proteus.
Por favor, si alguien pudiera ayudarme, estaria agradecido.
  • codigos_877.rar
    32 KB · Visitas: 32
  • circuit_142.rar
    16.9 KB · Visitas: 35
