En la secccion del lcd esta,mira:
You can setup up to eight user defined
characters to be used on LCD. This can
easily be done with LCDDEFCHAR
statement. The first argument of this
statement is char number and must be in
the range 0-7. Next 8 arguments form 8-
line char pattern (from the top to the
bottom) and must be in the range 0-31
(5-bits wide). These 8 user characters are
assigned to char codes 0-7 and 8-15 and
can be displayed using LCDOUT
statement. After LCDDEFCHAR statement
the cursor will be in HOME position. For
example:
Lcddefchar 0, 10, 10, 10,
10, 10, 10, 10, 10
Lcddefchar 1, %11111,
%10101, %10101, %10101,
%11111
Lcdout 0, 1, "Hello!", 1,
0
Esa es la instruccion (lcddefchar), ay que buscar un poco mas.
salu2
