Mas de media hora! es mucho, igual ahi hable con andres cuenca para ver si me envia todo el contenido de este tema con adjuntos y todo para hacer una web y organizar las cosas por categorias, etc.
  program DMX
'  DMX 9 Channel PWM
'  PIC 16F628A @20MHz
'  Mardaso 2008
Const aantalkanalen as byte=9
Dim ch_count, offset, i, j, adres as Integer
Dim dat as byte[aantalkanalen]
Dim startcode, nutteloos, brk, led0, led1, led2, led3, led4, led5, led6, led7, led8 as byte
Dim counter as word
Sub procedure init_usart
    SPBRG = 0x04
    TXSTA.BRGH = 1
    TXSTA.SYNC = 0
    PIE1=0
    PIE1.RCIE = 1
    RCSTA.RX9 = 1
    nutteloos=RCREG
    nutteloos=RCREG
    nutteloos=RCREG
    RCSTA.CREN = 1
    RCSTA.SPEN = 1
    INTCON.PEIE=1
    INTCON.GIE=1
End sub
sub procedure init_timer0
  counter = 0            ' Initialize counter
  INTCON=0
  TMR0 = 160             ' load value TMR0
  INTCON.GIE=1
  INTCON.T0IE=1         ' Enable TMRO interrupt
  INTCON.T0IF=0
end sub
Sub procedure interrupt
  if INTCON.T0IF=1 then
      inc(counter)          ' Increment value of counter on every cycle
      If counter <= led0 then
         portb.4 = 1
      else
         portb.4 = 0
      end if
      If counter <= led1 then
         portb.5 = 1
      else
         portb.5 = 0
      end if
      If counter <= led2 then
         portb.6 = 1
      else
         portb.6 = 0
      end if
      If counter <= led3 then
         portb.7 = 1
      else
         portb.7 = 0
      end if
      If counter <= led4 then
         porta.0 = 1
      else
         porta.0 = 0
      end if
      If counter <= led5 then
         porta.1 = 1
      else
         porta.1 = 0
      end if
        If counter <= led6 then
         porta.2 = 1
      else
         porta.2 = 0
      end if
      If counter <= led7 then
         porta.3 = 1
      else
         porta.3 = 0
      end if
      If counter <= led8 then
         porta.4 = 1
      else
         porta.4 = 0
      end if
      if counter = 255 then ' if counter is 255, then reset counter
        counter = 0
        ' To prevent clitches load the data at the end of the pwm cyclus
        led0 = dat[0]
        led1 = dat[1]
        led2 = dat[2]
        led3 = dat[3]
        led4 = dat[4]
        led5 = dat[5]
        led6 = dat[6]
        led7 = dat[7]
        led8 = dat[8]
      end if
      INTCON.T0IF=0
      portb.3=0
  end if
  'Uart interrupt routine
  if PIR1.RCIF=1 then
    portb.3=1
    if (RCSTA.OERR) then
       RCSTA.SPEN=0
       RCSTA.SPEN=1
       nutteloos=RCREG
       nutteloos=RCREG
       nutteloos=RCREG
       RCSTA.CREN=0
       RCSTA.CREN=1
       ch_count=0
       brk=0
    else
       if (RCSTA.FERR) then
          nutteloos=RCREG
          ch_count=0
          offset=0
          brk=0xFF
       else
          if (brk = 0xFF) then
             if (ch_count=0) then
                startcode=RCREG
             else
                 if (adres<1)  then
                    nutteloos = RCREG
                    for j=0  to aantalkanalen-1
                        dat[j]=0
                    next j
                  else
                     ' ------------------------------ Hier adres controleren en evt. uitlezen
                     if (ch_count >= adres) and (ch_count < (adres + aantalkanalen)) and (startcode = 0) then
                        dat[offset] = RCREG
                        offset= offset + 1
                     else
                        nutteloos = RCREG
                     end if
                 end if
             end if
             ch_count = ch_count + 1
          else
              nutteloos = RCREG
              ch_count = 0
          end if
       end if
      end if
    PIR1.RCIF=0
    end if
end sub
main:
  TRISA = 0xE0              ' PORTA is output
  PORTA = 0x00              ' Initialize PORTA
  TRISB = 0x02              ' PORTB is output
  PORTB = 0x00              ' Initialize PORTB
  CMCON = 0x07              ' comperators off
  OPTION_REG = $80          ' Assign prescaler to TMR0
 ' Option register
 ' bit <2:0>     | Timer0 prescaler Rate
 '      000      |         1:2
 '      001      |         1:4
 '      010      |         1:8
 '      011      |         1:16
 '      100      |         1:32
 '      101      |         1:64
 '      110      |         1:128
 '      111      |         1:256
  PORTB.0 = 0                 ' Set SN75176 to recieve data
  PORTB.3 = 1
  ch_count=0
  brk=0
     dat[j] = 0
  next j
init_timer0
init_usart
  while TRUE
      adres = 1
   wend
end.
	Un mes sin actividad en el tema, se perdio en la quinta pagina de la seccion, que paso muchachos...
Les dejo un pequeño avance de algunos cosas que estoy haciendo...
Saludos...
