// Flex_LCD420.c
// These pins are for my Microchip PicDem2-Plus board,
// which I used to test this driver.
// An external 20x4 LCD is connected to these pins.
// Change these pins to match your own board's connections.
#define LCD_DB4 PIN_D4
#define LCD_DB5 PIN_D5
#define LCD_DB6 PIN_D6
#define LCD_DB7 PIN_D7
#define LCD_RS PIN_E0
#define LCD_RW PIN_E1
#define LCD_E PIN_E2
// To prove that the driver can be used with random
// pins, I also tested it with these pins:
#define LCD_DB5 PIN_B1
#define LCD_DB6 PIN_C5
#define LCD_DB7 PIN_B5
#define LCD_RS PIN_E2
#define LCD_RW PIN_B2
#define LCD_E PIN_D6
// If you want only a 6-pin interface to your LCD, then
// connect the R/W pin on the LCD to ground, and comment
// out the following line. Doing so will save one PIC
// pin, but at the cost of losing the ability to read from
// the LCD. It also makes the write time a little longer
// because a static delay must be used, instead of polling
// the LCD's busy bit. Normally a 6-pin interface is only
// used if you are running out of PIC pins, and you need
// to use as few as possible for the LCD.
#define USE_RW_PIN 1
// These are the line addresses for most 4x20 LCDs.
#define LCD_LINE_1_ADDRESS 0x00
#define LCD_LINE_2_ADDRESS 0x40
#define LCD_LINE_3_ADDRESS 0x14
#define LCD_LINE_4_ADDRESS 0x54
// These are the line addresses for LCD's which use
// the Hitachi HD66712U controller chip.
#define LCD_LINE_2_ADDRESS 0x20
#define LCD_LINE_3_ADDRESS 0x40
#define LCD_LINE_4_ADDRESS 0x60
#define lcd_type 2 // 0=5x7, 1=5x10, 2=2 lines(or more)
int8 lcd_line;
int8 const LCD_INIT_STRING[4] =
0x20 | (lcd_type << 2), // Set mode: 4-bit, 2+ lines, 5x8 dots
0xc, // Display on
1, // Clear display
6 // Increment cursor
void lcd_send_nibble(int8 nibble)
// Note: !! converts an integer expression
// to a boolean (1 or 0).
output_bit(LCD_DB4, !!(nibble & 1));
output_bit(LCD_DB5, !!(nibble & 2));
output_bit(LCD_DB6, !!(nibble & 4));
output_bit(LCD_DB7, !!(nibble & 8));
delay_cycles(1);
output_high(LCD_E);
delay_us(2);
output_low(LCD_E);
// This sub-routine is only called by lcd_read_byte().
// It's not a stand-alone routine. For example, the
// R/W signal is set high by lcd_read_byte() before
// this routine is called.
#ifdef USE_RW_PIN
int8 lcd_read_nibble(void)
int8 retval;
// Create bit variables so that we can easily set
// individual bits in the retval variable.
#bit retval_0 = retval.0
#bit retval_1 = retval.1
#bit retval_2 = retval.2
#bit retval_3 = retval.3
retval = 0;
output_high(LCD_E);
delay_us(1);
retval_0 = input(LCD_DB4);
retval_1 = input(LCD_DB5);
retval_2 = input(LCD_DB6);
retval_3 = input(LCD_DB7);
output_low(LCD_E);
delay_us(1);
return(retval);
#endif
// Read a byte from the LCD and return it.
#ifdef USE_RW_PIN
int8 lcd_read_byte(void)
int8 low;
int8 high;
output_high(LCD_RW);
delay_cycles(1);
high = lcd_read_nibble();
low = lcd_read_nibble();
return( (high<<4) | low);
#endif
// Send a byte to the LCD.
void lcd_send_byte(int8 address, int8 n)
output_low(LCD_RS);
#ifdef USE_RW_PIN
while(bit_test(lcd_read_byte(),7)) ;
#else
delay_us(60);
#endif
if(address)
output_high(LCD_RS);
else
output_low(LCD_RS);
delay_cycles(1);
#ifdef USE_RW_PIN
output_low(LCD_RW);
delay_cycles(1);
#endif
output_low(LCD_E);
lcd_send_nibble(n >> 4);
lcd_send_nibble(n & 0xf);
void lcd_init(void)
int8 i;
lcd_line = 1;
output_low(LCD_RS);
#ifdef USE_RW_PIN
output_low(LCD_RW);
#endif
output_low(LCD_E);
// Some LCDs require 15 ms minimum delay after
// power-up. Others require 30 ms. I'm going
// to set it to 35 ms, so it should work with
// all of them.
delay_ms(35);
for(i=0 ;i < 3; i++)
lcd_send_nibble(0x03);
delay_ms(5);
lcd_send_nibble(0x02);
for(i=0; i < sizeof(LCD_INIT_STRING); i++)
lcd_send_byte(0, LCD_INIT_STRING[i]);
// If the R/W signal is not used, then
// the busy bit can't be polled. One of
// the init commands takes longer than
// the hard-coded delay of 50 us, so in
// that case, lets just do a 5 ms delay
// after all four of them.
#ifndef USE_RW_PIN
delay_ms(5);
#endif
void lcd_gotoxy(int8 x, int8 y)
int8 address;
switch(y)
case 1:
address = LCD_LINE_1_ADDRESS;
break;
case 2:
address = LCD_LINE_2_ADDRESS;
break;
case 3:
address = LCD_LINE_3_ADDRESS;
break;
case 4:
address = LCD_LINE_4_ADDRESS;
break;
default:
break;
address += x-1;
lcd_send_byte(0, 0x80 | address);
void lcd_putc(char c)
switch(c)
case '\f':
lcd_send_byte(0,1);
lcd_line = 1;
delay_ms(2);
break;
case '\n':
lcd_gotoxy(1, ++lcd_line);
break;
case '\b':
lcd_send_byte(0,0x10);
break;
default:
lcd_send_byte(1,c);
break;
#ifdef USE_RW_PIN
char lcd_getc(int8 x, int8 y)
char value;
lcd_gotoxy(x,y);
// Wait until busy flag is low.
while(bit_test(lcd_read_byte(),7));
value = lcd_read_byte();
output_low(LCD_RS);
return(value);
#endif
Librerias XLCD de microchip en microcontroladores AVR
#include <avr/io.h>
#include "Lcd.h"
#define F_CPU 1000000UL
#include "delays.h"
Los ciclos de reloj estan definidos en Lcd.h
char q[] ="129";
int main(void)
OpenXLCD( FOUR_BIT & LINES_5X7);
BusyXLCD();
WriteCmdXLCD(0x0C); //para parpadeo
gotoxyXLCD(1,1);
putrsXLCD("ATmel AVR");
gotoxyXLCD(1,2);
putrsXLCD("AvR studio 4");
gotoxyXLCD(1,3);
putrsXLCD("LCD HD44780");
gotoxyXLCD(10,4);
putrsXLCD("4x20");
while(1){}
return 0;
Hola. En princípio la memoria del LCD no está dividida (es una sola) pero para mostrar los datos se separan en 4 segmentos de los cuales los 16 primeros de cada segmento están visibles; generalmente cada segmento tiene 32 bytes pero tambien hay de 64 Bytes.no comprendo como seleccionar las líneas 3 y 4.
os dejo la hoja de dato a ver si me pueden aclarar un poco.
mi idea es modificar la librería que tengo para uno de 16x2
;**************************** Librería "LCD.INC" ***********************************
; Estas subrutinas permiten realizar las tareas básicas de control de un módulo LCD de 2
; líneas por 16 caracteres, compatible con el modelo LM016L.
; El visualizador LCD está conectado al Puerto B del PIC mediante un bus de 4 bits. Las
; conexiones son:
; - Las 4 líneas superiores del módulo LCD, pines <DB7:DB4> se conectan a las 4
; líneas superiores del Puerto B del PIC, pines <RB7:RB4>.
; - Pin RS del LCD a la línea RA0 del PIC.
; - Pin R/W del LCD a la línea RA1 del PIC, o a masa.
; - Pin Enable del LCD a la línea RA2 del PIC.
; Se utilizan llamadas a subrutinas de retardo de tiempo localizadas en la librería RETARDOS.INC.
; ZONA DE DATOS *********************************************************************
CBLOCK
LCD_Dato
LCD_GuardaDato
LCD_GuardaTRISB
LCD_Auxiliar1
LCD_Auxiliar2
ENDC
LCD_CaracteresPorLinea EQU .16 ; Número de caracteres por línea de la pantalla.
#DEFINE LCD_PinRS PORTA,0
#DEFINE LCD_PinRW PORTA,1
#DEFINE LCD_PinEnable PORTA,2
#DEFINE LCD_BusDatos PORTB
; Subrutina "LCD_Inicializa" ------------------------------------------------------------
; Inicialización del módulo LCD: Configura funciones del LCD, produce reset por software,
; borra memoria y enciende pantalla. El fabricante especifica que para garantizar la
; configuración inicial hay que hacerla como sigue:
LCD_Inicializa
bsf STATUS,RP0 ; Configura las líneas conectadas al pines RS,
bcf LCD_PinRS ; R/W y E.
bcf LCD_PinEnable
bcf LCD_PinRW
bcf STATUS,RP0
bcf LCD_PinRW ; En caso de que esté conectado le indica
; que se va a escribir en el LCD.
bcf LCD_PinEnable ; Impide funcionamiento del LCD poniendo E=0.
bcf LCD_PinRS ; Activa el Modo Comando poniendo RS=0.
call Retardo_20ms
movlw b'00110000'
call LCD_EscribeLCD ; Escribe el dato en el LCD.
call Retardo_5ms
movlw b'00110000'
call LCD_EscribeLCD
call Retardo_200micros
movlw b'00110000'
call LCD_EscribeLCD
movlw b'00100000' ; Interface de 4 bits.
call LCD_EscribeLCD
; Ahora configura el resto de los parámetros:
call LCD_2Lineas4Bits5x7 ; LCD de 2 líneas y caracteres de 5x7 puntos.
call LCD_Borra ; Pantalla encendida y limpia. Cursor al principio
call LCD_CursorOFF ; de la línea 1. Cursor apagado.
call LCD_CursorIncr ; Cursor en modo incrementar.
return
; Subrutina "LCD_EscribeLCD" -----------------------------------------------------------
; Envía el dato del registro de trabajo W al bus de dato y produce un pequeño pulso en el pin
; Enable del LCD. Para no alterar el contenido de las líneas de la parte baja del Puerto B que
; no son utilizadas para el LCD (pines RB3:RB0), primero se lee estas líneas y después se
; vuelve a enviar este dato sin cambiarlo.
LCD_EscribeLCD
andlw b'11110000' ; Se queda con el nibble alto del dato que es el
movwf LCD_Dato ; que hay que enviar y lo guarda.
movf LCD_BusDatos,W ; Lee la información actual de la parte baja
andlw b'00001111' ; del Puerto B, que no se debe alterar.
iorwf LCD_Dato,F ; Enviará la parte alta del dato de entrada
; y en la parte baja lo que había antes.
bsf STATUS,RP0 ; Acceso al Banco 1.
movf PORTB,W ; Guarda la configuración que tenía antes TRISB.
movwf LCD_GuardaTRISB
movlw b'00001111' ; Las 4 líneas inferiores del Puerto B se dejan
andwf PORTB,F ; como estaban y las 4 superiores como salida.
bcf STATUS,RP0 ; Acceso al Banco 0.
movf LCD_Dato,W ; Recupera el dato a enviar.
movwf LCD_BusDatos ; Envía el dato al módulo LCD.
bsf LCD_PinEnable ; Permite funcionamiento del LCD mediante un pequeño
bcf LCD_PinEnable ; pulso y termina impidiendo el funcionamiento del LCD.
bsf STATUS,RP0 ; Acceso al Banco 1. Restaura el antiguo valor en
movf LCD_GuardaTRISB,W ; la configuración del Puerto B.
movwf PORTB ; Realmente es TRISB.
return
; Subrutinas variadas para el control del módulo LCD -----------------------------------------
;Los comandos que pueden ser ejecutados son:
movlw b'00000110'
goto LCD_EnviaComando
LCD_Linea1 ; Cursor al principio de la Línea 1.
movlw b'10000000' ; Dirección 00h de la DDRAM
LCD_Linea2 ; Cursor al principio de la Línea 2.
movlw b'11000000' ; Dirección 40h de la DDRAM
LCD_PosicionLinea1 ; Cursor a posición de la Línea 1, a partir de la
iorlw b'10000000' ; dirección 00h de la DDRAM más el valor del
goto LCD_EnviaComando ; registro W.
LCD_PosicionLinea2 ; Cursor a posición de la Línea 2, a partir de la
iorlw b'11000000' ; dirección 40h de la DDRAM más el valor del
LCD_OFF ; Pantalla apagada.
movlw b'00001000'
LCD_CursorON ; Pantalla encendida y cursor encendido.
movlw b'00001110'
LCD_CursorOFF ; Pantalla encendida y cursor apagado.
movlw b'00001100'
LCD_Borra ; Borra toda la pantalla, memoria DDRAM y pone el
movlw b'00000001' ; cursor a principio de la línea 1.
LCD_2Lineas4Bits5x7 ; Define la pantalla de 2 líneas, con caracteres
movlw b'00101000' ; de 5x7 puntos y conexión al PIC mediante bus de
; goto LCD_EnviaComando ; 4 bits.
; Subrutinas "LCD_EnviaComando" y "LCD_Caracter" ------------------------------------
; "LCD_EnviaComando". Escribe un comando en el registro del módulo LCD. La palabra de
; comando ha sido entregada a través del registro W. Trabaja en Modo Comando.
; "LCD_Caracter". Escribe en la memoria DDRAM del LCD el carácter ASCII introducido a
; a través del registro W. Trabaja en Modo Dato.
LCD_EnviaComando
bcf LCD_PinRS ; Activa el Modo Comando, poniendo RS=0.
goto LCD_Envia
LCD_Caracter
bsf LCD_PinRS ; Activa el "Modo Dato", poniendo RS=1.
call LCD_CodigoCGROM ; Obtiene el código para correcta visualización.
LCD_Envia
movwf LCD_GuardaDato ; Guarda el dato a enviar.
call LCD_EscribeLCD ; Primero envía el nibble alto.
swapf LCD_GuardaDato,W ; Ahora envía el nibble bajo. Para ello pasa el
; nibble bajo del dato a enviar a parte alta del byte.
call LCD_EscribeLCD ; Se envía al visualizador LCD.
btfss LCD_PinRS ; Debe garantizar una correcta escritura manteniendo
call Retardo_2ms ; 2 ms en modo comando y 50 µs en modo cáracter.
call Retardo_50micros
return
; Subrutina "LCD_CodigoCGROM" -----------------------------------------------------------
; A partir del carácter ASCII número 127 los códigos de los caracteres definidos en la
; tabla CGROM del LM016L no coinciden con los códigos ASCII. Así por ejemplo, el código
; ASCII de la "Ñ" en la tabla CGRAM del LM016L es EEh.
; Esta subrutina convierte los códigos ASCII de la "Ñ", "º" y otros, a códigos CGROM para que
; que puedan ser visualizado en el módulo LM016L.
; Entrada: En (W) el código ASCII del carácter que se desea visualizar.
; Salida: En (W) el código definido en la tabla CGROM.
LCD_CodigoCGROM
movwf LCD_Dato ; Guarda el valor del carácter y comprueba si es
LCD_EnheMinuscula ; un carácter especial.
sublw 'ñ' ; ¿Es la "ñ"?
btfss STATUS,Z
goto LCD_EnheMayuscula ; No es "ñ".
movlw b'11101110' ; Código CGROM de la "ñ".
movwf LCD_Dato
goto LCD_FinCGROM
LCD_EnheMayuscula
movf LCD_Dato,W ; Recupera el código ASCII de entrada.
sublw 'Ñ' ; ¿Es la "Ñ"?
btfss STATUS,Z
goto LCD_Grado ; No es "Ñ".
movlw b'11101110' ; Código CGROM de la "ñ". (No hay símbolo para
movwf LCD_Dato ; la "Ñ" mayúscula en la CGROM).
goto LCD_FinCGROM
LCD_Grado
sublw 'º' ; ¿Es el símbolo "º"?
btfss STATUS,Z
goto LCD_FinCGROM ; No es "º".
movlw b'11011111' ; Código CGROM del símbolo "º".
movwf LCD_Dato
LCD_FinCGROM
movf LCD_Dato,W ; En (W) el código buscado.
return
; Subrutina "LCD_DosEspaciosBlancos" y "LCD_LineaBlanco" --------------------------------
; Visualiza espacios en blanco.
LCD_LineaEnBlanco
movlw LCD_CaracteresPorLinea
goto LCD_EnviaBlancos
LCD_UnEspacioBlanco
movlw .1
movlw .2
LCD_TresEspaciosBlancos
movlw .3
LCD_EnviaBlancos
movwf LCD_Auxiliar1 ; (LCD_Auxiliar1) se utiliza como contador.
LCD_EnviaOtroBlanco
movlw ' ' ; Esto es un espacio en blanco.
call LCD_Caracter ; Visualiza tanto espacios en blanco como se
decfsz LCD_Auxiliar1,F ; haya cargado en (LCD_Auxiliar1).
goto LCD_EnviaOtroBlanco
return
; Subrutinas "LCD_ByteCompleto" y "LCD_Byte" --------------------------------------------
; Subrutina "LCD_ByteCompleto", visualiza el byte que almacena el registro W en el
; lugar actual de la pantalla. Por ejemplo, si (W)=b'10101110' visualiza "AE".
; Subrutina "LCD_Byte" igual que la anterior, pero en caso de que el nibble alto sea cero
; visualiza en su lugar un espacio en blanco. Por ejemplo si (W)=b'10101110' visualiza "AE"
; y si (W)=b'00001110', visualiza " E" (un espacio blanco delante).
; Utilizan la subrutina "LCD_Nibble" que se analiza más adelante.
LCD_Byte
movwf LCD_Auxiliar2 ; Guarda el valor de entrada.
andlw b'11110000' ; Analiza si el nibble alto es cero.
btfss STATUS,Z ; Si es cero lo apaga.
goto LCD_VisualizaAlto ; No es cero y lo visualiza.
movlw ' ' ; Visualiza un espacio en blanco.
call LCD_Caracter
goto LCD_VisualizaBajo
LCD_ByteCompleto
LCD_VisualizaAlto
swapf LCD_Auxiliar2,W ; Pone el nibble alto en la parte baja.
call LCD_Nibble ; Lo visualiza.
LCD_VisualizaBajo
movf LCD_Auxiliar2,W ; Repite el proceso con el nibble bajo.
; call LCD_Nibble ; Lo visualiza.
; return
; Subrutina "LCD_Nibble" ----------------------------------------------------------------
; Visualiza en el lugar actual de la pantalla, el valor hexadecimal que almacena en el nibble
; bajo del registro W. El nibble alto de W no es tenido en cuenta. Ejemplos:
; - Si (W)=b'01010110', se visualizará "6".
; - Si (W)=b'10101110', se visualizará "E".
LCD_Nibble
andlw b'00001111' ; Se queda con la parte baja.
movwf LCD_Auxiliar1 ; Lo guarda.
sublw 0x09 ; Comprueba si hay que representarlo con letra.
btfss STATUS,C
goto LCD_EnviaByteLetra
movf LCD_Auxiliar1,W
addlw '0' ; El número se pasa a carácter ASCII sumándole
goto LCD_FinVisualizaDigito ; el ASCII del cero y lo visualiza.
LCD_EnviaByteLetra
addlw 'A'-0x0A ; Sí, por tanto, se le suma el ASCII de la 'A'.
goto LCD_Caracter ; Y visualiza el carácter. Se hace con un "goto"
; para no sobrecargar la pila.
Sin ir tan a fondo puedes revisar el controlador compatible LCD HD44780, y vas a entender mejor como está organizado la memoria DDRAM.para entenderlo me dices que literalmente el lcd de 16x4 en realidad es un lcd 32x2 y el problema lo resuelvo poniendo tantos espacios asta saltar a la línea que sigue ???
Tu librería en ASM debe de tener una sub-rutina que manipule el cursor o mejor dicho, debe de tener un método para pasar de la primera línea a la segunda, es cosa de manipular dicha rutina.PD: gracias por la respuesta tan rápida. e leído pero los ejemplos están en leguaje que no se usar yo aprendí en assembler
;**************************** Librería "LCD_4BIT.INC" ***********************************
; conexiones son:
CBLOCK
LCD_Dato
LCD_GuardaDato
LCD_GuardaTRISB
LCD_Auxiliar1
LCD_Auxiliar2
ENDC
LCD_Inicializa
bcf LCD_PinEnable
bcf LCD_PinRW
bcf STATUS,RP0
call Retardo_20ms
movlw b'00110000'
call Retardo_5ms
movlw b'00110000'
call LCD_EscribeLCD
movlw b'00110000'
call LCD_EscribeLCD
call LCD_EscribeLCD
return
LCD_EscribeLCD
return
movlw b'00000110'
; Mi solución
LCD_PosicionLinea1
iorlw b'10000000'
LCD_PosicionLinea2
movlw .17
call LCD_PosicionLinea1
LCD_PosicionLinea3
iorlw b'11000000'
LCD_PosicionLinea4
movlw .33
call LCD_PosicionLinea3
movlw b'00001000'
movlw b'00001110'
movlw b'00001100'
LCD_EnviaComando
goto LCD_Envia
LCD_Caracter
LCD_Envia
return
LCD_CodigoCGROM
btfss STATUS,Z
movwf LCD_Dato
goto LCD_FinCGROM
LCD_EnheMayuscula
btfss STATUS,Z
goto LCD_FinCGROM
LCD_Grado
btfss STATUS,Z
movwf LCD_Dato
LCD_FinCGROM
return
LCD_LineaEnBlanco
LCD_UnEspacioBlanco
movlw .1
movlw .2
movlw .3
LCD_EnviaBlancos
LCD_EnviaOtroBlanco
return
LCD_Byte
call LCD_Caracter
LCD_ByteCompleto
LCD_VisualizaAlto
LCD_VisualizaBajo
; return
LCD_Nibble
btfss STATUS,C
LCD_EnviaByteLetra
