hay chicos no entienden... comparo un amplificador de el año 1959 de 50 watt operando a 50 watt con un thd de 0.1% a 50 watt, con un stk de 80 watt, operando a 50 watt con un thd de 0.4 que es cuatro veces mas grande la distorcion del stk que el valvular del año 1959
y para comparar amplis del 2012 tenemos la hilacha esa del accuphase feo con este
http://www.audioresearch.com/Reference750.html
SPECIFICATIONS
POWER OUTPUT: 750 watts per channel continuous from 20Hz to 20kHz. 1kHz total harmonic distortion typically 0.5% at 750 watts, below .04% at 1 watt. Approximate actual power available at “clipping” 850 watts (1kHz). (Note that actual power output is dependent upon both line voltage and “condition” i.e.: if power line has high distortion, maximum power will be affected adversely, although from a listening standpoint this is not very critical.)
POWER BANDWIDTH: (-3dB points) 15Hz to 150kHz.
FREQUENCY RESPONSE: (-3dB points at 1 watt) 1 Hz to 200 kHz.
INPUT SENSITIVITY: 4.6V RMS Balanced for rated output. (24 dB gain into 8 ohms.)
INPUT IMPEDANCE: 200K ohms Balanced.
OUTPUT TAPS: 4, 8, 16 ohms.
OUTPUT REGULATION: Approximately 0.5dB 16 ohm load to open circuit (Damping factor approximately 17).
OVERALL NEGATIVE FEEDBACK: 13dB.
SLEW RATE: 20 volts/microsecond.
RISE TIME: 1.5 microseconds.
HUM & NOISE: Less than 0.2mV RMS – 110dB below rated output (IHF-A weighted, input shorted, 16 ohm output).
POWER SUPPLY ENERGY STORAGE: Approximately 1300 joules.
POWER REQUIREMENTS: 105-130VAC 60Hz (260-750VAC 50Hz) 2100 watts at rated output, 2400 watts maximum, 800 watts at “idle”.
TUBES REQUIRED: 8 Matched pair KT120 Power Output; 1 6550WE Regulator; 1 6H30 Regulator Amplifier; 1 matched pair KT120 Driver; 1 6H30 follower.
DIMENSIONS: 13.5" (34.3 cm) W x 23" (58.4 cm) H x 20.8" (52.8 cm) D. Handles extend 1.5" (3.8 cm) forward and rearward.
WEIGHT: 170 lbs. (77.2 kg) Net; 395 lbs. (180 kg) per pair shipped weight.
esto si es un ampli.... 0.5% de thd a 750 watt de potenciaaaaaaaaaaaaaaaaaaaaaaaa
i m p r e s i o n a n t e !!!!!!!!!
al tubo en audio no hay con que darle......
bueno con comparaciones ya con la de arriba estamos sobrados, que el tubo manejando potencia tiene menos distorcion eso es un hecho y con las mentiras del audio estoy totalmente de acuerdo en que ni en pedo voy a pagar una fortuna por un cable por mas que lo haya creado mandrake el mago no?
y a que la beta de un tr depende de la ic a exactamente eso me referia con cuanto gana esta porqueria....
por que supuestamente en clase ab tiene que pasar de una pequeñisima corriente de colector a una enorme para volver a la corriente de reposo, y en ese trayecto varia la ganancia y mete distorcion como lo explican mas arriba
el tubo es distinto si bien toma corriente la grilla cuando se hace positiva esto no sucede hasta casi la region de saturacion, desde que la grilla es negativa con respecto al catodo la valvula es mas lineal hasta los 0 volt de g1
por eso en todos los ampli valvulares vemos thd a plena potencia y en los tr no,
ahora si tenemos que comprar un transistor de diamante y una valvula con grilla de oro esto es una estupidez atomica..... pero a alguien le gusta toda esa chatarreria y de hecho paga por ella fortunas...
SPECIFICATIONS
