Hola compañeros que tal, recurro a ustedes esperando puedan ayudarme a resolver un problema que tengo con el codigo de un contador johnson, estoy usando Galaxy Warp 6.3 de Cypress
A la hora de compilar todo ocurre de manera perfecta, pero luego trato de simularlo con Active-VHDL 3.3 y me marca el siguiente error:
Design: 08:18 p.m., Miércoles, 01 de Abril de 2009
Design: Opening design "C:\ESCOM\Cuarto Semestre\Circuitos Logicos 2\ContJohnson\vhd\John\John.adf"
Compilation with file reorder...
File: C:\ESCOM\Cuarto Semestre\Circuitos Logicos 2\ContJohnson\vhd\John.vhd
Compile Entity "e_john"
Compile Architecture "DSMB" of Entity "e_john"
Error: COMP96_0386: John.vhd : (125, 13): Generic types of actuals in component instantiation do not match those in component declaration.
Error: COMP96_0386: John.vhd : (153, 13): Generic types of actuals in component instantiation do not match those in component declaration.
Error: COMP96_0386: John.vhd : (181, 13): Generic types of actuals in component instantiation do not match those in component declaration.
Error: COMP96_0386: John.vhd : (209, 13): Generic types of actuals in component instantiation do not match those in component declaration.
Error: COMP96_0386: John.vhd : (237, 13): Generic types of actuals in component instantiation do not match those in component declaration.
Error: COMP96_0386: John.vhd : (265, 13): Generic types of actuals in component instantiation do not match those in component declaration.
Error: COMP96_0386: John.vhd : (293, 13): Generic types of actuals in component instantiation do not match those in component declaration.
Error: COMP96_0386: John.vhd : (321, 13): Generic types of actuals in component instantiation do not match those in component declaration.
Top-Level unit detected
Entity => e_john
Compile failure 8 Errors 0 Warnings Analysis time : 0.0
realmente lo que hace el programa, o bueno lo que intento que haga es recorrer la secuencia inicial negando el ultimo dato del vector de entrada, pero no se que ocurre aqui. De hecho ya programe mi GAL y efectivamente no funciona de manera correcta ya que aunque le de una secuencia de bits determinada siempre lo pone todo en 0's y luego empieza a hacer la rotacion de bits negandolos. Espero me puedan ayudar y gracias.
SOLUCIONADO
OOps el error lo he resuelto, gracias aunque nadie me ayudo, espero contar con su ayuda en proximas ocasiones. Al parecer reg es una palabra reservada o algo asi en VHDL asi que la sustitui por registro y todo ha marchado a la perfeccion.
Código:
library ieee;
use ieee.std_logic_1164.all;
entity e_john is
port(clr, clk, sel: in std_logic;
reg, car: inout std_logic_vector(7 downto 0)
end e_john;
architecture a_john of e_john is begin
process(clr,clk) begin
if(clr = '1') then
reg <= "00000000";
elsif(CLK'EVENT and clk = '1')then
if(sel = '0') then
reg <= car;
elsif(sel = '1') then
reg <= (not reg(0)) & reg(7 downto 1);
end if;
end if;
end process;
end a_john;
Entity => e_john
SOLUCIONADO
