//// Joystick.c ////
//// Joystick 8 ejes 24 botones ////
//// Autor: Alejandro ////
//// 02/05/2010 ////
#include <18F2550.h>
#device ADC = 10
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
#use delay(clock=48000000)
#use fast_io(A)
#use fast_io(b)
#use fast_io(c)
#DEFINE USB_HID_DEVICE TRUE
#define USB_EP1_TX_ENABLE USB_ENABLE_INTERRUPT //turn on EP1 for IN bulk/interrupt transfers
#define USB_EP1_TX_SIZE 20
#define USB_EP1_RX_ENABLE USB_ENABLE_INTERRUPT //turn on EP1 for IN bulk/interrupt transfers
#define USB_EP1_RX_SIZE 8
#include <pic18_usb.h>
#include <PPM_USB_HID.h> //USB Configuration and Device descriptors for this UBS device
#include <usb.c> //handles usb setup tokens and get descriptor reports
// Defines y Zarandajas
int8 TxUSB[20];
#define LED_ON output_high
#define LED_OFF output_low
// RAM
int8 connected;
int8 enumerated;
int8 rx_msg[USB_EP1_RX_SIZE];
int8 tx_msg[22]={0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
char NextChar='0';
int1 fTX=0;
int1 fInicio=0;
int1 fLeer=0;
int8 i;
int8 rNroCanal=0;
int8 rTiempo=0;
int8 txlen=0;
int8 txpoint=0;
int8 rAntBot1a8=0; //estado anterior de los botones
int8 FpBtn1a8=0; //Flacos positivos
#bit fp1 = FpBtn1a8.0
#bit fp2 = FpBtn1a8.1
#bit fp3 = FpBtn1a8.2
#bit fp4 = FpBtn1a8.3
#bit fp5 = FpBtn1a8.4
#bit fp6 = FpBtn1a8.5
#bit fp7 = FpBtn1a8.6
#bit fp8 = FpBtn1a8.7
int8 rEncDir=0; //Deteccuion de la direccion de los encoders
#bit Dir1 = rEncDir.0
#bit Dir2 = rEncDir.1
#bit Dir3 = rEncDir.2
#bit Dir4 = rEncDir.3
#bit Dir5 = rEncDir.4
#bit Dir6 = rEncDir.5
#bit Dir7 = rEncDir.6
#bit Dir8 = rEncDir.7
int8 Eje0=0;
int16 Eje1=0;
int16 Eje2=0;
int16 Eje3=0;
int16 Eje4=0;
int16 Eje5=0;
int16 Eje6=0;
int16 Eje7=0;
int16 Eje8=0;
int8 Btn1a8=0; //Encoders
int8 Btn9a16=0; //Encoders
int8 Btn17a24=0; //Ultimos 8 borones
int8 Btn24a32=0;
//Registros enviados por USB 24 Botones
#bit Btn1 = btn1a8.0
#bit Btn2 = btn1a8.1
#bit Btn3 = btn1a8.2
#bit Btn4 = btn1a8.3
#bit Btn5 = btn1a8.4
#bit Btn6 = btn1a8.5
#bit Btn7 = btn1a8.6
#bit Btn8 = btn1a8.7
#bit Btn9 = btn9a16.0
#bit Btn10 = btn9a16.1
#bit Btn11 = btn9a16.2
#bit Btn12 = btn9a16.3
#bit Btn13 = btn9a16.4
#bit Btn14 = btn9a16.5
#bit Btn15 = btn9a16.6
#bit Btn16 = btn9a16.7
// usb_debug_task()
// When called periodically, displays debugging information over serial
// to display enumeration and connection states. Also lights LED2 and LED3
// based upon enumeration and connection status.
void usb_debug_task(void) {
enumerated=usb_enumerated();
// usb_rx_task()
// Listens to EP1 for any incoming packets. The only report ID that is
// configurd to send us data is 2 (keyboard LED status, see above)
void usb_rx_task(void){
#int_RTCC
void RTCC_isr() {
fleer=1;
#int_TIMER1 //Timer 1 overflow
void TIMER1_int(){
void main() {
int8 Trim[2];
int8 Buffer;
set_tris_a(0b11101111);
set_tris_b(0b11111111);
set_tris_c(0b00110111);
port_b_pullups(false);
setup_adc_ports( AN0_TO_AN10 );
setup_adc(ADC_CLOCK_INTERNAL );
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_128|RTCC_8_BIT);
delay_ms(500);
usb_init_cs();
disable_interrupts(INT_TIMER1);
disable_interrupts(int_tbe);
enable_interrupts(INT_TIMER0);
enable_interrupts(global);
set_adc_channel(1);
while (TRUE)
int8 rTemp;
int8 temp=0;
int8 temp1=0;
usb_task();
usb_debug_task();
if(fLeer){
fLeer=0;
set_adc_channel(0); //PREPARO PARA PRIMER EJE
//LEO DIGITALES
output_low(pin_c7);
output_low(pin_c6);
output_high(pin_a4); //prepara para leer primeros 8 botones
delay_us(5);
temp= input_b();
temp1=input_c();
output_low(pin_a4);
output_low(pin_c7);
output_high(pin_c6); //prepara para leer segundos 8 botones
//leo los 8 botones
temp=temp & 0b11110001;
temp1=(temp1 & 0b00000111)*2;
Btn1a8 = temp | temp1;
/* #asm comf rAntBot1a8 //Estado anterior de los botones
#endasm
FpBtn1a8 = rTemp & rAntBot1a8; //Flancos positivos de los botones
rAntBot1a8 = rTemp; //igualo estado actual con anterior
btn7=0;
btn8=0;
if(fp3 & bit_test(rtemp,2))btn7=1;
if(fp3 & !bit_test(rtemp,2))btn8=1;
temp= input_b();
temp1=input_c();
output_low(pin_a4);
output_low(pin_c6);
output_high(pin_c7); //prepara para leer ultimos 8 botones
//leo los otros 8 botones
Btn9a16 = temp | temp1;
//Una vez obtenido el flanco y la direccion seteo los botones
//Reseteo todos los botones del 1 al 16
btn1a8=0;
btn9a16=0;
//Encoder 1
if(fp1 & Dir1) Btn1=1;
if(fp1 & !Dir1)Btn2=1;
//Encoder 2
if(fp2 & Dir2) Btn3=1;
if(fp2 & !Dir2)Btn4=1;
//Encoder 3
if(fp3 & Dir3) Btn5=1;
if(fp3 & !Dir3)Btn6=1;
//Encoder 4
if(fp4 & Dir4) Btn7=1;
if(fp4 & !Dir4)Btn8=1;
//Encoder 5
if(fp5 & Dir5) Btn9=1;
if(fp5 & !Dir5)Btn10=1;
//Encoder 6
if(fp6 & Dir6) Btn11=1;
if(fp6 & !Dir6)Btn12=1;
//Encoder 7
if(fp7 & Dir7) Btn13=1;
if(fp7 & !Dir7)Btn14=1;
//Encoder 8
if(fp8 & Dir8) Btn15=1;
if(fp8 & !Dir8)Btn16=1;
//leo ultimos ultimos 8 botones
temp= input_b();
temp1=input_c();
Btn17a24 = temp | temp1;
//LEO ANALOGICAS
Eje1=read_adc();
set_adc_channel(1); //PREPARO PARA EJE 2
delay_us(10);
Eje2=read_adc();
set_adc_channel(2); //PREPARO PARA EJE 3
delay_us(10);
Eje3=read_adc();
set_adc_channel(3); //PREPARO PARA EJE 4
delay_us(10);
Eje4=read_adc();
set_adc_channel(4); //PREPARO PARA EJE 5
delay_us(10);
Eje5=read_adc();
set_adc_channel(9); //PREPARO PARA EJE 6
delay_us(10);
Eje6=read_adc();
set_adc_channel(8); //PREPARO PARA EJE 7
delay_us(10);
Eje7=read_adc();
set_adc_channel(10); //PREPARO PARA EJE 8
delay_us(10);
Eje8=read_adc();
fTx=1;
if(usb_enumerated()) //si esta configurado el Joysick
if (fTX){
txusb[0]=*(&eje0 + 1);
txusb[1]=*(&eje0 + 2);
txusb[2]=*(&eje0 + 3);
txusb[3]=*(&eje0 + 4);
txusb[4]=*(&eje0 + 5);
txusb[5]=*(&eje0 + 6);
txusb[6]=*(&eje0 + 7);
txusb[7]=*(&eje0 + 8);
txusb[8]=*(&eje0 + 9);
txusb[9]=*(&eje0 + 10);
txusb[10]=*(&eje0 + 11);
txusb[11]=*(&eje0 + 12);
txusb[12]=*(&eje0 + 13);
txusb[13]=*(&eje0 + 14);
txusb[14]=*(&eje0 + 15);
txusb[15]=*(&eje0 + 16);
txusb[16]=Btn1a8;
txusb[17]=Btn9a16;
txusb[18]=Btn17a24;
usb_put_packet( 1, &eje0+1, 20, USB_DTS_TOGGLE);
fTX=0;
delay_ms(10);
