Piel de escroto de mosca Vs. piel de lombriz del Himalaya
hay chicos no entienden... comparo un amplificador de el año 1959 de 50 watt operando a 50 watt con un thd de 0.1% a 50 watt, con un stk de 80 watt, operando a 50 watt con un thd de 0.4 que es cuatro veces mas grande la distorcion del stk que el valvular del año 1959
y para comparar amplis del 2012 tenemos la hilacha esa del accuphase feo con este
http://www.audioresearch.com/Reference750.html
SPECIFICATIONS
POWER OUTPUT: 750 watts per channel continuous from 20Hz to 20kHz. 1kHz total harmonic distortion typically 0.5% at 750 watts, below .04% at 1 watt. Approximate actual power available at “clipping” 850 watts (1kHz). (Note that actual power output is dependent upon both line voltage and “condition” i.e.: if power line has high distortion, maximum power will be affected adversely, although from a listening standpoint this is not very critical.)
POWER BANDWIDTH: (-3dB points) 15Hz to 150kHz.
FREQUENCY RESPONSE: (-3dB points at 1 watt) 1 Hz to 200 kHz.
INPUT SENSITIVITY: 4.6V RMS Balanced for rated output. (24 dB gain into 8 ohms.)
INPUT IMPEDANCE: 200K ohms Balanced.
OUTPUT TAPS: 4, 8, 16 ohms.
OUTPUT REGULATION: Approximately 0.5dB 16 ohm load to open circuit (Damping factor approximately 17).
OVERALL NEGATIVE FEEDBACK: 13dB.
SLEW RATE: 20 volts/microsecond.
RISE TIME: 1.5 microseconds.
HUM & NOISE: Less than 0.2mV RMS – 110dB below rated output (IHF-A weighted, input shorted, 16 ohm output).
POWER SUPPLY ENERGY STORAGE: Approximately 1300 joules.
POWER REQUIREMENTS: 105-130VAC 60Hz (260-750VAC 50Hz) 2100 watts at rated output, 2400 watts maximum, 800 watts at “idle”.
TUBES REQUIRED: 8 Matched pair KT120 Power Output; 1 6550WE Regulator; 1 6H30 Regulator Amplifier; 1 matched pair KT120 Driver; 1 6H30 follower.
DIMENSIONS: 13.5" (34.3 cm) W x 23" (58.4 cm) H x 20.8" (52.8 cm) D. Handles extend 1.5" (3.8 cm) forward and rearward.
WEIGHT: 170 lbs. (77.2 kg) Net; 395 lbs. (180 kg) per pair shipped weight.
esto si es un ampli.... 0.5% de thd a 750 watt de potenciaaaaaaaaaaaaaaaaaaaaaaaa
i m p r e s i o n a n t e !!!!!!!!!
al tubo en audio no hay con que darle......
bueno con comparaciones ya con la de arriba estamos sobrados, que el tubo manejando potencia tiene menos distorcion eso es un hecho y con las mentiras del audio estoy totalmente de acuerdo en que ni en pedo voy a pagar una fortuna por un cable por mas que lo haya creado mandrake el mago no?
y a que la beta de un tr depende de la ic a exactamente eso me referia con cuanto gana esta porqueria....
por que supuestamente en clase ab tiene que pasar de una pequeñisima corriente de colector a una enorme para volver a la corriente de reposo, y en ese trayecto varia la ganancia y mete distorcion como lo explican mas arriba
el tubo es distinto si bien toma corriente la grilla cuando se hace positiva esto no sucede hasta casi la region de saturacion, desde que la grilla es negativa con respecto al catodo la valvula es mas lineal hasta los 0 volt de g1
por eso en todos los ampli valvulares vemos thd a plena potencia y en los tr no,
ahora si tenemos que comprar un transistor de diamante y una valvula con grilla de oro esto es una estupidez atomica..... pero a alguien le gusta toda esa chatarreria y de hecho paga por ella fortunas...
Jajajajajaj, Encontré el calentador que necesito en invierno.
Me parece que están demasiado metidos con el TDH y se están olvidando que los amplificadores a válvulas suelen tener una respuesta irregular, por mas baja que sea su TDH.
Por mas bueno que sea el ampli los transformadores de salida hacen estragos en la respuesta después de unos 8khz y hay que compensar siempre (a menos que esta caída en la respuesta nos venga bien, que pasa frecuentemente al poner el sistema de audio en una sala poco o nada tratada...).
Si te gustan los valvulares usa un valvular y si te gustan los transistorizados usa transistorizado, punto, en ambos casos hay excelentes diseños y en ambos casos (suponiendo que están bien diseñados y compensados) las distorsiones lineales y no lineales están por debajo de los umbrales auditivos con lo cual, si hacemos una comparativa ciega, dudo que alguien los distinga (bue... estoy seguro que nadie los distingue ya que todavía nadie ha pasado ninguna prueba de las que he hecho).
No entiendo muy bien las comparaciones que haces, venis alabando propiedades de equipamiento esoterico del cual hay para SS o Valvulares.
Aca tenes un ejemplo
MCINTOSH MC2KW
Especificaciones
FREQUENCY RESPONSE
+0, -0.25dB from 20Hz to 20kHz
+0, -3.0dB from 10Hz to 100kHz
TOTAL HARMONIC DISTORTION
0.005% maximum harmonic distortion
at any power level from 250 milliwatts
to 2000 watts, 20Hz to 20kHz
INTERMODULATION DISTORTION
0.005% maximum, if instantaneous peak power
output does not exceed 4000 watts, for any
combination of frequencies from 20Hz to 20kHz.
A-WEIGHTED SIGNAL-TO-NOISE RATIO
Unbalanced: 90dB (123dB below
rated output)
Balanced: 94dB (127dB below
rated output)
POWER OUTPUT
2000 watts into an 8, 4, or 2 ohm load is
the minimum sine wave continuous average
power output. The output RMS voltage is:
126.5V across 8 ohms
89.5V across 4 ohms
63.3V across 2 ohms
INPUT IMPEDANCE
10,000 ohms
OUTPUT LOAD IMPEDANCE
Three pairs of terminals each
for 8, 4 and 2 ohms
INPUT SENSITIVITY
2.5V unbalanced; 5V balanced
WIDE BAND DAMPING FACTOR
Greater than 40
DYNAMIC HEADROOM
2dB
RATED POWER BAND
20Hz to 20kHz
POWER GUARD
Clipping is prevented and THD
does not exceed 2% with up
to 14dB overdrive
POWER REQUIREMENTS
Each Power Module:
100 Volts, 50/60Hz, 1440 Watts
110 Volts, 50/60Hz, 13 Amps
120 Volts, 50/60Hz, 12 Amps
220 Volts, 50/60Hz, 7.5 Amps
230 Volts, 50/60Hz, 6.5 Amps
240 Volts, 50/60Hz, 6.5 Amps
Output Module:
100 Volts, 50/60Hz, 35 Watts
110 Volts, 50/60Hz, 35 Watts
120 Volts, 50/60Hz, 35 Watts
220 Volts, 50/60Hz, 35 Watts
230 Volts, 50/60Hz, 35 Watts
240 Volts, 50/60Hz, 35 Watts
OVERALL DIMENSIONS (H x W x D including
handles, connectors and feet)
MC2KW Output Module and Power Module:
12-5/16" (31.27cm) x 17-3/4" (45.1cm) x 26-5/8" x (62.54cm)
WEIGHT
MC2KW Output Module: 121 lbs. (54.9kg) net;
146 lbs. (66.2kg) in shipping carton
MC2KW Power Module: 158 lbs. (71.7kg) net;
183 lbs. (83kg) in shipping carton
Realmente crees que una escucha HI/FI requiere de este mamotreto, o el mamotreto que posteaste?
Esto es subjetividad, este tipo de equipamiento es para mostrar cuan grande es tu billetera, que es algo muy comun entre los famosos Hi-Enders.
Los bandos existen porque son negocio, negocio del que vende en detrimento del que compra.
Sabes cuantas veces fui a casas de audiofilos que me mostraban equipamiento con varios ceros, y en la sala no tenian absolutamente ningun tipo de correcciona acustica, que te mostraban cables de 2000 dolares , pero ni siquieran equalizaban sala " porque el minimalismo es lo mejor". Debes ser un tipo grande pero equivocas el camino, si te gustan los equipos a valvulas defendelos desde la posicion que son lindos, que te despiertan emociones y que a vos te gustan , pero tecnologicamente son obsoletos. En tu discurso te falto las otras ramas del audio Vudu, que son el tube rolling, y el break-in time de las valvulas para que den todo su potencial.
Te falto tambien el tiempo de rodaje de los capacitores de acople, con dielectrico de piel de escroto de mosca, porque para bajas frecuencias son lo mejor.
:eek: :eek: :eek: Recién me doy cuenta del peso... 125 Kg :eek:
Eduardo, la misma cantidad de kilos en billetes, necesitas para comprarlo.(n)(n)(n)
Ahora, prestando un poco mas de atenciòn, debe de haber algùn error en los valores de power requirements, para entregar 2 KW, estos valores no me cierran ni ahi (ni viajando a mayor velocidad que la luz y ni retrocediendo en el tiempo.....)
Ahhhh, o serà por eso que son tan caros, serà por el ahorro de energia ???
Acordate que con el banco de capacitores podes entregar mas potencia en intervalos cortos de tiempo, mayores a lo que da el trafo, lo que ponen es el consumo "promedio" pero puede haber picos mayores en algunos casos puntuales (bue.. zarpados mas que puntuales :D:D)
Juan a mi me encanta tambien, a cualquiera que le guste el audio y la electronica al ver estas cosas se le vuela la peluca, pero los veo como un concept car. Es publicidad, no creo que ni siquiera sea negocio. Esto equivale a las Kef Muon, a las ByW 800 Series, los giradiscos con levitacion magnetica y ese tipo de cosas. Son las herramientas que tiene las empresas para decirnos que estan a la vanguardia, pero son eso un concepto.
La de los capacitores no la pude evitar, es la costumbre.:LOL:
Aja, gracias Juan, pero ahi entonces no serìa "2000 watts into an 8, 4, or 2 ohm load is
the minimum sine wave continuous average power output", o me equivoco ???
Sds.
El equipo entrega 2000W, toma de la red eléctrica 1800W y la potencia faltante de la materia oscura del universo.
Así que no solo es Hi Fi, sino que también es ecológico.
La piel de escroto de de mosca ya no se emplea en Hi Fi como dieléctrico en los capacitores, quedó plenamente demostrado que la piel de la lombriz del Himalaya da unos tonos medios mas caramelosos y deconvolutivos sobre todo en frecuencias trans-paramétricas, y por supuesto los agudos son envolventes y virtuosos.
También da unos bajos excepcionalmente "Abrigantes y acolchonados".
Capacitores con dieléctrico de piel de lombriz del Himalaya "Auténtica" a la venta "En exclusividad" a través de la Fogonazo INC. y en oferta especial para el Foro.
! Llame YA ¡, nuestras operadoras lo están esperando.
Satisfacción garantizada o le retenemos su dinero.​
jaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa si es cierto cuantos hay que toman energia de los rayos cosmicos y del calor de el cuerpo del dueño para engrosar sus watts.....
para el bien de la humanidad deberian clonar sus oidos e implantarlos a todos "para que podamos ver la luz..." y apreciar los matices ultrasonicos y sub sonicos que solo ellos escuchan y para que al final le demos la razon jajajas
Aja, entonces hemos descubierto que la materia obscura del universo es la causa del precio.......;)
estube viendo los videos de anuvis en you tube aparte de muy divertidos.... y poniendome un poco serio si los videos son verdaderos don anuvis esta protagonizando la gran estafa 4, jejeje salvese quien pueda.....
