Migrar código de PIC16F877 a PIC18F4550
¿Cómo lo puedo hacer funcionar?
PHP:
LIST P=18F4550, F=INHX32    ;directive to define processor
    #include <P18F4550.INC>    ;processor specific variable definitions
;Configuration bits
;Microchip has changed the format for defining the configuration bits, please
;see the .inc file for futher details on notation.  Below are a few examples.
;   Oscillator Selection:
 CONFIG    FOSC = INTOSCIO_EC         ;XT oscillator, XT used by USB
 CONFIG  PWRT = ON
 CONFIG  BOR = OFF
 CONFIG  WDT = OFF
 CONFIG  MCLRE = OFF ;
 CONFIG  PBADEN = OFF
 CONFIG  LVP = OFF
 CONFIG  DEBUG = OFF
 CONFIG  XINST = OFF
;Variable definitions
; These variables are only needed if low priority interrupts are used.
; More variables may be needed to store other special function registers used
; in the interrupt routines.
;        UDATA
;WREG_TEMP    RES    1    ;variable in RAM for context saving
;STATUS_TEMP    RES    1    ;variable in RAM for context saving
;BSR_TEMP    RES    1    ;variable in RAM for context saving
    ;    UDATA_ACS
;Conta1        RES    1    ;example of a variable in access RAM
;Conta2        RES 1
;Conta3        RES 1
;COUNT        RES 1
;EEPROM data
; Data to be programmed into the Data EEPROM is defined here
;DATA_EEPROM    CODE    0xf00000
;        DE "Test Data",0,1,2,3,4,5
;Reset vector
; This code will start executing when a reset occurs.
;RESET_VECTOR    CODE    0x0000
;        goto    Main        ;go to start of main code
;High priority interrupt vector
; This code will start executing when a high priority interrupt occurs or
; when any interrupt occurs if interrupt priorities are not enabled.
;HI_INT_VECTOR    CODE    0x0008
;        bra    HighInt        ;go to high priority interrupt routine
;Low priority interrupt vector and routine
; This code will start executing when a low priority interrupt occurs.
; This code can be removed if low priority interrupts are not used.
;LOW_INT_VECTOR    CODE    0x0018
;        bra    LowInt        ;go to low priority interrupt routine
;High priority interrupt routine
; The high priority interrupt code is placed here to avoid conflicting with
; the low priority interrupt vector.
;        CODE
;HighInt:
;    *** high priority interrupt code goes here ***
;        retfie    FAST
;Low priority interrupt routine
; The low priority interrupt code is placed here.
;LowInt:
;        movff    STATUS,STATUS_TEMP    ;save STATUS register
;        movff    WREG,WREG_TEMP        ;save working register
;        movff    BSR,BSR_TEMP        ;save BSR register
;    *** low priority interrupt code goes here ***
;        movff    BSR_TEMP,BSR        ;restore BSR register
;        movff    WREG_TEMP,WREG        ;restore working register
;        movff    STATUS_TEMP,STATUS    ;restore STATUS register
;        retfie
;Start of main program
; The main program code is placed here.
;Variable para el DELAY del ADC
val equ h\'20\'
  ;Variables para el DELAY del ENABLE LCD
val2 equ 0x30
val1 equ 0x31
  ;Variables para separar el resultado de ADC
  ; en valor BCD
Unidades equ 0x32
Decenas equ 0x33
Centenas equ 0x34
Resto equ 0x35
        ORG     0X1000
        goto INICIO
INICIO:
      clrf PORTA        ;Limpia el puerto A
      clrf PORTB        ;Limpia el puerto B
      clrf PORTC        ;Limpia el puerto C
      clrf PORTD        ;Limpia el puerto D
      bsf STATUS,5
      bcf STATUS,6    ;Cambio al banco 1
      ;Configuración de puertos C-D para el LCD
      clrf TRISC        ;Configura PORTC como salida
      clrf TRISD        ;Configura PORTD como salida
      ;Configuración del puerto A para ADC
      movlw 00h
      movwf ADCON1      ;Configura puerto A y E como analógicos
      movlw 3fh
      movwf TRISA       ;Configura el puerto A como entrada
      movlw h\'0\'
      ;Configuración del puerto B para mostrar el resultado ADC
      movwf TRISB       ;Configura puerto B como salida
      bcf STATUS,5    ;Regresa al banco 0
      ;Inicio del programa
START
      call START_LCD   ;Inicializa LCD
      goto START_ADC   ;Comienza la lectura del Conv. A/D
      ;Inicia LCD
START_LCD:
      bcf PORTC,0      ; RS=0 MODO INSTRUCCION
      movlw 0x01       ; 0x01 limpia la pantalla en el LCD
      movwf PORTD
      call COMANDO     ; Se da de alta el comando
      movlw 0x0C       ; Selecciona la primera línea
      movwf PORTD
      movlw 0x3C       ; Se configura el cursor
      movwf PORTD
      bsf PORTC, 0     ; Rs=1 MODO DATO
      return
      ;Rutina para enviar un dato
ENVIA:
      bsf PORTC, 0    ; RS=1 MODO DATO
      return
      ;Rutina para enviar comandos
COMANDO:
      bsf PORTC, 1    ; Pone la señal ENABLE en 1
      call DELAY2     ; Tiempo de espera
      call DELAY2
      bcf PORTC, 1    ; ENABLE=0
      call DELAY2
      return
      ;Rutina para limpar pantalla LCD
ERASE_LCD
      movwf PORTD
      return
      ;Configuración Convertidor A/D
START_ADC
      movlw b\'11000001\' ;Configuración ADCON0
      movwf ADCON0      ;ADCS1=1 ADCS0=1 CHS2=0 CHS1=0
                        ;CHS0=0 GO/DONE=0 - ADON=1
CICLO: bsf ADCON0,2      ;Conversión en progreso GO=1
       call DELAY1       ;Espera que termine la conversión
ESPERA btfsc ADCON0,2    ;Pregunta por DONE=0?(Terminó conversión)
       goto ESPERA       ;No, vuelve a preguntar
       movf ADRESH,0     ;Si
       movwf PORTB       ;Muestra el resultado en PORTB
       ;Rutina que muestra temperatura
PRINT_TEMP
       call ERASE_LCD    ;Limpia LCD
       movlw \'T\'
       movwf PORTD
       call ENVIA
       movlw \'=\'
       movwf PORTD
       call ENVIA
       call READ_TEMP    ;Llamada a rutina que obtine el
                         ;valor de la temperatura a partir
                         ;del  resultado del Conv a/D
       movf Centenas,W   ;Imprime el dígito de las centenas
       movwf PORTD
       call ENVIA
       movf Decenas,W    ;Imprime el dígito de las decenas
       movwf PORTD
       call ENVIA
       movf Unidades,W   ;Imprime el dígito de las unidades
       movwf PORTD
       call ENVIA
       movlw \' \'
       movwf PORTD
       call ENVIA
       movlw h\'DF\'       ;Imprime el simbolo "°"
       movwf PORTD
       call ENVIA
       movlw \'C\'
       movwf PORTD
       call ENVIA
       goto CICLO        ;Repite el ciclo de lectura ADC
       ;Rutina que obtine el valor de la temperatura
       ;a partir del  resultado del Conv a/D
READ_TEMP:
       clrf Centenas
       clrf Decenas
       clrf Unidades
       movf ADRESH,W
       addwf ADRESH,W     ;Dupilca el valor de ADRESH para
       ;obtener un valor de temperatura real aprox
       movwf Resto        ;Guarda el valor de ADRESH en Resto
       ;Comienza el proceso de otención de valores BCD
       ;para Centenas, Decenas y unidades atraves de restas
       ;sucesivas.
CENTENAS1
       movlw d\'100\'      ;W=d\'100\'
       subwf Resto,W     ;Resto - d\'100\' (W)
       btfss STATUS,C    ;Resto menor que d\'100\'?
       goto DECENAS1     ;SI
       movwf Resto       ;NO, Salva el resto
       incf Centenas,1   ;Incrementa el contador de centenas BCD
       goto CENTENAS1    ;Realiza otra resta
DECENAS1
       movlw d\'10\'       ;W=d\'10\'
       subwf Resto,W     ;Resto - d\'10\' (W)
       btfss STATUS,C    ;Resto menor que d\'10\'?
       goto UNIDADES1    ;Si
       movwf Resto       ;No, Salva el resto
       incf Decenas,1    ;Incrementa el contador de centenas BCD
       goto DECENAS1     ;Realiza otra resta
UNIDADES1
       movf Resto,W      ;El resto son la Unidades BCD
       movwf Unidades
       ;clrf Resto
       ;Rutina que obtiene el equivalente en ASCII
OBTEN_ASCII
       movlw h\'30\'
       iorwf Unidades,f
       iorwf Decenas,f
       iorwf Centenas,f
       return
;Rutina que genera un Delay de 20 microSeg aprox.
;para el Conv. A/D
DELAY1:
       movlw h\'30\'
       movwf val
Loop   decfsz val,1
       goto Loop
       return
;Subrutina de retardo para ENABLE_LCD
DELAY2:
       movlw 0xFF
       movwf val1
Loop1:
       movlw 0xFF
       movwf val2
Loop2:
       decfsz val2,1
       goto Loop2
       decfsz val1,1
       goto Loop1
       return
    end
Para hacerlo funcionar, tenes que ponerte con las dos hojas de datos de los PICs, reemplazar las palabras de configuración, y reemplazar las funciones que no existan en el 16F877. Por ejemplo, la función movff no existe en el 877, pero se puede reemplazar por dos funciones movlw/movf/movfw, según lo que quieras hacer.
También deberías revisar que coincidan los pines con las funciones que se les ha asignado, que coincidan los vectores de interrupción, etc.
El primer paso es buscar ambas hojas de datos.
