Les mando mi código en VHDL de parte del generador de direcciones de memoria, al momento de compilar me lanza distintos errores:
El error que muestra es:
Updating: Fit Design
Starting: 'C:\ispTOOLS\ispsys\bin\fit.exe lecturaescritura.tt2 -dev P22V10 -str -gui -err automake.err'
FIT Generic Device Fitter
Copyright(C), 1992-2000, Lattice Semiconductor Corporation. All rights reserved
Portions Copyright(c), 1992-1999, Vantis Corporation
Portions Copyright(C), 1993-1998, Data I/O Corporation
Portions Copyright(C), 1997-1998, MINC Washington Corporation
Portions Copyright(C), Alan Phillips, Lancaster University Computer Centre 1992-1998
Input file: 'lecturaescritura.tt2'
Device 'P22V10'
Note 4068: Signal INCDIR cannot be assigned (to pin 23) because
the register type of 'INCDIR' pin 23 is invalid.
Note 4068: Signal WR cannot be assigned (to pin 23) because
the register type of 'WR' pin 23 is invalid.
Note 4068: Signal RD cannot be assigned (to pin 23) because
the register type of 'RD' pin 23 is invalid.
Design does NOT fit
Done: failed with exit code: 0001.
Y su respectiva Carta ASM es la siguiente:
[/CENTER
Les pido que me ayuden a corregir dicho problema...
Código:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_signed.all;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity LectEsc is
port(clk : in std_logic;
PRO, RW : in bit;
RD, WR, INCDIR : out bit
end LectEsc;
architecture RTL of LectEsc is
signal state, next_state: bit; -- INI = 1, MEM = 0
attribute syn_encoding : string;
attribute syn_encoding of state : signal is "onehot";
begin
process (clk)
begin
if rising_edge(clk) then
state <= next_state;
end if;
end process;
process (state, PRO, RW)
begin
case state is
when '0' => -- MEM
if PRO = '1' then
if RW = '1' then
INCDIR <= '0';
RD <= '1';
WR <= '0';
next_state <= '0'; -- MEM
else
INCDIR <= '0';
RD <= '0';
WR <= '1';
end if;
else
INCDIR <= '1';
next_state <= '1';
end if;
when '1' => -- INI
if PRO = '1' then
else
next_state <= '1'; -- INI
end if;
when others =>
end case;
end process;
end RTL;
Device 'P22V10'
Design does NOT fit
