El circuito mas sencillo que conozco para este fin utiliza el ICL7107 de intersil, aqui les dejo la descripcion de su datasheet:
ICL7106, ICL7107, ICL7107S: 31/2 Digit, LCD/LED Display, A/D Converters
The Intersil ICL7106 and ICL7107 are high performance, low power, 31/2 digit A/D converters. Included are seven segment decoders, display drivers, a reference, and a clock. The ICL7106 is designed to interface with a liquid crystal display (LCD) and includes a multiplexed backplane drive; the ICL7107 will directly drive an instrument size light emitting diode (LED) display.
The ICL7106 and ICL7107 bring together a combination of high accuracy, versatility, and true economy. It features autozero to less than 10μV, zero drift of less than 1μV/oC, input bias current of 10pA (Max), and rollover error of less than one count. True differential inputs and reference are useful in all systems, but give the designer an uncommon advantage when measuring load cells, strain gauges and other bridge
type transducers. Finally, the true economy of single power supply operation (ICL7106), enables a high performance panel meter to be built with the addition of only 10 passive
components and a display.
Pueden descarga el datasheet desde este enlace:
http://www.intersil.com/data/fn/fn3082.pdf
Les adjunto el circuito para realizar el voltimetro con displays
